Old 03-03-2014, 04:39 PM   #1
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
fuel return system?
so fuel return system vs a non return system on our cars?
what does our car have factory and what are the benefits of both on our car (boosted or not)?
lbroskee is offline   Reply With Quote
Old 03-03-2014, 07:44 PM   #2
wparsons
wparsons's Avatar
Stock we have a returnless system. The biggest downside to a returnless system on a boosted car is that you can't easily adjust fuel pressure mechanically without messing with the regulator, which is in the tank. If you run a return system you can put an adjustable FPR in the engine bay and easily change it. You can also increase the flow capacity of the whole system without needing to make a custom in tank regulator.
For an N/A car, I don't think you'll see any real benefits.
flickr
Old 03-03-2014, 08:22 PM   #3
lbroskee
lbroskee's Avatar
So basically since I'm goin boosted just to return system and save myself headaches later?
Old 03-03-2014, 08:30 PM   #4
Basket Case
Drives: 2013 Raven fr-s
Also, a return system will help keep the fuel cooler which helps with a boosted motor. No need on an NA application though.
Basket Case is offline   Reply With Quote
Old 03-04-2014, 07:56 AM   #5
wparsons
wparsons's Avatar
IMO, not needed unless you're building the motor and going for big power. If you're going to keep the stock internals you'll be fine with the stock returnless lines, just a bigger pump and port injectors.
flickr
Sportsguy83 (04-29-2014)
Dynosty 1000 Fuel System Dustin@Dynosty Forced Induction 48 10-08-2018 06:27 PM
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 11:00 AM
FRS Fuel System Component Walkthrough DeatschWerks Engine, Exhaust, Transmission 8 09-21-2012 01:09 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
Deatschwerks BRZ Fuel System Review xwd Engine, Exhaust, Transmission 0 08-11-2012 04:47 PM
