#2759 | |
Drives: 2014 Subaru Brz with manual
Hopefully i can get my car back soon. Valentines day is coming...... |
| The Following User Says Thank You to kfcheung For This Useful Post: | eurospeed (02-16-2014) |
#2760 | |
That sounds like they should give you another new car.... ![]() Only 127 km and they have had it for two weeks and don't know what the heck is wrong with it ...... that ain't right! |
#2761 | |
if they dont do things right this time, I will not buy another subaru again in the future. They also told me they will replace the ECU for me but what the heck. New car needs a new ECU after one week of usage. This is a joke! This is subaru. |
| The Following User Says Thank You to kfcheung For This Useful Post: | humfrz (02-07-2014) |
#2762 |
Drives: 2013 FRS Whiteout
Apparently this things haven't been resolved. I have the coming to a stop in neutral rpm did along with a rattle from engine trying not to stall. I took it to the dealer and they "updated the ECU" but quite honestly the car came out doing the same thing. What should i do, take it back again? It's ridiculous because they say they have to replicate it in order to do anything.. its a random thing.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
#2763 | |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
| The Following User Says Thank You to Turkish For This Useful Post: | yomny (02-10-2014) |
#2764 |
Drives: BRZ Limited 6MT
I took my car in this morning for this issue (no CEL though) and they re-flashed the ECU with an update. Will let you guys know if this continues... so far as I can tell, the engine noise characteristics have changed significantly, but I don't know if that means the idle issue has been resolved.
#2765 |
Drives: 2017 86
So I found out something interesting when I installed my new header this week. I put defoulers on BOTH of my O2 sensors during the install, thinking that it would be better to control engine check issues. WRONG!! I had check engine light, rough idle/almost stalling, slip light, etc. All of the issues discussed in this thread. So this leads me to believe that people who have no had catastrophic engine failures could try replacing their front O2 sensors and it may fix it. When I took the defouler off the first O2 sensor and placed it directly into the exhaust stream, all of my issues went away. I could be mega wrong, or I could have discovered something anomalous that not even the dealers could know about.
#2766 |
Nice find man, it could be the solution to all the issues that we are having.
Btw my car is still in repair for 3 weeks and still no luck. |
#2767 | |
Drives: '14 Monogram 6MT FR-S - Hot Lava
The downstream, secondary O2 sensor is used for verifying catalyst efficiency. That's the one to put a defowler/O2sim on. It's possible, however, that you've come across the underlying cause by replicating the symptoms. If the O2 sensors are iffy, get damaged, or are particularly sensitive to burned oil, they could be sending bad information to the ECU, hence the problems and catastrophic failure. |
#2768 |
Drives: 2014 Subaru BRZ
1500 Miles. P0018 Code. Been in Subaru Dealership shop for 3 days now and they don't know how to fix it and have been awaiting word from Subaru on how to fix it. Finally got word today and was told to make some measurements. Guy doesn't know if they will send a short block, long block, or have them tear it apart. Car is bran new 2014.
Edit: Went in shop Monday, came out following Wednesday with new ECU. Last edited by guitarhero23; 03-05-2014 at 10:42 PM. |
| The Following User Says Thank You to guitarhero23 For This Useful Post: | eurospeed (07-04-2014) |
#2769 |
VehicleDynamicsSpecialist
Drives: iG FR-S
My FR-S has received the following...
Short block Manifold and catalytic converter Hpfp rev 2 Short block Oil pump OTC valve Hpfp rev 3 Other misc items Other OTC and gear ECU replacement All within ~ 2500 miles, stating at 16,xxx miles First short block replacement lasted 54 miles Two ds taillights , one ps taillight, and both rear shocks replaced Also car was scratch while in service for 51 days and was compensated. Toyota/Scion and the local dealership have been terrific. However it is obviously sad to go through all of this. Car is repaired at the moment but I'm considering arbitration. I'd buy another frs but I'm hearing the release series and 2014 are still having issues
"The best track modification you can ever make is between the steering wheel and seat." - CSH Last edited by ill86; 03-15-2014 at 08:28 PM. |
| The Following User Says Thank You to ill86 For This Useful Post: | eurospeed (07-04-2014) |
#2770 |
Drives: 2013 Limited BRZ
RPM dip started again yeaterday and continued today.
Sent from my HTCONE using Tapatalk |
#2771 | |
Serial Cone Killer
| The Following User Says Thank You to Turkish For This Useful Post: | ill86 (03-15-2014) |
#2772 |
Drives: Subaru BRZ SE Lux Auto
fatrab, BRZ, 11000 miles, in shop, Scotland
| The Following User Says Thank You to fatrab For This Useful Post: | eurospeed (07-04-2014) |
| NW Owner List & Event Archive | DarrenDriven | Northwest | 1643 | 08-05-2016 06:48 PM |
| Idle issue? | yayforaddison | Issues | Warranty | Recalls / TSB | 891 | 07-14-2016 10:42 AM |
| Idle issue | scioneric | CANADA | 23 | 08-24-2012 01:40 AM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 12:00 PM |
| An unofficial message from TMCA | Courtz1074 | AUSTRALIA | 25 | 05-17-2012 10:00 AM |
