Old 02-28-2014, 07:27 AM   #1
dssence
Drives: Toyota FT/MT 86
Scion FRS H11 Projector Low beam CREE LED replacement
Guys I'm trying to figure out if these replacement for the FRS low beam which are halogen bulbs inside the projectors work ok on intensity beam and length.
I've checked and have found some cree LED Replacements which coem with a back plate heatsink for proper power discipation but I don't find them quite reliable with a fan on the backside. This is the one
http://www.ebay.com/itm/Cree-CXA1512...item43c6313d55
Then this is the one I might be getting my hands hold off
http://www.ebay.com/itm/301076976468...S:1123&vxp=mtr
Some people have said that these leds within the projector housing do not reflect well enough the led beam cause of the optics which were designed for halogen bulbs. Don't know if that's true. Like the guy who sells both of this cree bulbs told me to get the one with the heatsink cause of that. Basing himself that if I get the 60 watts cree if would not be as bright and the beam wouldn't be so focused.
Anyways I'm opened to listening to your advices.
dssence is offline   Reply With Quote
Old 02-28-2014, 08:27 AM   #2
KAR
Drives: Whiteout 6spd
I took the plunge.. dont think they are worth it..
KAR is offline   Reply With Quote
Old 02-28-2014, 09:01 AM   #3
dssence
Hi what do you mean by the plunge ?
Old 02-28-2014, 10:55 AM   #4
mush
mush's Avatar
Get HID. I dont think the aftermarket technology for LED low beam is up to par yet
Old 02-28-2014, 10:57 AM   #5
dssence
awps I actually wanted to avoid HID and go with LED thought cree was fine. Anyways for HID only low beams , do you have some quality ones not that expensive with good ballasts (metallic casing). Any links to recommend, and simple install.
TNX
Old 02-28-2014, 07:39 PM   #6
KAR
spent the money with out any feedback, def not up to par..
Old 02-28-2014, 07:47 PM   #7
FRSHunter
Drives: Asphalt FRS
Dont' the new Corollas have LED headlights?
EDIT: Found on Toyota's Corolla website. "Standard LED headlights set the stage for a stylish look, no matter the time. Designed to enhance the profile of Corolla, they help you see, and be seen. The best part is they come standard on every model."
FRSHunter is offline   Reply With Quote
Old 02-28-2014, 09:37 PM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
the difference is that the corolla's design was built from the ground up to work with led's.
currently, all the led bulb conversions use a COB- based led which has a very large die area--they emit light smoothly across a space about as wide as a dime. hid and halogen both emit light from a very small fraction of that area, so the engineers have designed the reflectors around the light being emitted from a very tiny centerpoint.. because of this, led bulbs just can't be bright enough because they can't physically fit all the light exactly where it needs to be to compete with hid or halogen lights..
Old 03-01-2014, 01:16 AM   #9
dssence
Ok so I need a hid low beam replacement for my FRS . But I want not that so expensive ones. I'm looking for metallic casing ballasts not those cheap plastic ones which come with rubber isolation inside which breaks down and are disstarous. Any links ?
These low beams are to be fitted inside the projector housing where the halogen are, H11 hids right?
Old 03-01-2014, 01:27 AM   #10
KkSc
KkSc's Avatar
Drives: 86
I had them for 2 months, they are nice, they gives you pure white look, but it's absolutely not bright enough, somehow i found that my OEM Halogen was even brighter than this, so i switched to HID, save your money and get HID.
5000k HID/ Switchback LED signals/ Valenti LED Tail/ TRD Air Intake/ H&R Supersport with Koni Yellow Shocks
KkSc is offline   Reply With Quote
Old 03-01-2014, 01:37 AM   #11
dssence
Okay listen should I get this one
http://store.ijdmtoy.com/Slim-Digita...ersion_kit.htm
Some people say that if the car is not designed to have HIDS by factory sooner or later hids will fail, making you go back to stock halogens. Sooner or later cause the wiring is not prepared, alternator. Or don't know.
I would like to fit low beams the ones inside the projector with HIDS low beam and the high beams , so I would have to buy to HIDS sets ? will the FRS handle that?
I was looking for some good cosntruction ballasts metallic with digital asic and well made not rubbish. But at the same time I don't want to spend a fortune.
Thanks
Update: I think I'm going with these which do have AC ballasts
[ame="http://www.amazon.com/OPT7-Bolt-Z-Arc-HID-Bulb/dp/B00DWKYYLQ/ref=cm_cr_pr_product_top"]OPT7 Bolt AC Z-Arc HID Bulb Set - H11 - 8000K Ice Blue Light Xenon : Amazon.com : Automotive[/ame]
Old 03-01-2014, 02:00 AM   #12
KkSc
KkSc's Avatar
Drives: 86
well, All the HID Kits has their lifetime, doesn't matter if the car comes with HID Headlights or aftermarket HID kits, it will burn out one day, the only thing is FR-S projector is not designed for HID, so the cut off will be not as good as Halogen or some Real HID projector lens, but HID kits is from $50 - $200, so it's not that expensive compare to a full HID Headlights conversion, However, this is just my thought, maybe i m wrong..
Old 03-01-2014, 02:05 AM   #13
dssence
So for the HID to focus the beam properly on my low beam projectors I will have to switch them with ones for HIDS? any links ?
Old 03-01-2014, 02:10 AM   #14
dssence
Sorry these
[ame="http://www.amazon.com/OPT7-Bolt-55w-Xenon-Conversion/dp/B00CF280LM/ref=pd_bxgy_auto_img_y"]Amazon.com: OPT7 Bolt AC 55w HID Xenon Conversion Kit - 9006 - 5000K Bright White Light - 2 Bulbs & 2 Ballasts: Automotive[/ame]
Scion steering wheel emblem replacement: any companies planning to make one? fooddude Cosmetic Modification (Interior/Exterior/Lighting) 8 05-13-2014 06:20 PM
GTA: CREE Reverse Lights Selvedge Canada Classifieds 0 12-27-2012 06:37 PM
Toyota badges direct replacement for Scion ones? seven Cosmetic Modification (Interior/Exterior/Lighting) 2 10-12-2012 10:11 PM
5W High Power CREE LED Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 0 09-21-2012 06:30 PM
Scion FRS center wheel caps replacement? Silverback Cosmetic Modification (Interior/Exterior/Lighting) 10 09-03-2012 02:16 AM
