#15 | |
Drives: 2013 FRS Whiteout
#16 | |
Site Moderator
Drives: Stuff
First to get this out of the way, if you can lock up the tires and engage ABS you do NOT need more brake torque. Now, the reasons for using a "BBK" are (not in order of importance): -Consumables -Additional thermal mass -More efficient cooling -In some kits, reduction in unsprung weight -Better pad selection (depends on the car) -Modulation/Feel (depends on the car/OEM setup) Let's look at each of those in a bit more detail. 1. Consumables: I did the math awhile ago and really don't feel like doing so again, but the pads in the Essex kit (which I use) are about 50% thicker and cost less than the OEM size pad. Rotors are more expensive but last significantly longer. So even though the rotor rings cost more, their durability and long life span combined with the lower cost pads and MUCH longer lifespan create a lower cost solution for those who track their cars. (pretty close to 100% worthless consideration on a street car) 2. Additional Thermal Mass: A rotor is a piece of equipment that has multiple roles. It provides a friction surface for the pads, it connects the braking system to the hub, and thus the wheel and most importantly the tire, it dissipates heat from the braking system and most importantly it holds heat generated during braking. More thermal mass is important because it allows for repeated stops with less cool down time and prevents some heat from going to the pads and caliper. Once you extend the metals capacity for heat other components take more of it and you exceed pads thermal ranges, etc. However, this is a two way street. You can EASILY have too much thermal mass making it hard to get temps where you want them to be. This is why huge 14" rotors on these cars is just silly IMO. There are two ways to increase thermal mass, diameter and thickness and different kits go about it in different ways. Refering to the Essex Sprint kit again, it mostly increases width, this is ideal in terms of leverage staying about stock and with the caliper choice overall brake torque doesn't change much from stock, preventing bias issues. 3. Most BBKs use thicker rotors, which allows for more air to be pushed through the vents for cooling. They also use directional rotors with directional vanes. Vane count varies for the various kits. Cooling is related to one of the rotors jobs (dissipation of heat). 4. AL hats are light, calipers can be lighter. In the case of the Essex Sprint kit it's about 10lbs/front wheel (20lbs total). This is a difference that can be felt in steering and responsiveness of the front suspension. 5. Pad selection varies by car and we are lucky in that there are a bunch of WRX pads so this isn't as critical for us, however, some BBK still have better pad selection than the OEM pad choices (Wilwood superlite based kits, Essex kits, etc). Some may have worse pad selection, I haven't researched them but the only ones with worse selection are likely ebay ones. 6. Fixed calipers off better modulation and feel than sliding calipers. This is important to us as the OEM setup are sliders. The benefits here are pretty obvious. As for the rears, you limit all of these benefits. One you don't need more thermal mass on a US or high spec overseas car. IMO the rear brakes are likely too much already, common on RWD cars with traction control. I run even pads F&R now for rotation but there's absolutely no need to increase cooling or brake torque in the rear. That is of course unless you drastically increase front brake torque (huge rotors, caliper choice, etc) then you would want to regain OEM balance or you will likely have WORSE braking performance than stock.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles Last edited by Dave-ROR; 03-03-2014 at 01:10 PM. Reason: typos |
| The Following 11 Users Say Thank You to Dave-ROR For This Useful Post: | BRZ NA (03-03-2014), CSG David (03-03-2014), CSG Mike (03-03-2014), JRitt (03-04-2014), Krispeee (03-03-2014), Pointmutation (02-25-2016), Racecomp Engineering (03-03-2014), SirBrass (03-03-2014), Sportsguy83 (03-03-2014), suaveflooder (03-03-2014), yomny (03-03-2014) |
#17 | |||
We don't have to deal with any rear BBK upgrades as this has been deemed as a modification that does very negligible benefits to the overall package of the vehicle. Quote:
When performing a cost analysis, we found that a BBK will work towards our favor. For the majority, it may or may not help them in the long term. It does offer a sense of satisfaction seeing some fat caliper behind your wheels though. ![]() If you're local to us, we'll show you what the stock brake calipers and rotors can do (unless you're @Dave-ROR who tends to just break everything). |
| The Following 3 Users Say Thank You to CSG David For This Useful Post: |
#18 | |
Site Moderator
Drives: Stuff
Weight transfer isn't defined by spring rates. Certainly you can make static and dynamic handling changes that may make you desire a brake configuration change (as an example I've run lower rear pads to minimize oversteer from trail braking on heavy rear roll stiffness biased FWD cars). In a BRZ, stock or modified, equal pads are the best from what I've found so far.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#19 | |
#20 | |
Drives: 2013 FRS, 2008 R32
Speaking from experience with a BBK on my previous car, while driving the Dragon. Hankook V12's just weren't up to snuff. That was fun. lol. |
#21 | |
Drives: 2005 Toyota Camry
Keep in mind that many aftermarket kits have rotors that retain the stock drum parking brake assembly. By design, this makes the rear rotors larger than the fronts if given same caliper layout as front BBKs. -alex |
#22 | |
A no holds barred track only car may have upgraded rear brakes but it's a good bit of extra cash that most even dedicated track guys don't need to spend. The benefit is not very large. Plus you may lose your e-brake which isn't acceptable to most that street their cars. Dave and CSG have summed everything up pretty nicely! - Andy |
#23 | |
#24 | |
#25 | |
So its just braking performance increase by dissipating more heat and having more mass for friction? So the more pistons the kit has doesn't necessarily translate into more pressure/force or bite, just the force being applied over a greater contact area? So in reality most cars out there or car owner's wallets could benefit from simply upgrading the front braking system to a BBK, as in reality the rears are sufficient for most applications. For future reference then it'll be same to assume a good front kit with maybe upgraded rear pads for the rear would suffice most of the needs of a beginner to intermidiate skilled level driver participating in HPDEs? I'll stick to the basics now, since oem power could be dealt with OEM equipment(not pads). I've been looking at some of the brake cooling solutions offered by touge factory or the APR cooling kit and they look pretty good. |
#26 | |
Drives: Sterling BRZ Ltd
I have the 328 front kit with stock rears and love it, its about the heat capacity anyway.
| The Following User Says Thank You to mrk1 For This Useful Post: | yomny (03-03-2014) |
#27 | |
PS- also i was just looking at your fabrication progress.. man you sir are a talented human being! Continue |
| The Following User Says Thank You to yomny For This Useful Post: | mrk1 (03-03-2014) |
#28 | |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
| The Following User Says Thank You to raul For This Useful Post: | yomny (03-03-2014) |
| FRS ChargeSpeed & BRZ STi style Front Lip / Side Skirt Extensions | JonMotoring | Exterior Parts - The Rest | 480 | 01-05-2016 03:51 PM |
| WTB: BRZ PS headlight, hood, front wide fenders, front bumper/ body kit | Guildjs | Want-To-Buy Requests | 5 | 10-31-2013 08:35 PM |
| Stock Front Seats (Front/Driver/Pick up only) For Sale | Sehwan Kim | Interior Parts (Incl. Lighting) | 2 | 10-24-2013 12:09 PM |
| Wtb brz headlights and a white front frs front bumper post to Australia. | jet86 | Want-To-Buy Requests | 0 | 08-20-2013 08:27 AM |
| Perrin Front Front LCA Bushes Zero Offset SOLD | Captain Snooze | Australia Classifieds | 0 | 05-05-2013 04:14 AM |
