Old 02-06-2014, 11:05 AM   #2759
kfcheung
Drives: 2014 Subaru Brz with manual
Originally Posted by Eurasianman View Post
Can not be worse than my previous car. I literally had 50+ pages of service receipts for the vehicle. Some of those were oil changes, the rest... yea. And that was only within the first 30,000 miles. After that, I traded it in for the BRZ. I only have 3 or 4 service receipts for the BRZ and that is for oil changes and warranty work. All visits required 1-2 hours of being without my car.
Best purchase in my life.
Side note/back on topic: Hope they figure it out and get you back in your BRZ
The car design is awesome, dont get me wrong. It's just the parts quality and lack of follow up with details caused frustration. And it's a new car that malfunctioned at 127km......
Hopefully i can get my car back soon. Valentines day is coming......
kfcheung is offline   Reply With Quote
The Following User Says Thank You to kfcheung For This Useful Post:
eurospeed (02-16-2014)
Old 02-06-2014, 12:44 PM   #2760
DANG, kfcheung!
That sounds like they should give you another new car....
Only 127 km and they have had it for two weeks and don't know what the heck is wrong with it ...... that ain't right!
Old 02-07-2014, 12:00 AM   #2761
kfcheung
DANG, kfcheung!
Thanks,
if they dont do things right this time, I will not buy another subaru again in the future.
They also told me they will replace the ECU for me but what the heck. New car needs a new ECU after one week of usage. This is a joke!
This is subaru.
humfrz (02-07-2014)
Old 02-10-2014, 04:57 PM   #2762
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Apparently this things haven't been resolved. I have the coming to a stop in neutral rpm did along with a rattle from engine trying not to stall. I took it to the dealer and they "updated the ECU" but quite honestly the car came out doing the same thing. What should i do, take it back again? It's ridiculous because they say they have to replicate it in order to do anything.. its a random thing.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 02-10-2014, 06:05 PM   #2763
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
Look at your state's lemon law. In Texas taking it back to the dealer works in your favor as there are minimum requirements to the quantity of visits to the dealer for the same issue in a certain period of time.
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
The Following User Says Thank You to Turkish For This Useful Post:
yomny (02-10-2014)
Old 02-11-2014, 01:01 PM   #2764
jhh3000
Drives: BRZ Limited 6MT
I took my car in this morning for this issue (no CEL though) and they re-flashed the ECU with an update. Will let you guys know if this continues... so far as I can tell, the engine noise characteristics have changed significantly, but I don't know if that means the idle issue has been resolved.
jhh3000 is offline   Reply With Quote
The Following 2 Users Say Thank You to jhh3000 For This Useful Post:
eurospeed (02-16-2014), Marrk (02-11-2014)
Old 02-15-2014, 04:52 PM   #2765
Darkrune
Darkrune's Avatar
Drives: 2017 86
So I found out something interesting when I installed my new header this week. I put defoulers on BOTH of my O2 sensors during the install, thinking that it would be better to control engine check issues. WRONG!! I had check engine light, rough idle/almost stalling, slip light, etc. All of the issues discussed in this thread. So this leads me to believe that people who have no had catastrophic engine failures could try replacing their front O2 sensors and it may fix it. When I took the defouler off the first O2 sensor and placed it directly into the exhaust stream, all of my issues went away. I could be mega wrong, or I could have discovered something anomalous that not even the dealers could know about.
Darkrune is offline   Reply With Quote
The Following 2 Users Say Thank You to Darkrune For This Useful Post:
Marrk (02-15-2014), Mr.EvoMR (02-16-2014)
Old 02-18-2014, 12:22 AM   #2766
kfcheung
Nice find man, it could be the solution to all the issues that we are having.
Btw my car is still in repair for 3 weeks and still no luck.
Old 02-19-2014, 03:00 PM   #2767
Slysdexia
Slysdexia's Avatar
Drives: '14 Monogram 6MT FR-S - Hot Lava
Originally Posted by Darkrune View Post
I put defoulers on BOTH of my O2 sensors during the install, thinking that it would be better to control engine check issues... ...When I took the defouler off the first O2 sensor and placed it directly into the exhaust stream, all of my issues went away....
Modern cars use the upstream O2 sensor for closed loop running. If it wasn't in the exhaust stream, the engine is trying to operate in closed loop (running with feedback from the primary O2 sensor) with the sensor not reading that's actually going on, hence the issue.
The downstream, secondary O2 sensor is used for verifying catalyst efficiency. That's the one to put a defowler/O2sim on.
It's possible, however, that you've come across the underlying cause by replicating the symptoms. If the O2 sensors are iffy, get damaged, or are particularly sensitive to burned oil, they could be sending bad information to the ECU, hence the problems and catastrophic failure.
Slysdexia is offline   Reply With Quote
Old 02-27-2014, 08:38 PM   #2768
guitarhero23
Drives: 2014 Subaru BRZ
1500 Miles. P0018 Code. Been in Subaru Dealership shop for 3 days now and they don't know how to fix it and have been awaiting word from Subaru on how to fix it. Finally got word today and was told to make some measurements. Guy doesn't know if they will send a short block, long block, or have them tear it apart. Car is bran new 2014.
Edit: Went in shop Monday, came out following Wednesday with new ECU.
guitarhero23 is offline   Reply With Quote
The Following User Says Thank You to guitarhero23 For This Useful Post:
eurospeed (07-04-2014)
Old 03-13-2014, 05:25 PM   #2769
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
My FR-S has received the following...
Short block
Manifold and catalytic converter
Hpfp rev 2
Short block
Oil pump
OTC valve
Hpfp rev 3
Other misc items
Other OTC and gear
ECU replacement
All within ~ 2500 miles, stating at 16,xxx miles
First short block replacement lasted 54 miles
Two ds taillights , one ps taillight, and both rear shocks replaced
Also car was scratch while in service for 51 days and was compensated.
Toyota/Scion and the local dealership have been terrific. However it is obviously sad to go through all of this.
Car is repaired at the moment but I'm considering arbitration.
I'd buy another frs but I'm hearing the release series and 2014 are still having issues
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
The Following User Says Thank You to ill86 For This Useful Post:
Old 03-15-2014, 07:42 PM   #2770
Vis101
Vis101's Avatar
Drives: 2013 Limited BRZ
RPM dip started again yeaterday and continued today.
Sent from my HTCONE using Tapatalk
Vis101 is offline   Reply With Quote
Old 03-15-2014, 07:45 PM   #2771
Turkish
Serial Cone Killer
Turkish's Avatar
The issues seem less frequent in the '14s or else people are being less vocal about it. My '14 brz has been problem free thus far. *knocks on wood*
... his name is...
C'THULHU
ill86 (03-15-2014)
Old 03-17-2014, 09:26 AM   #2772
fatrab
Drives: Subaru BRZ SE Lux Auto
fatrab, BRZ, 11000 miles, in shop, Scotland
fatrab is offline   Reply With Quote
The Following User Says Thank You to fatrab For This Useful Post:
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 06:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 10:00 AM
