#827 |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Yes, I meant your subjective opinions and your experiences for specific instances, including the pros and cons. In other words - recommendations
...maybe something that will hold up all day at the track (or at least as most it can), while still being DD'able.
#828 |
What kind of tires?
- Andy |
#829 |
Drives: FR-S Whiteout
Have any of you heard about people installing eccentric bolts on the rear lower arms to gain negative camber? While it doesn't seem to be ideal, or even a very good idea, it sure sounds cost effective.
I believe I read on the board somewhere that people have installed the bolts spindle side of the lower rear arm to get a bit of negative camber. |
#830 | |
Drives: 2015 WRX
| The Following User Says Thank You to Malt For This Useful Post: | solidONE (02-28-2014) |
#831 | |
#832 | |
Drives: 2015 WRX
Speaking of that, anyone know how far a BRZ sits off the ground when measured from the rear jacking point on stock tires and stock suspension? I had previously purchased the whiteline upper ecentric bushing kit and was quoted 6 hours for the install, which was more than I wanted to pay since the labor alone would pay for a set of adjustable LCA's, so those are sitting in my office. I thought that toe arms wouldn't be needed for that modest of a lower to help with the toe issues, but after paying $80 for an alignment, $50 for the bolts, and $130 for the install (yes I know I could of done it myself and would of if I wasn't lazy) and they didn't even adjust the front camber like I wanted, I wasn't very happy. I haven't taken it to a different shop yet but I probably will just to be certain it wasn't just a case of someone not wanting to or not having the time to do the alignment right. It's quite possible they were right and there isn't any more camber adjustment to be had. Either way I felt like I threw $270 out the window. That being said, the guys at the shop were super nice. As for tracking with them, I don't see why it would be any different than using eccentric bolts on the front. I imagine if they are installed properly they shouldn't slip. Last edited by Malt; 02-28-2014 at 11:21 PM. Reason: added more info |
#833 | |
The reason why they may rotate is because of where they are connected. The angle of the spindle will change relative to the control arm when the suspension does it's thing. Compress and decompress. It is effectively a hinged connection out back vs the strut and spindle connection that stays in the same position up front. What is the diameter of that bolt BTW? |
#834 | |
Drives: 2015 WRX
http://www.ft86club.com/forums/showp...15&postcount=6 For the record, no grinding was done or necessary according to the shop. |
#835 |
245 width... I plan on trying PSS, D2 and RS3 and switching off as time goes by; all for DD. Maybe try a Bridgestone flavor too (RE11 or other..idk which are the good ones). Don't really have money currently for a track-day-only extra set of wheels/tires; though that would be nice and maybe so in the future.
#836 | |
Drives: 2013 Scion FR-S - Argento
What would be the ideal alignment specs for a car lowered on Yellows, 90-95% DD, few times a year on a track or auto-x, 17X8.5 +38, 245/40-17's? And, can I achieve this without any additional parts, or should I at least add OEM bolts? How about for the rear? (I think you've kind of answered this above, I'm just trying to make sure I understand what's a good spec and how to make that happen.) |
#837 | |
0 toe front, hair of toe-in for the rear. - Andy |
#838 |
Original 2013 Owner
Drives: 13 BRZ, Galaxy Blue Silica
Gents, how does spring pre-load factor into ride quality?
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα |
#839 |
It seems for car applications little or no preload is added. Come to think of it... the stock setup has preload as evidenced by the need for spring compressors to install and remove.
#840 |
Not really a direct answer, but more caster will let you run less static camber BUT will also make steering input less reactive for small inputs. It's all a balance with the whole setup. Adding a bit more caster might mean you can run less (or no) toe in while still feeling stable in a straight line, but it might dull the input too much for your taste.
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
