Old 02-27-2014, 11:27 AM   #1
rhythmM
rhythmM's Avatar
Drives: 2014 Subaru BRZ Limited MT - White
Battery dies, push start car in gear.... push start button
Hey I was wondering if anyone knew if pushing a car and throwing it in gear to start it is possible with a "push button start" car (BRZ Limited). This is of course in the event the battery dies.
Phantom Super Charged - 2014 BRZ
rhythmM is offline   Reply With Quote
Old 02-27-2014, 11:50 AM   #2
jonzhuxD
Drives: Ultramarine FR-S
I don't see why not as long as you had enough juice to get the car to the "on position"
jonzhuxD is offline   Reply With Quote
Old 02-27-2014, 12:08 PM   #3
Pickleahoy
Drives: 10 Series #1617
You would need enough juice left to "turn on" the car by pressing the button twice without holding the clutch down
Pickleahoy is offline   Reply With Quote
Old 02-27-2014, 12:44 PM   #4
rhythmM
rhythmM's Avatar
Okay, and if there is absolutely no more juice... Thats pretty much it right? lol
Old 02-27-2014, 12:57 PM   #5
TrqlessWonder
Drives: 2014 FR-S
Juice..and momentum from the push. I had not thought about this scenario at all. That doesn't actually require a whole lot of electrical juice (once the engine is spinning, it'll provide enough elec through the alternator to go), so it's probably still doable, but I don't think standard good samaritan passers-by will get it done. Handful of football players or need to chance it pointing it down a hill, without power brakes or steering.
Kinda glad I cheaped-out.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 02-27-2014, 03:59 PM   #6
Forty
Drives: Ultramarine
and enough juice to for the fuel pump...
Forty is offline   Reply With Quote
Old 02-27-2014, 06:06 PM   #7
Basket Case
Drives: 2013 Raven fr-s
I honestly don't think you are going to be able to push start a modern car...Needing to run two fuel pumps, high pressure injectors, spark plugs on top of the ignition system...As an example, I have an older Buell that unless you have a full charge on the battery, it will crank just fine, headlight will come on, fuel pump will come one, but it won't fire. The ignition system and injectors pull too much juice and there is no way to push start the bike.
Basket Case is offline   Reply With Quote
BRZ OEM Push Start Button Hachiroku14 Interior Parts (Incl. Lighting) 1 01-07-2014 02:43 AM
Push Button Start z3ro Cosmetic Modification (Interior/Exterior/Lighting) 10 10-29-2013 03:00 PM
Q: push button start frs blanco Electronics | Audio | NAV | Infotainment 8 08-09-2013 04:58 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
TRD push start button nix Australia Classifieds 1 11-27-2012 12:53 AM
