Old 12-04-2013, 08:14 AM   #43
cslntuee
Drives: Subaru BRZ Limited
Originally Posted by FR-S Matt View Post
Tune + Header -> Overpipe + Front pipe > Drop-in/CAI > (Pick your flavor of catback). That's the best N/A performance and the order it goes in but they all work together even better when they are tuned together.
HI,
What's you option for upgrading the big throttle body?
ex. http://revo-tune.jp/catalogue/detail.php?id=294
Is that worth to combo with CAI for NA setup?
Thanks.
cslntuee is offline   Reply With Quote
Old 12-04-2013, 08:26 AM   #44
FR-S Matt
Originally Posted by cslntuee View Post
HI,
Thanks.
I'd only think this is necessary if you're pushing a very high amount of horsepower. Our stock throttle body is already pretty decently sized for our engine. I think it is a waste until you have internals in the engine. (i.e. cams, heads, etc)
The Following 2 Users Say Thank You to FR-S Matt For This Useful Post:
cslntuee (12-04-2013), Ghost 86 (12-18-2013)
Old 12-18-2013, 06:36 AM   #45
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
I love it when people say that na is useless and to just go FI like spending $1500 is just a few cents away from the 5k you'd need for a turbo setup.
35hp while it isnt a ton will be noticeable in a light car.
GR86 MT premium
StormTrooper is offline   Reply With Quote
The Following 3 Users Say Thank You to StormTrooper For This Useful Post:
ATL BRZ (12-18-2013), HatchetBurial (12-18-2013), Mr.Impreza (02-21-2016)
Old 12-31-2013, 01:53 AM   #46
etherealfall
Drives: Toyota 86 GTS Storm Black
What overpipes have had clearance issues? Are these isolated cases or very widespread?
And do all installations of overpipes require lifting the engine or is it still relatively easy to install?
etherealfall is offline   Reply With Quote
Old 02-28-2014, 11:18 AM   #47
Howardwei
Hi, does the overpipe from invidia have heat shielding? It looks like it doesn't have any coating on there. I am asking because they are giving it to me for free. And if it's not better than I wouldn't install it.
Howardwei is offline   Reply With Quote
Old 02-28-2014, 12:21 PM   #48
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
It does not... pretty sure the pictures make that very clear lol.
leicaboss is offline   Reply With Quote
Old 02-28-2014, 02:12 PM   #49
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Just the OP won't net you much b/c then you're still dealing with the flow restrictions brought on by two full sized cats. Now, OP as part of a FP/OP package and then a tune? Yeah, you'll get benefits in the torque curve with a tune. Maybe not much HP gain, but it should help your tuner reduce the torque dip more than he'd be able to with a stock exhaust.
You'll see the most gains from an op/fp when paired with a more freely-flowing header, though.
exhaust mods after the FP, however, will net you very little. Those are mostly for sound. But FP/OP and headers are where power will be unlocked when you go aftermarket and tuned.
Skip intake. The stock intake flows VERY well, and you won't need to upgrade it until you get into much higher HP applications, which will either require an engine swap if you're staying NA, or you go FI (in which case, your FI kit will include an intake). A built FA20 built for power on e85 still won't have enough increased flow requirements to merit going with an aftermarket intake over the factory intake with drop-in panel filter.
^GT5 Replay Photo Mode^
Old 02-28-2014, 02:28 PM   #50
xxscaxx
Drives: 2013 SWP BRZ
The overpipe is the only part of my exhaust I haven't replaced lol.
Not convinced it will do much, Hell i'm not convinced anything other than the header will do that much.
I have had the stock exhaust mated up to header/stock OP/catted front pipe, and it does not sound very good. Tinny/crappy sounding. Or I would have kept the exhaust this way to keep sound down.
xxscaxx is offline   Reply With Quote
Old 02-28-2014, 02:48 PM   #51
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
I didn't read the full thread..but read many "it will give you 3-5hp, with a tune".... hahaha, what BS! That doesn't really count or make sense does it?? Lol...I mean, the tune itself will give you a couple extra Hp with a stock car, regardless of a new Op or not, lol.
