Old 02-27-2014, 11:02 AM   #29
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by RallySport Direct View Post
Yeah they look amazing, and fit very well. I also wished they had replicated the OEM mounting, and they did to a degree, just with studs and nuts and not plastic clips. Also the OEM uses some double sided tape, but not as much as these Prova's, still very impressed with fit and finish
The nuts are probably so that someone can't walk by your car and pop them off.
Anything expensive and easy to steal will get stolen eventually.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 02-28-2014, 01:11 PM   #30
serial gixxer
Negative. One of my studs broke off quite easily from barely tightening the nut. I believe these are there more to help with alignment vs security as it's really the tape holding my pieces on. Just make sure to wipe area down with some isopropyl before applying for added strength and be generous with the tape. The trims will STICK. I know because I had to reapply one from misalignment and it was a bitch to remove. If someone were to jack these with the amount of force they would have to use, nuts wouldn't do anything. But they better be sportin some Nike's.
I agree with above poster. Fitment is good but don't expect 100. Do I regret buying? No. These are quality pieces and they look fabolous. Best looking fender trim I've seen to date.
serial gixxer is offline   Reply With Quote
Old 02-28-2014, 01:35 PM   #31
636
636's Avatar
Drives: '23 CWP BRZ
Would you be willing to sell the stock OEM fenders you took off? Let me know!
636 is offline   Reply With Quote
Old 02-28-2014, 04:57 PM   #32
serial gixxer
Sorry sold these a while back. Not trying to he a d*** but maybe pm is better for questions like this?
Old 03-15-2014, 08:58 AM   #33
sirisvirus
Drives:
👍 nice DIY
Sent from my Subaru BRZ Limited using plastic cup 2.0
sirisvirus is offline   Reply With Quote
Old 08-02-2014, 03:27 PM   #34
banane63
banane63's Avatar
Drives: BRZ Club blanc perle
It's better to paint the fender in black in the back of the grid before putting it. Especially for the white coloured cars, otherwise the original paint can be seen, and so it shows that they are false...
Collecteur et frontpipe Supersprint full décat - Catback Remus
Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons
banane63 is offline   Reply With Quote
Old 08-02-2014, 10:12 PM   #35
s2d4
s2d4's Avatar
Its better to cut the fender.
The Following User Says Thank You to s2d4 For This Useful Post:
coyote (08-02-2014)
Old 08-03-2014, 02:39 AM   #36
banane63
banane63's Avatar
I Don't think there is any gain here, just useless hard work for unequipped guy like me...
Envoyé de mon Nexus 7 en utilisant Tapatalk
Old 08-03-2014, 03:40 AM   #37
s2d4
s2d4's Avatar
No gain? OK.....
Old 08-22-2014, 06:00 PM   #38
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Cut my fenders too
Nervously took a stab at cutting my fenders too. Added some color to the grilles to match my painted emblems.
Used a $26 3" cut-off tool from Harbor Freight (get a pack of 40-grit discs) and my rotary Dremel with a small cut-off disc. Taped all around the fenders twice to protect from any accidental slippage. Put on long sleeves, eye protection, and gloves if you're going to do this; sparks will be flying everywhere.
Also, I glued on some foam washers to the bolts that are on the emblems themselves. Figured this will keep the bolts from coming off, and they'll cushion the nuts when you tighten them. On the rear, I put down another foam washer, plus a steel fender washer on top, then the nut. The steel washer will spread out the tension all across the emblems when you tighten them down -- these things are never coming out now....
The vents definitely help the engine breathe, I can feel hot air coming out while the car is running.
.ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
The Following User Says Thank You to ck-GT86 For This Useful Post:
SuperTom (12-26-2019)
Old 08-22-2014, 06:37 PM   #39
omegared19
omegared19's Avatar
Drives: White 2013 BRZ Limited 6MT
Attachment 88803
.ck
Well done sir. Would love to see the work in person
omegared19 is offline   Reply With Quote
The Following User Says Thank You to omegared19 For This Useful Post:
ck-GT86 (08-22-2014)
Old 08-22-2014, 06:53 PM   #40
ck-GT86
ck-GT86's Avatar
Let me know if you need yours cut, I'll help out.
.ck
|| My Build Thread ||
The Following 2 Users Say Thank You to ck-GT86 For This Useful Post:
Alain (08-22-2014), omegared19 (08-22-2014)
Old 08-22-2014, 06:54 PM   #41
omegared19
omegared19's Avatar
.ck
Thanks for the offer. Actually did mine a year or so ago
ck-GT86 (08-23-2014)
Old 08-25-2014, 01:46 PM   #42
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
i really wish the white wasnt so off
ive been looking for a set for my FRS for a couple months now
question about brz/fr-s front fender vents nmullin11 Cosmetic Modification (Interior/Exterior/Lighting) 23 03-20-2013 05:01 AM
FS: OEM FR-S "86" fender emblems Trojan_SC Exterior Parts (Aero, Lighting, Etc.) 2 02-25-2013 08:13 PM
FS: Toyota 86 Front And Rear Emblems hayleybeaners Exterior Parts (Aero, Lighting, Etc.) 2 01-30-2013 08:21 AM
Functional front fender vents JohnATL Cosmetic Modification (Interior/Exterior/Lighting) 10 01-25-2013 11:58 AM
WTB: Stock Scion front & rear emblems JoeBoxer Exterior Parts (Aero, Lighting, Etc.) 9 10-01-2012 10:52 PM
