Old 03-03-2014, 12:36 PM   #43
brntrinh
Drives: Asphalt 6MT FR-S
a rubber glove has been a great help to give me enough extra grip to remove stubborn filters by hand
brntrinh is offline   Reply With Quote
Old 03-03-2014, 12:44 PM   #44
choi0706
Drives: t
Originally Posted by mav1178 View Post
I have no idea what it was like on your car. My first oil change had a filter that came off easily by hand.
My "hand tight" is exactly the procedure that is outlined in the FSM, marked on the filter, etc.
Screw on filter. Once rubber base touches engine, turn another 2/3 to 3/4. This can be accomplished by hand.
There is absolutely no need to turn the filter 1.5 full rotations. Please show me where it says to screw on the filter that tightly.
-alex
Edit: torque spec for the filter is 10ft-lb of torque.
If that is not a definition of "hand tight", you're doing it wrong!
there is no definition of hand tight.. which is exactly what I was stating.. even the FSM clearly states rotate an extra 3/4 .. which is my point..
choi0706 is offline   Reply With Quote
Old 03-03-2014, 01:11 PM   #45
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
I've used a giant set of channel locks in the past, but I like this screwdriver method...
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 03-03-2014, 02:31 PM   #46
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
your local dealership sells the proper size oil filter cup that you attach to a rachet. give them a call, if they dont shoot me a pm and i will get you one.
DAN_BRZ is offline   Reply With Quote
Old 03-03-2014, 02:49 PM   #47
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
Lisle Tools. And done.
Ralph Spoilsport is offline   Reply With Quote
Old 03-03-2014, 03:00 PM   #48
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Originally Posted by choi0706 View Post
factory filter has some grease on the gasket..
no it doesnt
supramkivtt2jz is offline   Reply With Quote
Old 03-03-2014, 03:20 PM   #49
choi0706
Drives: t
Originally Posted by supramkivtt2jz View Post
no it doesnt
personally I still add oil, but they do come pre greased..
The Following User Says Thank You to choi0706 For This Useful Post:
racecat (03-03-2014)
Old 03-03-2014, 03:48 PM   #50
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
i beg to differ. None of mine have "grease" on them, but yes, i add oil as well.
Old 03-03-2014, 04:16 PM   #51
choi0706
Drives: t
all of mine do.. have you checked the bottom?
[IMG]http://i140.photobucket.com/albums/r10/choi0706/20140303_150119_zpsb9ae***d.jpg[/IMG]
Old 03-03-2014, 04:40 PM   #52
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
every one of them. they all have the same chalky protective coating - definately not "grease" at all.
brb while i buy more filters so i can have more than you.
Old 03-03-2014, 04:45 PM   #53
choi0706
Drives: t
its grease..
Old 03-03-2014, 05:50 PM   #54
CoupedUpSubie
Drives: 2013 BRZ Limited
its grease..
All filters gaskets have that coating, it is definitely not grease meant for aiding in a proper seal and protecting the gasket. I don't have an old box at my disposal but many say to add some engine oil to the gasket so it won't bind and fold against the sealing surface.
That same coating is even on fuel filter gaskets which I normally wet the surface with a bit of fuel when installing them.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 03-03-2014, 09:07 PM   #55
retoocs
I learned by lesson with my Legacy GT, let the dealer do the first oil change. The oil filter and the drain plugs were probably installed by gorillas.
I used one of these now to get filters loose.
retoocs is offline   Reply With Quote
Old 03-03-2014, 09:09 PM   #56
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
not all... look at the filters at an average auto parts store.
The "grease" is why OEM filters are of a higher cost, they are shipped with a packing grease.
... but having said that, all FSM (Toyota/Subaru) specify to use oil to lube up the gasket.
FWIW.
-alex
OEM Subaru engine air filter + cabin air filter autobrz Mechanical Maintenance and Tools 6 03-09-2014 09:28 PM
Does anybody know exactly what filter the injen Sri uses? I want to get a new filter Frsexxxy Engine, Exhaust, Transmission 13 02-19-2013 10:04 AM
PLS REMOVE Nezz Australia Classifieds 0 01-31-2013 05:59 AM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 10:41 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
