Old 02-04-2014, 12:11 AM   #29
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Good stuff. So in simpleton terms, is our stock front suspension setup good enough for aggressive street driving with only grippier tires? Would it be entirely beneficial to add more camber via the OEM camber bolts? Are there any adverse effects of doing that (aside from potentially a little less braking traction)?
Also, do you think there is any advantage to this McPherson strut design (aside from less/lower down unsprung weight) compared to other McPherson and double wishbone designs?
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 02-04-2014, 09:18 AM   #30
Wepeel
Drives: '13 BRZ Ltd
IMO the stock suspension is quite good, easily good enough for anything on the street. It's even good for autocross and tracking, feel-wise, but there are things you can do to it (stiffer, more camber) to make it faster on the clock. More camber will increase front cornering grip and with small amounts the OEM camber bolt provides it shouldn't affect braking performance. I don't see any downsides to it - tire wear shouldn't be an issue as long as toe is in alignment.
I don't think there is anything novel about the BRZ strut design - it's pretty straightforward, simple - definitely not as complex as some other front strut arrangements I've seen (BMW, Ford, ...). I think the handling ability of the BRZ is more due to being low weight, light weight, low polar moment, etc, rather than suspension wizardry.
Wepeel is offline   Reply With Quote
The Following User Says Thank You to Wepeel For This Useful Post:
Bristecom (02-04-2014)
Old 03-03-2014, 08:19 PM   #31
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
I'm still a little confused on Caster. Is this what we need? .5 more degrees?
I'm trying to read and figure it out, but this stuff is a little over my head right now.
http://www.whiteline.com.au/product_..._number=KCA434
DrDuquette is offline   Reply With Quote
Old 03-03-2014, 09:28 PM   #32
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
This thread hurts my head and I don't know how I should have the car setup :'(
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
The Following User Says Thank You to DriftEightSix For This Useful Post:
DrDuquette (03-03-2014)
Old 03-03-2014, 11:34 PM   #33
DrDuquette
DrDuquette's Avatar
Yeah the more I research the more I just want to make the car look good than handle amazing. Haa haa.
Lets just "Bag It" and call it a day!!
Old 03-04-2014, 10:13 AM   #34
Wepeel
Drives: '13 BRZ Ltd
More caster will certainly help, to a point. Based on what I've tried on my previous strut cars, getting up to an additional 0.5-0.75 deg of caster from stock helped, but anything more than that made the steering feel a little odd.
DrDuquette (03-04-2014)
Old 02-21-2015, 04:31 PM   #35
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
Interesting read, thanks.
It would be great if someone with coding experience could put together a SAI and scrub radius calculator, with variables being wheel/tyre size, wheel offset, camber adjustment at tophat, hub, and LCA. Similar to the wheel fitment program that was written.
I've changed my wheel offset from +48 to +16, and I'm interested in knowing how much I should be increasing SAI to counter the offset change and subsequent increase in scrub radius. I'm thinking that I'll then need to run a positive camber setting at the hub, to offset the excessive neg camber from increasing the SAI.
Manji is offline   Reply With Quote
Old 02-24-2015, 05:54 PM   #36
sunset_blvd
sunset_blvd's Avatar
Drives: Lava 2014 Scion FRS
Originally Posted by 7thgear View Post
not to take away from what you have said, i would just like to point out that we all shouldn't be using F1 cars as examples because those cars rely on speed for grip. As that guy from top gear showed us, if you drive an F1 car slow, you'll spin)
That's only because of how much grip comes from the downforce. The basic suspension geometry rules still apply.
sunset_blvd is offline   Reply With Quote
Old 02-24-2015, 05:59 PM   #37
sunset_blvd
I'm still learning the car after switching from the Porsche world, but my feeling is as follows:
-1 to -2 degress of camber all the way around
add a little bit of caster
correct roll center proportionally for any drop in ride height.
Old 02-24-2015, 06:01 PM   #38
sunset_blvd
as you can see, the outside wheel not only has to deal with the geometrical movements of the suspension, but also the relative re-positioning of the chassis pickup points in space..
Really good point. There really are a fuckload of variables to consider.
Old 02-24-2015, 08:07 PM   #39
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Its hard to limit what changing caster will do to just camber, there is an almost infinite amount of stiffness you can increase or decrease from the chassis along with spring rates, LCA's and toe.
It would be interesting to see if anyone could stick in some alternate caster settings into the proper suspension model sticky.
Old 02-24-2015, 08:09 PM   #40
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
@Racecomp Engineering @plucas @Shankenstein
I wonder if you guys have anything to add?
Tein Flex Z Coilovers Evasive Motorsports Brakes, Suspension, Chassis 54 07-16-2017 01:21 AM
Raceseng | Billet Aluminum Caster Camber Plates Raceseng Suspension | Chassis | Brakes -- Sponsored by 949 Racing 162 12-29-2014 10:32 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
Rear Caster Adjustment Questions RWDRIFT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-05-2012 11:47 AM
