Drives: 2013 FRS Whiteout
Why BBK for front only
I had never seen this done much until now. It seems to be a common upgrade within our community. Why do some only upgrade their front brakes to Brembo, Stoptech, AP... and leave the rear setup stock? I would rather hear from people that have done so and their reasons why. I'm not a racing pro but with EBD(brake force thing) on modern cars wouldn't a strong bite upfront only cause the rear to act up? I also see that some front rotors are smaller than the rear, this is due because of the e-brake drum being within the disc?
head of infinite swagger
Drives: 2013 FR-S 6MT
The same reason almost all cars come from the factory with larger vented rotors in the front and smaller solid ones in the back, the front brakes do approx 70% of the braking.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater 2000 Silverstone M5 6MT - SOLD 2013 Ultramarine FR-S 6MT - Car Journal - SOLD 2004 AlpineWhite M3 6MT - SOLD |
Drives: t
smaller in diameter?
on some kits (not sure about frs/brz) you loose the parking brake going with bbk in the rear.. |
#4 | |
![]() On another note, properly designed BBKs will have correctly sized pistons to ensure proper braking distribution. A huge reason for a BBK is really meant for consistency due to additional mass for thermal loading. The BRZ/FRS actually has a really well sized front brake setup. You're not going to magically drop stopping distances. Stopping distances is more of a function of tires. |
So its practical then to upgrade in this manner? I dont mind either option, just curious as to why i see it done more with this car than others. Which kits let you retain the emergency brake? Is is recommended then to use the kits with bigger discs up front?
I know the front does more braking hence bigger discs up front, but going to a BBK and retaining the stock rear is not the same proportion as manufacturers design.
Drives: 2013 FR-S, 2012 MCS
Because most cars are heavily front biased under breaking IIRC
Drives: Exige S 240
Don't take this the wrong way, but your ignorance on the subject (nothing wrong with that) tends to indicate you don't need bigger brakes. Why do you think you need bigger brakes?
Everyone pretty much agrees that with a stock motor, decent (read "sporty") pads and discs for the OEM set-up are more than enough, even if you get regular track action. |
#9 | |
#10 | |
#11 |
People lets focus here... Its just a simple question except for @CSG David i dont think there are many experts here. I simply asked why is it so popular to only upgrade front brakes on this car as compared to others. Please if you have nothing better to do than come on threads and flame it to death.. get lost!
Back to basics, read the question and answer it, in parts if you must. This isn't a critical thinking question or a topic for you wise man to elaborate on..This only applies to the ones with the smart remarks, everyone else i appreciate your input. How is anyone suppose to learn, make decisions with arrogant dope heads replying in such ways. |
#12 | |
Yes sir, i've noticed a lot of them have a smaller disc in diameter up front. example: Front-StopTech ST-40 Red Calipers with 328x28mm Slotted Rotors Rear-StopTech ST-22 Red Calipers with 345x28mm Slotted Rotors |
#13 |
That headunit though...
Drives: 2013 Subaru BRZ Limited SSM
Different strokes for different folks, but here's my opinion on the matter:
Stopping faster shifts more weight up front, meaning there is less friction on the rear tires (less downforce/weight, less friction). For many people, especially on stock/looser suspension, you're not using the rear brakes as much. Because of that, many people don't see the need to upgrade the rear brakes. The bigger the bite in the front, the less you actually use the brakes in the back. This can lead to some funky behavior for sure, if you're not used to driving that way. The car can become a little extra tail happy under braking, and often braking distance can actually decrease. However, with a good stiff and flat suspension setup, you can help with some of that weight shift (a little). I think many people hit the zone where their suspension is stiff enough to help keep those back brakes doing some work, but not stiff enough to where the back brakes need more love. If your car (theoretically) stayed perfectly flat all the time, upgrading all four is definitely necessary. In any other situation, you just need to find the right balance of front/back distribution. Once the suspension is modified, that can change very quickly. Size of the front brakes also matters. There are a lot of good articles out there about this subject if you're looking to read a little more about it. Sent from my iPhone using Tapatalk
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300 Eibach Pro-Kit + Michelin PSS (stock size) |
#14 |
Drives: Exige S 240
| FRS ChargeSpeed & BRZ STi style Front Lip / Side Skirt Extensions | JonMotoring | Exterior Parts - The Rest | 480 | 01-05-2016 03:51 PM |
| WTB: BRZ PS headlight, hood, front wide fenders, front bumper/ body kit | Guildjs | Want-To-Buy Requests | 5 | 10-31-2013 08:35 PM |
| Stock Front Seats (Front/Driver/Pick up only) For Sale | Sehwan Kim | Interior Parts (Incl. Lighting) | 2 | 10-24-2013 12:09 PM |
| Wtb brz headlights and a white front frs front bumper post to Australia. | jet86 | Want-To-Buy Requests | 0 | 08-20-2013 08:27 AM |
| Perrin Front Front LCA Bushes Zero Offset SOLD | Captain Snooze | Australia Classifieds | 0 | 05-05-2013 04:14 AM |
