Old 02-28-2014, 03:16 PM   #1247
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Originally Posted by frsqc View Post
does the OFT tunes fix the idle dip issue if i have the old ecu from 2012?
its getting annoying...
You could go to the dealer and get an updated flash. But yeah, the OFT overwrites that info with its own. I didn't have any idle issues, just cold cranking.
On another note, my P0351 (misfire cyl #1) code DID come back after going back to stock with 91 oct. Time for a new coilpack.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
steve99 (03-01-2014)
Old 03-01-2014, 09:58 AM   #1248
troek
troek's Avatar
Drives: 2012 Toyota 86
Is monitoring oil temps a future possibility with this?
troek is offline   Reply With Quote
Old 03-01-2014, 10:00 AM   #1249
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Yes that, along with 30 new channels, will be available next week via auto update.
Shiv@Openflash is offline   Reply With Quote
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
TM (03-01-2014), troek (03-01-2014)
Old 03-01-2014, 10:01 AM   #1250
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Awesome, can hardly wait
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 03-01-2014, 10:27 AM   #1251
troek
troek's Avatar
30? Haha awesome!
Old 03-01-2014, 04:06 PM   #1252
steve99
Drives: FT86
Hope your good for that $1
2point0 (03-01-2014)
Old 03-01-2014, 07:20 PM   #1253
Sonolin
Shiv, I'm getting lots of e85 cold start issues. Is this something that can be fixed? It's stalled on me every day since it started raining (~3 days ago) ambient temps 56 F according to Weather.com
I'm very confused since I figured in Cali I wouldn't have to deal with this
Sonolin is offline   Reply With Quote
Old 03-01-2014, 08:24 PM   #1254
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Someone posted about adding cold start enrichment in one of the tables. if you did a search you should be able to find it. I'm in socal as well and I got the same every morning after the car has been sitting overnight.
Old 03-01-2014, 08:28 PM   #1255
wparsons
wparsons's Avatar
Originally Posted by shiv@vishnu View Post
Nope. Normal
How about 11.25? Seems pretty low to me, but I'm far from an expert.
That's on 1.42 stage 1 tune, I flashed to 1.56b tonight and will grab a log from that tomorrow to see if it's much different. It was running a pretty horrible IAM (0.11-0.12 at the time of the log), would that effect AFR that much? It had learned up to about 0.6 before I flashed to 1.56b, so I don't think it was knock related? I also noticed that on the 1.42 tune it started off at 0 but on the 1.56b tune it started off at 1.
Car is mostly stock, just a perrin 2.5" catted front pipe and 2.5" resonated exhaust.
http://www.datazap.me/u/wparsons/mar...log=0&data=1-9
flickr
Old 03-01-2014, 08:44 PM   #1256
fstlane
fstlane's Avatar
Drives: BRZ Limited
That was my initial experience as well. However, every since I've been adding 2 gallons of 91 octane gas to every tank of e85 I've never had another problem. It fires up on the 1st crank even with temps in the low 40's. The advance multiplier is always pegged at 1.0 and the fuel trims are right where they should be. Maybe it can be fixed with enrichment tuning but I'm fine with having to blend a little gas for now to get all of the benefits of running e85.
fstlane is offline   Reply With Quote
The Following User Says Thank You to fstlane For This Useful Post:
Sonolin (03-02-2014)
Old 03-02-2014, 02:09 AM   #1257
steve99
Drives: FT86
Pretty sure @Luckrider has done some mods to cranking enrichment tables that worked well.
Old 03-02-2014, 02:42 AM   #1258
Sonolin
Thanks good suggestion I'll look into this after more logs.
I did see the cold start enrichment fix, but was hoping to get a response from @shiv@vishnu status with the OTS tune. I'd think it should handle rough starts better. I'd even love to see another tune like "stg 2 e85 el (winter)" or something.
Anyway, I'll probably end up trying both solutions thanks guys and I'm glad I can edit this myself. Just might be something to consider for the OFT otb.
The Following User Says Thank You to Sonolin For This Useful Post:
fstlane (03-02-2014)
Old 03-02-2014, 06:52 AM   #1259
xclusive_brett
xclusive_brett's Avatar
Drives: 08 scion xb
I haven't had any cold start issues, but I'm getting some lag if I go WOT from a stop. Myabe just need more time for tune to adjust? Been running it since Thursday...
xclusive_brett is offline   Reply With Quote
Old 03-02-2014, 01:07 PM   #1260
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
What brand of fuel do you buy? Propel? They seem to have a lot more ethanol than other brands. Did you have one good tank with no cold start problems then the second e85 tank had them? You'll need to enrich the cold cranking tables, especially the RPM cranking table, around 60 degrees F and below. I get great cold starts this way. PM me your email and I can send you a ROM that handles it.
Or you can do as suggested and just add a gallon or two of 91 to every tank. I don't want to do that because then the ethanol level fluctuates quite a bit.
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
