Old 03-04-2014, 10:29 AM   #841
ZionsWrath
Thanks
ZionsWrath's Avatar
Going to go to first track day ever this year, planning on more. Going to run my stock tire until they burn up.
What think of everything else stock and
OEM camber bolts
Carbotech XP10
RBF 600
The Following User Says Thank You to ZionsWrath For This Useful Post:
CSG Mike (03-04-2014)
Old 03-04-2014, 11:15 AM   #842
Racecomp Engineering
Originally Posted by Cjymiller View Post
Gents, how does spring pre-load factor into ride quality?
Not as much as most think, unless it's a ton of preload (i.e. more than the corner weight).
- Andy
Cjymiller (03-04-2014), CSG Mike (03-04-2014)
Old 03-04-2014, 11:15 AM   #843
OEM camber bolts
Carbotech XP10
RBF 600
Sounds good, have fun!
- Andy
Old 03-04-2014, 11:18 AM   #844
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
what's the magic behind WRC suspensions, seeming how the roads they travel on are actual roads, the level of grip these cars get is beyond my comprehension.
and why don't people immitate their setups and instead focus on touring style cars that wouldn't last a minute on country road.
Old 03-04-2014, 11:38 AM   #845
Wepeel
Drives: '13 BRZ Ltd
I think damper travel and quality have a lot to do with it. I remember seeing pics of the coilovers when their working on the cars inbetween stages, and there is a lot of damper stroke.
The GD Impreza's had something like 8.5" of damper stroke on the rear struts. I seem to remember reading that for the GR chassis rally cars (same rear suspension as the BRZ - multilink), Subaru actually retrofitted struts in the rear. I wonder if I can find that source again.
Wepeel is offline   Reply With Quote
Old 03-04-2014, 11:47 AM   #846
Tons of travel, awesome dampers with lots of compression and not too much rebound. Lots of fluid capacity to reduce shock fade (and gas pressure helps).
- andy
Old 03-04-2014, 11:59 AM   #847
CSG Mike
CSG Mike's Avatar
Their suspension does exactly what it's supposed to do: keep the tires in contact with the ground.
(Dirt) Rally suspension is made for compliance and are actually surprisingly soft. Tarmac Rally suspension is much closer to what you'd see on a track car.
Everything is adjusted to specifically meet the needs of a given stage.
Old 03-04-2014, 12:04 PM   #848
ZDan
ZDan's Avatar
Drives: '23 BRZ
You'd probably be fine on XP8 pads and off-the-shelf DOT4 fluid. That's what I ran in the S2000, never any problems with pads or fluid over many track events.
OEM camber bolts
Carbotech XP10
RBF 600
Old 03-04-2014, 12:54 PM   #849
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
so tarmac rally is really the thing everyone should be immitating
but no one is
what's up with that.
Old 03-04-2014, 01:06 PM   #850
but no one is
I told you....Bilsteins + RCE Yellows ain't a bad way to go on the cheap for a tarmac rally car!
- Andy
Old 03-04-2014, 01:12 PM   #851
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
- Andy
that's the plan
i'm just thinking outloud as to why this isn't common knowledge and why do i feel like i'm a minority in thinking all drivers shoudl strive to improve grip and compliance above looks and stiffness
The Following User Says Thank You to 7thgear For This Useful Post:
solidONE (03-04-2014)
Old 03-04-2014, 01:19 PM   #852
Wepeel
Drives: '13 BRZ Ltd
but no one is
Well, it might be because quality dampers that try to maximize travel are usually $$$$.
The higher level dampers seem to have more travel and obviously much better damping. And since most people are concerned with slamming the car (don't care about stroke) or optimizing the car for track/autocross (relatively smooth), it might not be as important.
Old 03-04-2014, 01:35 PM   #853
Also, RCE Yellows sell quite well so maybe there is a lot of people with the same mindset. They're just not as vocal as those that want the car real low. And the Bilsteins only just came out.
Also, real rally coilovers are expensive.
- Andy
Old 03-04-2014, 03:22 PM   #854
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
B14 or B8+TarmacSprings...that is the question, hehe.
Which has more aggressive dampening (b14 or b8) and which has more aggressive springs (a large dynamic range 2.5-7kg progressive vs 5kg linear (which falls in between the B14's prog spring rates))?
I know both aren't crazy, aggressive, full blown, race-only suspension setups (far from it, I know) ...BUT, I prefer to get the more aggressive setup (even though if it's only marginal).
fooddude is offline   Reply With Quote
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
