Old 02-27-2014, 10:37 AM   #3669
NickFRS
Drives: 2013 Asphalt FRS
Hey guys. My charger has been making this nice noise once it gets hot. Anyone have this noise?
https://www.facebook.com/photo.php?v...type=2&theater
Sorry for facebook video! ^
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 02-27-2014, 10:48 AM   #3670
evan
Drives: fr-s
Nick, I'd love to listen to the noise but I don't use Facebook and have no login. Are you around this Saturday? I wouldn't mind checking it out in person.
Eat your vegetables..
evan is offline   Reply With Quote
Old 02-27-2014, 12:10 PM   #3671
wrxgoose
WUB WUB
Drives: 2013 Firestorm
Map sensor harness extension that came with the kit is having some issues. The blue wire sensor side isn't locking into the connector body, and voltage is fluctuating.
Sent from my VS840 4G using Tapatalk
wrxgoose is offline   Reply With Quote
Old 02-27-2014, 12:15 PM   #3672
TemeCal
Drives: 86
My stock harness is long enough to not use the extension. I went ahead and installed the extension, just for the extra slack. Can you remove the extension?
TemeCal is offline   Reply With Quote
The Following User Says Thank You to TemeCal For This Useful Post:
sw20kosh (02-27-2014)
Old 02-27-2014, 12:50 PM   #3673
wrxgoose
WUB WUB
nah, needed it for the length.
Old 02-27-2014, 01:50 PM   #3674
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I had to take mine off as the wires were incorrectly wired,
Do a color match end to end to verify ok.
Ryan86 is offline   Reply With Quote
Old 02-27-2014, 02:01 PM   #3675
Ryan86
Road Warrior
Ryan86's Avatar
When last did you check your SC oil? Exact sound mine made and I found no oil in the SC.
The Following User Says Thank You to Ryan86 For This Useful Post:
evan (02-27-2014)
Old 02-27-2014, 02:07 PM   #3676
evan
Drives: fr-s
Good call. I was going to ask him to check the oil but didn't want to jump to conclusions before hearing it.
You found no oil in yours.. Hmmm. Did it not come with oil or do you think it's being lost? I'm not following the 30k mile recommendation and planning to change mine every 10k for insurance. The Redline stuff is relatively cheap.
Old 02-27-2014, 02:56 PM   #3677
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
This would probably be the issue as you all have stated. I have used the Lucas gear oil instead of the Redline if it is not available near you.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 02-27-2014, 04:37 PM   #3678
NickFRS
My last blower was was replaced at 500 miles. This one only has 600 miles on it. If it doesn't have oil i'll be quite shocked.
Prob date night with the wife. Might do C&C though.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 02-27-2014, 04:46 PM   #3679
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
My gear oil was pretty low when I changed it last week. Only have about 2K miles on the sc.
Sent from my SM-N900V using Tapatalk
Area86 is offline   Reply With Quote
Old 02-27-2014, 05:07 PM   #3680
xjohnx
Grip>Slip
xjohnx's Avatar
Mine always seemed low from the factory as well. I used the intercooler install as a good opportunity to drain and replace with the factory specified amount.
Pro-tip - A syringe like this makes measuring out the exact amount of oil specified (157ml if i recall correctly) much easier.
[ame="http://www.amazon.com/EcoPlus-740610-Syringe-100CC-ML/dp/B002JLJDQ0/ref=sr_1_1?ie=UTF8&qid=1393538795&sr=8-1"]Syringe 100CC/ML: Amazon.com: Industrial & Scientific[/ame]
Old 02-27-2014, 05:53 PM   #3681
NickFRS
This makes me all wonder. The first time my blower was replaced Innovate kept asking if the blower had enough oil in it. Wonder if there is something to connect the dots to. I'll check it on Sat. Car is sitting in the garage again......
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 02-27-2014, 06:02 PM   #3682
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by xjohnx View Post
Ready to test for leaks.
Results man, where are the results?
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
