Old 02-24-2014, 05:01 PM   #141
Wepeel
Drives: '13 BRZ Ltd
So it looks like some people are rubbing the inside of the front wheel on something? What exactly is it rubbing?
Also, thinking of running a 255/40-17 Rival on this wheel. Anyone see any issues with inside front clearance (coilovers obviously)? By my thread engagement math for the RPF1 I can run up to a 3mm spacer without extended studs if needed (the RPF1 have a lot more thread engagement to start with than the OEM wheel).
Wepeel is offline   Reply With Quote
Old 02-24-2014, 05:50 PM   #142
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
It lightly rubs on the tierod end only in full lock scenarios
2superblus is offline   Reply With Quote
The Following User Says Thank You to 2superblus For This Useful Post:
Wepeel (02-25-2014)
Old 02-25-2014, 02:51 PM   #143
Wepeel
Drives: '13 BRZ Ltd
Thanks. 2-3mm spacer should take care of that.
Old 02-25-2014, 03:04 PM   #144
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Eh for how often it rubs it is a non issue for me.
Old 03-01-2014, 01:37 PM   #145
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
not sure if this is a stupid question or not but will coilovers fix this rubbing problem?
Lee358 is offline   Reply With Quote
Old 03-02-2014, 02:13 AM   #146
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
no it's a combination of height and wheel alignment, or even something like camber adjusted at the wheel hub vs camber adjusted a the strut top makes a difference.
86•BRZ is offline   Reply With Quote
Old 03-02-2014, 10:55 PM   #147
Lee358
Lee358's Avatar
So with coilovers I still will not be able to have negative camber?
Old 03-03-2014, 01:50 AM   #148
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
I have 1.5 degrees. No rubbing. YMMV.
Old 03-03-2014, 02:26 AM   #149
s2d4
s2d4's Avatar
You created a thread on the tie rod end rubbing
Old 03-03-2014, 02:31 AM   #150
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
I did. They rubbed when I initially installed coilovers as with a lowered ride height your wheels toe out because of steering arm angle. Alignment cured this but as stated, it is very close.
Old 03-05-2014, 03:20 PM   #151
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Will this setup fit on stock suspension?
I'm looking at getting some Enkei RPF1's in 17X9 +45 but not sure about the tire size yet. What's the widest tire I could use that wouldn't rub on the stock springs? I'd like to go with at least 245's if possible. Any feedback would be appreciated.
smg1138 is offline   Reply With Quote
Old 03-07-2014, 02:00 PM   #152
Wepeel
Drives: '13 BRZ Ltd
I can see how running coilovers with a slotted upper hole and/or the OEM crash bolt may help alleviate the rubbing issue. Not sure if camber at the topmount would affect it one way or the other.
Old 03-17-2014, 11:03 AM   #153
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Merged @smg1138's topic into this one. Maybe this will help his research.
Old 03-17-2014, 02:48 PM   #154
VuDism
NASIOC: AzNSTiImpreza
VuDism's Avatar
@smg1138
I read and read and read the forum between +35 or +45 and i came to the conclusion +35 is the way to go especially running stock struts.
I highly recommend going with 17x9 +35.
I fit 245/40/17 Hankook Ventus s2 noble 1 tires no problem and lowered on RS*R SUPER DOWN Springs (lowered 1.2-1.4 inches). Whiteline 16mm Camber bolt up front for about -1.6 camber. Camber Bolts are $35
either +45 or +35 offset will have the wheel/tires poke in front.. however the +35 gives you more room for camber adjustment while using stock struts with lowering springs
my car is a daily driver and does not rub one bit. I hate hellaflush/poke etc and I think the set up is perfect for daily driving and no headache from rubbing.
VuDism is offline   Reply With Quote
The Following 3 Users Say Thank You to VuDism For This Useful Post:
8R6 (03-31-2014), Bach415 (11-16-2015), congee (03-25-2015)
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 07:31 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 04:50 PM
Wheel Directory: Enkei Kojin 17x9.0 +45 Clipdat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 08-02-2016 05:18 PM