Only way to see if it truly adds Hp is to do an A&B/before&after dyno with NO tune.
Getting really tired of all these comparison dynos of products AFTER a tune. It's like cheating and is moot. You can tune for days and days and years and years and spend thousands on dyno tuning, nonstop until you squeeze say 35hp from your dumb header for example ...but is the customer really going to do that and tune it 100s of times and also with the exact same person doing the tuning? N O
NO tune dynos are the only way to keep it an even playing field with companies and parts. A stock tune is the perfect calibration/monitor unit to keep everything/everyone level and equal in regards to parts and comparisons.
fooddude is offline   Reply With Quote
The Following User Says Thank You to fooddude For This Useful Post:
twasd (10-24-2022)
Old 02-28-2014, 02:54 PM   #52
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Getting really tired of all these comparison dynos of products AFTER a tune. It's like cheating and is moot. You can tune for days and days and years and years, nonstop ...but is the customer really going to do that and tune it 100s of times and also with the exact same person doing the tuning? N O
NO tune dynos are the only way to keep it an even playing field with companies and parts. A stock tune is our calibration/monitor unit to keep everything/everyone level and equal in regards to parts and comparisons.
Yep. I want to see some untuned turbo numbers... You could do a tune on stock car vs tuned bolt ons. Just saying.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
The Following User Says Thank You to FrsDuke For This Useful Post:
Xinshadow (02-28-2014)
Old 02-28-2014, 03:08 PM   #53
ShoShin
ShoShin's Avatar
Drives: WRB Premium
Originally Posted by Wise View Post
I'm looking at getting the Perrin exhaust system and I'm weighing up whether to get it with the over pipe, or to just get the catted front pipe and the cat back components.
My question is, does the overpipe really do anything? Perrin quotes a 3rwhp gain but that's pretty negligible on a dyno and wouldn't even be noticed when driving. How does it increase flow being such a small part of the system?
Does anyone have any experience comparing these two setups?
OP ain't worth it IMO. These things tend to matter more when one decides to go the FI route...or if you commit to a NA setup like TRD did..
ShoShin is offline   Reply With Quote
Old 02-28-2014, 03:09 PM   #54
s2d4
s2d4's Avatar
So what is the point of tuning then?
Old 02-28-2014, 03:37 PM   #55
STV3
Señor Member
STV3's Avatar
Turbo + Stock tune = BOOM
STV3 is offline   Reply With Quote
The Following User Says Thank You to STV3 For This Useful Post:
SirBrass (02-28-2014)
Old 02-28-2014, 03:51 PM   #56
Xinshadow
Drives: 2013 Scion FR-S Ultramarine
Have the nameless, got it on sale early and will be getting OFT/OFH combo and Perrin cat back to complete the set. Not sure how much the OP will get you alone but FWIW it has WAY fewer crimps and bends than the factory piece, so it can only help.
The Nameless unit is a good 12 lbs lighter than stock though (as are most catbacks) so the weight savings alone made it worth it.
Sent from my XT1056 using Tapatalk
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
Xinshadow is offline   Reply With Quote
Sway Bars..Do they really make a difference for a DD? jmkv Suspension | Chassis | Brakes -- Sponsored by 949 Racing 81 08-26-2013 02:54 PM
Tires Make a Big Difference poudre Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-16-2012 10:58 PM
Little details . . . make a difference avusblue Cosmetic Modification (Interior/Exterior/Lighting) 27 08-10-2012 08:53 AM
Do intake systems really make a difference? Echo Engine, Exhaust, Transmission 36 07-26-2012 07:09 PM
Little details . . . make a difference avusblue Scion FR-S / Toyota 86 GT86 General Forum 1 07-21-2012 12:00 PM
