Old 02-16-2014, 04:52 AM   #99
akyp
Drives: 2012 86
I just installed the PCV can into my RHD 86. Well I have yet to install the hoses but it was getting dark. Anyway the sucker took a lot of persuasion to get into place and even then I wasn't sure I did it right -- the bracket isn't perfectly horizontal. I probably should have bought the LHS can instead.
With the bracket installed it's impossible to unscrew the can so I need a syringe or something to suck up the fluid through the dipstick hole.
akyp is offline   Reply With Quote
Old 02-16-2014, 05:29 AM   #100
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Originally Posted by utekineir View Post
That's what the little tube on the end if your sucking device is for
It's what I used to do with a previous can with no drain. Big syringe and tube
Ahhh I didn't know that. I always thought that the oil would drain/drip out via the long tubing down near the bottom of the engine bay into an empty bottle when you want to empty it(like a fumoto valve). Learn something new every day!
I think I might root around and find a cheapie $2 spray bottle for emptying the Rad Catch cans cos I'm cheap like that lol.. Maybe utilised an old use spraybottle trigger from a cleaning product.. $0 lol
Better than spending the $60 for the petcock I think
stevo_12v is offline   Reply With Quote
Old 02-21-2014, 01:35 PM   #101
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Are these supposed to come with spring clamps for the hoses? I installed mine today and there weren't any clamps included. The photo on the Radium website shows 3 clamps per catch can kit.
HRTROB is offline   Reply With Quote
Old 02-28-2014, 01:22 AM   #102
whataboutbob
AutoX-10/10ths every run
So after a couple of weeks of daily driving, a weekend of autox, and a couple of hours of practice driving here's what i found in my catch cans. The dry one is inline to the intake tube, and the NOT dry one is inline to the back of the blower. Wow.
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
BatStig (02-28-2014), JB86'd (02-28-2014)
Old 02-28-2014, 03:31 AM   #103
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Holy crap obviously this is not a want but a "need" when boosted. Money well spent Bob.
The Following User Says Thank You to OICU812 For This Useful Post:
whataboutbob (02-28-2014)
Old 03-02-2014, 07:40 PM   #104
FRSKEV
Drives: FRS
So its safe to say that on a NA car thats close to stock ( minor bolt ons + tune ) the catch can on the PCV side is the only necessary one?
This is what I thought from beginning and after the results of people running dual set ups, the can on the intake side rarely ever has anything in it and this is from forced induction cars. Also from personal experience on previous turbo cars I've always ran dual catch cans and the intake side one never had anything in it.
FRSKEV is offline   Reply With Quote
Old 03-31-2014, 11:35 PM   #105
congiiee
Drives: WRB Subaru BRZ
So the PCV side is the one that actually caught anything? Not sure which one is which from your description.
congiiee is offline   Reply With Quote
Old 03-31-2014, 11:47 PM   #106
whataboutbob
Yes.
Build thread:Here
Old 03-31-2014, 11:52 PM   #107
congiiee
Yes.
Cool. I've been driving around with a vortech for around 15k miles. Hope my engine is not destroyed...
Old 04-08-2014, 12:15 AM   #108
whataboutbob
So I was wrong in my initial response. I went back and looked and I'm pretty sure I have the cans connected to the crankcase breathers, passenger rear end of block, driver front end of block under AC unit.
Build thread:Here
Old 04-08-2014, 12:32 AM   #109
congiiee
still not to sure what you mean. I purchased only the PCV can. which is the one that would mount in front of battery. Is that the can with the oil residue in your picture? Or is it the one that didn't catch anything at all?
Old 04-08-2014, 02:19 PM   #110
xwd
The passenger rear end of block sounds like the PCV?
NA you want it connected on the PCV, I've definitely caught oil in my Radium can coming from there after doing autox/track days.
Old 04-09-2014, 03:35 AM   #111
congiiee
So do you think just the PCV would be sufficient? I'm vortech supercharged and just bought the PCV side
Old 03-02-2016, 12:49 AM   #112
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
has anyone noticed metal shavings in their catch cans? I am assuming metal flakes are dropping down from the steel wool. it makes me feel quite uneasy that some can be sucked into my intake. I started to burn a bit of oil recently. (~250ml over 3000kms)
projek_01 is offline   Reply With Quote
DIY | Radium Catch Can | Video | Full Technical Info Dezoris DIY (Do-It-Yourself) Guides 233 01-07-2020 02:12 AM
Catch cans: what are you running? Apex Chase Engine, Exhaust, Transmission 144 08-14-2014 07:17 AM
Rev Works Vented Catch Cans - Need Your Help on deciding color options!! Rev Works Engine, Exhaust, Transmission 20 02-06-2014 12:53 PM
cusco catch cans difference Silverdub Engine, Exhaust, Transmission 15 04-23-2013 09:17 AM
AVO Inlets, Injen Intakes, Cusco Catch Cans, All In Stock! RallySport Direct Engine, Exhaust, Bolt-Ons 3 10-05-2012 12:39 AM
