Old 03-02-2014, 11:41 AM   #1
j0hnnybk01
Drives: Firestorm FR-S
frs low fuel rail pressure ? 15,000 miles
So my car has a cel for low fuel rail pressure. When i give it gas there is no response and the idle is bouncing up and down making poping noises. Any one have any idea what it could be?? I took it to one dealer and they just cleared the code and told me to go back to the dealer i got it from if it happened again ... Sure enough i let it sit for 30 min and start it and it happens again !! so there are no mods on my car except a hks drop in air filter rims and springs . Another thing is the dealer did change my fuel pump for the chirping noise and it did make the noise again . but i am wondering if the fuel pump replacement could be the problem . maybe it was installed incorrectly but it took about 10,000 miles to show up . Has anyone experienced this problem ? i want to start modding the car but i don't think its going to happen if its an unreliable car from the get go .
j0hnnybk01 is offline   Reply With Quote
Old 03-02-2014, 04:15 PM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Have it towed back to the dealer you bought the car from.
The first thing they should check is literally the PSI in the lines.
Another thing you can do is take out the gas cap and turn the car to ON but DO NOT START THE CAR. You should hear the fuel pump priming.
The Following User Says Thank You to N1rve For This Useful Post:
strat61caster (03-02-2014)
Old 03-02-2014, 07:03 PM   #3
j0hnnybk01
@N1rve i had it towed back yesterday morning still haven't heard anything back from the dealer at the moment they wont be open till monday morning and it does seem like the fuel pump is priming although the other dealer said they heard a tapping noise from the fuel pump..
Old 03-03-2014, 01:22 AM   #4
N1rve
N1rve's Avatar
They could of installed the pump incorrectly, which is causing this issue. What they should check is the PSI in the lines.
Old 03-03-2014, 02:43 AM   #5
HapaHaole
Drives: Grocery cart
How will that measure the fuel pressure? And how would that diagnose the high fuel pressure code?
SOLD: 2014 BRZ Limited WRB 6 Speed.
HapaHaole is offline   Reply With Quote
Old 03-03-2014, 02:53 AM   #6
N1rve
N1rve's Avatar
If it's not priming.... then there's no pressure....
I never specifically said this measures fuel pressure. It's just another thing you can do.
You'll need a special tool to measure fuel pressure in the lines. It has a gauge that tells you the PSI. I have no idea what the specific PSI is for this car.
And if someone wants to jump on my case as to why I said "Tow it back to where you bought the car. It's because through experience, the dealer where you bought the car is more incline to help you because you gave them your business.
Old 03-03-2014, 11:55 AM   #7
HapaHaole
A dealer saying take it back where you purchased it is NOT a good dealer, it does not matter where you buy the car, as long as the dealer represent the manufacture they have to honor all warranties on that vehicle.
You can listen for the fuel pump prime, but if it did not turn on his car will not even run period. I would of told that original dealer to fix it, and explain what code you have!
Old 03-03-2014, 07:43 PM   #8
j0hnnybk01
Alright so i got a phone call today from the dealer and they don't know what is causing the problem and they told me they are just going to replace the fuel pump and go from there seems to me this might not go so well ...
Old 03-04-2014, 04:55 AM   #9
N1rve
N1rve's Avatar
All dealers are independently owned and are not owned by Subaru or Toyota so each dealership experience is different.
Check on yelp or google reviews to see if the dealership is good.
Old 03-04-2014, 02:42 PM   #10
j0hnnybk01
Well i got the car back today and they replaced the fuel pump again so far car is running fine with no issues hope it stays that way .
Old 03-04-2014, 03:03 PM   #11
nelsmar
I am assuming they replaced the DI pump? Just for future reference the car idles on DI only, and checking the fuel pressure can be done with tech stream (or if you have some sort of upgraded ecu most platforms will let you log it). The high pressure direct injection system has a fuel pressure sensor. However the lower pressure port injection system does not. That system has to be verified with a fuel pressure gauge.
My flickr - Canibeat
Local magazine scout
FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 28 02-02-2014 08:19 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
High Pressure Fuel Pump Difference? Toyota vs. Subaru 86_ZN6 Engine, Exhaust, Transmission 18 06-03-2013 06:48 AM
Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) R2RO Issues | Warranty | Recalls / TSB 3 02-04-2013 10:06 PM
CP Rail on strike. Where is my BRZ/FRS? percyng CANADA 15 05-28-2012 09:17 PM
