Old 02-27-2014, 02:31 PM   #15
qganja
qganja's Avatar
Drives: 10 series frs
Originally Posted by Knickstape View Post
Maybe a little more responsive down low. I know higher in the rpms the intake is screaming so it "feels" like its pulling a little better in the 4500-5500 range. I've got an AT too btw
what do you have? AEM or Perrin? will it compensate lil bit of the loss of low end torque? (q300 + invidia catless front pipe)
qganja is offline   Reply With Quote
Old 02-27-2014, 02:46 PM   #16
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
Originally Posted by qganja View Post
gotcha! more cheaper than cai. what would you pick between K&N drop in or HKS hybrid?
You know what, I installed the KN just because it was on sale - I'm sure it makes gains but I haven't really paid too much attention to it. It does sound better but I don't want too much noise anyway.
leicaboss is offline   Reply With Quote
The Following User Says Thank You to leicaboss For This Useful Post:
qganja (02-27-2014)
Old 02-27-2014, 03:01 PM   #17
ramiram1984
Drives: 2016 STi DGM
Get em both, then stick with the one you like best. Sell the other one.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
The Following User Says Thank You to ramiram1984 For This Useful Post:
qganja (02-27-2014)
Old 02-27-2014, 03:31 PM   #18
jflogerzi
jflogerzi's Avatar
Just keep the stock box and get a drop in filter. Also look @ it this way. The $ you save can go towards a Tune like an ecutek or OFT. Much better use of the money.
Old 02-27-2014, 06:55 PM   #19
wu_dot_com
Drives: accord
im hesitant with regards to lossing more low end torque because im noticing it right now with my catless front pipe. having a sensible loss on sub 3k and its shifting a lil bit fast upto 3rd gear (oh, i have AT btw)
According to AEM Dyno data it shows no significant power lost at low end.
I am not sure if there is an interference effect with both AEM cai and light weight pulley. The losses I've evperienced is not significant, but it's noticeable.
wu_dot_com is offline   Reply With Quote
Old 02-27-2014, 07:10 PM   #20
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
Ive got the aem and ive switched back to stock w/ a perrin drop in and Im very happy. Wish I did this to begin with.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 02-27-2014, 07:11 PM   #21
qganja
qganja's Avatar
reason for switching to perrin drop in? lol
Old 02-27-2014, 07:16 PM   #22
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
After using aem for about 6 months I started to read about how others were switching back. I liked the oem sound tube and it felt better at low rpm, throttle response was much better but +7k rpm the aem might have had a little more power but Im never that high.
To your original question. I needed to change out my oem filter so I bought the Perrin drop in and the engine seems to be working a lot easier throughout the whole range and sound is cleaner and louder. Much better for the $$$. If I buy OFT or UniChip I might try to see if aem has any advantage, but for the time being Im enjoying stock+.
My BRZ
The Following User Says Thank You to m.wood0213 For This Useful Post:
qganja (02-27-2014)
Old 02-27-2014, 08:28 PM   #23
gramicci101
Off Topic
So, question. Is there a benefit to changing the inlet hose to one of the spiffy silicone hoses? Or should I just leave the entire intake stock except the filter?
The Following User Says Thank You to gramicci101 For This Useful Post:
qganja (02-27-2014)
Old 03-01-2014, 01:45 PM   #24
qganja
qganja's Avatar
im not quite sure if there are gains on the inlet hose, airflow wise IMO much better than stock hose.
The Following User Says Thank You to qganja For This Useful Post:
Fortis (03-01-2014)
Old 03-01-2014, 02:48 PM   #25
jflogerzi
jflogerzi's Avatar
I did it because it looks better and I could get rid of the noise generator.
The Following User Says Thank You to jflogerzi For This Useful Post:
qganja (03-01-2014)
Old 03-03-2014, 03:01 PM   #26
wu_dot_com
Drives: accord
yesterday ive switched back to AEM cai again for the third time after having 42k miles on my car and counting.
this time, im having everything stock except intake.
the behavior of this cai was the same as my previous experience; its a bit low from 1-3k. stronger from 3-5k and 5-7k are extremely responsive and willing. note: the overall performance is equivalent and marginally improve over stock setup. the difference is where power band shift upward from sub 3 to 4-5k.
the good is that the power delivery through the RPM ranges becomes more linear. rather than the camel hump performance curve like the stock setup, the AEM setup feels smoother and more consistent.
the bad is that you dont get as much useful power on demand during normal street driving. if by habits you shift below around 3k rpm, you will find yourself either changing your habit to shift around 4k or feel the lack of expected power.
just last weekend i did a canyon run with stock setup. since it was raining and flash flood were present at various location. the sudden power drop between 3-4 k got me into trouble a few time. i would like to try again with the AEM intake to see if the flatter power curve helps.
The Following User Says Thank You to wu_dot_com For This Useful Post:
qganja (03-04-2014)
for those who care: ARK DT-S, Perrin Catted Front Pipe, Perrin Overpipe Tylub Engine, Exhaust, Transmission 9 02-01-2014 04:20 AM
FS: Perrin headerback, Injen Intake and Perrin Pulley Boxer-86 Engine, Exhaust, Bolt-Ons 39 10-29-2013 10:32 PM
Anyone keen to swap their Perrin Unresonated mid pipe for a Perrin resonated one? Jigga Australia Classifieds 0 07-07-2013 12:35 AM
perrin pulley perrin intake tube Area51 Engine, Exhaust, Bolt-Ons 4 04-05-2013 06:11 PM
