Old 03-02-2014, 04:27 PM   #1
retrosmiths
Drives: Scion FR-S Whiteout
Enkei RPF1 vs Motegi Traklite
Looking for a lightweight 17x8 that won't break the bank (read: around $1k). Will be used for daily with 1 (2 max) track days per month. Will also be paired with a BBK. I've narrowed it down to the RPF1 vs Traklite, the former being called the best-bang-for-buck, the latter being lighter by around 2 lbs per wheel, but also a bit more expensive. Thoughts?
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 03-02-2014, 04:37 PM   #2
xwd
Where are you finding the Traklites? I thought Motegi stopped making the 5x100 ones a couple years ago? I would check the fitment of the RPF1s with the BBK, the spoke design isn't always the most BBK friendly, but you can't go wrong with them if you like the style.
The Following User Says Thank You to xwd For This Useful Post:
retrosmiths (03-02-2014)
Old 03-02-2014, 04:44 PM   #3
raytrix
Drives: Series 10 FR-S
Enkei, no brainer
raytrix is offline   Reply With Quote
The Following User Says Thank You to raytrix For This Useful Post:
Wolfking (03-02-2014)
Old 03-02-2014, 04:55 PM   #4
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
The 17x8 +45 RPF1 clears brakes the 17x9 +45 can't, and +35 just barely clears just due to the spoke design. The 17x8 has convex spokes, the 17x9 has flat spokes.
raul is offline   Reply With Quote
The Following 4 Users Say Thank You to raul For This Useful Post:
86geek (08-29-2017), retrosmiths (03-02-2014), SkAsphalt (03-02-2014), xwd (03-02-2014)
Old 03-02-2014, 05:02 PM   #5
DAEMANO
Time Traveller
Enkei RPF1 17x8 - 15.6 lbs - $240.00
Pros: Lightweight for a cast wheel, Strong due to the design, Cheap cause you can find them used since so many people run them. Confirmed fitment with many BBKs.
Cons: Not hubcentric (73mm bore), Common, very common. Gravity cast so if they do break (which is highly unlikely) they will crack which has more potential for damage in catastrophic event.
Motegi Traklite 1.0 (5 spoke) & 2 (6 spoke) 17x8 - est $280 ea - 14.0 lbs
Pros: Super Light weight because they're forged. Strong due to the design. Cheap new for a forged wheel.
Cons: Not hubcentric (72.6mm bore), more expensive than a cast or flow-formed alternative
Others brands to consider: Kosei, OZ, Mach V (17x9 only), Sparco, BBS (used).
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
raytrix (03-02-2014), retrosmiths (03-02-2014)
FS: Motegi Racing TRAKLITE 16x7 with Kuhmo Ecsta XS ft86Fan Wheels and Tires 8 03-04-2015 10:00 PM
FS: Motegi Racing TRAKLITE 16x7 with Kuhmo Ecsta XS ft86Fan NY / NJ / CT / PA 2 02-28-2015 11:43 AM
Wheel Directory: Motegi MR221 Traklite 1.0 16x7.0 +40 bakerr6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 10-12-2014 09:07 AM
Wheel Directory: Motegi Traklite 1.0 16x7.0 +50 mtsound Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 05-21-2014 05:20 PM
motegi traklite 16x7 bakerr6 Wheels and Tires 0 11-29-2013 12:05 PM
