Old 02-28-2014, 03:03 PM   #3697
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by olorin View Post
Definitely seated correctly. For comparison I seated it on some sockets that are the same length (and swapped for comparison):
The raceseng definitely seems to stick out a small amount more.
That's out by a lot. Check the back of the pulley to ensure they deburred it. Most of the products raceseng sells are unfinished/unpolished. I wouldn't be surprised if a deburring step was missed. If not, send those pics to them and ask for a replacement.
Old 02-28-2014, 07:36 PM   #3698
olorin
olorin's Avatar
Drives: GBS Premium
I've been talking with Mike (moto-east) and Jarret (RaceEng) who have both been very helpful.
olorin is offline   Reply With Quote
The Following User Says Thank You to olorin For This Useful Post:
Calum (02-28-2014)
Old 02-28-2014, 11:42 PM   #3699
choi0706
Drives: t
did innnovate change the hardware? what class were you guys seeing on the older ones?
choi0706 is offline   Reply With Quote
Old 03-01-2014, 12:51 AM   #3700
ntaphse
Drives: beater
It's the same hardware there was just a bad batch. It's already a high grade, no need to change.
ntaphse is offline   Reply With Quote
Old 03-01-2014, 11:54 PM   #3701
Powersfrs
Drives: Frs
How much crank hp is 300whp
Powersfrs is offline   Reply With Quote
Old 03-01-2014, 11:59 PM   #3702
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Around 360-370hp roughly
Figure the average 15-20% drivetrain loss
The Racers Line is offline   Reply With Quote
Old 03-02-2014, 12:02 AM   #3703
Powersfrs
Drives: Frs
J/w Uhm at 200 hp 15 percent loss is about 30 hp meaning that's how much hp u loose moving all the drivetrain right? So at 300whp it takes 60~70 hp to move the drivetrain.?
Old 03-02-2014, 02:54 AM   #3704
DriftEm
DriftEm's Avatar
that is a great point, how i see it, whatever the car is making over the stock whp, you add to the 200 crank hp. So if the stock in 170whp and you making 300whp with your mods then you are making 330 crank hp.
DriftEm is offline   Reply With Quote
Old 03-02-2014, 05:12 AM   #3705
Calum
That Guy
But a dyno doesn't read at steady state. It reads while everything in the drive train is being accelerated.
Sent from my samstone
Old 03-02-2014, 09:31 AM   #3706
xwd
I always equate 300WHP to about 350 crank HP on this car.
So I have my tax return coming in a few days, when does that 210+ kit come out? Does anyone know if the P&L EL header would work with the kit? I can't see why it wouldn't at first glance but I know there isn't much clearance in front of the engine and crank pulley with it. Sorry I'm not an owner yet but looking to become one.
Old 03-02-2014, 09:49 AM   #3707
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Should bolt right up - mine is sitting in pieces in my living room, just waiting for some warmer weather to get it installed.
mikalem is offline   Reply With Quote
Old 03-02-2014, 02:10 PM   #3708
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
if 15 % of loss 300/0.85=352.94
If 20% of loss 300/0.80= 375
Mars2 is offline   Reply With Quote
Old 03-02-2014, 02:15 PM   #3709
Mars2
you have to think that a 100 hp crank engine with 20% loss on drivetrain make 80 WHP
so to get crank Hp from WHp with 20% loss you have to divide WHP by 0.80.
80/0.80= 100
Old 03-02-2014, 02:38 PM   #3710
Powersfrs
Drives: Frs
80/0.80= 100
I get that part... Uhm so at. 100hp crank like u said u loose 20 hp to drivetrain but then as u increase the whp n u add the 20% u loose from the drivetrain the loss keeps going up n up why?? Example 100hp 20hp lost 200hp 30hp lost 300hp. 60hp lost..etc
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
