| View Poll Results: Have you had an issue with your Direct Injection System? | |||
| I have had a DI issue and was fixed under warranty (Subaru) |
10 | 12.35% |
| I had a DI issue that caused Engine Failure and was fixed under warranty (Subaru) |
2 | 2.47% |
| I have had a DI issue and was fixed under warranty (Toyota) |
31 | 38.27% |
| I have had a DI issue that caused Engine Failure and was fixed under warranty (Toyota) |
3 | 3.70% |
| I have had a DI issue and denied warranty by (Subaru) |
7 | 8.64% |
| I have had a DI issue and denied warranty by (Toyota) |
14 | 17.28% |
| I had a DI issue that caused Engine Failure and was Denied warranty (Subaru) |
8 | 9.88% |
| I had a DI issue that caused Engine Failure and was Denied warranty (Toyota) |
6 | 7.41% |
| Voters: 81. You may not vote on this poll | |||
#463 |
Drives: BRZ, STI, 535, Tiffin Allegro
My cylinder one DI seal failed after tracking my car for a year.
I paid a 3rd party mechanic to replace all four seals, updated my ECU with the Toyota fix, added an oil cooler, and replaced my coils with Okadas. After a second year of tracking I had my injectors pulled this week and all four were still good. |
#464 |
Drives: '13 FRS - STX
Did the mechanic do the flash or dealership?
I'm trying to get the courage to go to the dealership and fight for the tune, mine doesn't do the rpm drop anymore so the TSB technically doesn't apply to me... |
#465 |
| The Following User Says Thank You to romin For This Useful Post: | strat61caster (02-03-2014) |
#466 |
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
What's the warranty on the DI issue? Is it 5yrs/60,000 mile, or 3yr/36,000 mile?
I'm coming up on 2 years of ownership this June but only have 5,500 miles on my car. Dealer did a reflash last summer but I'm not sure for what. I haven't experienced anything people have mentioned in this thread but sometimes get a very brief idle dip. I normally shift by 5000 rpm but have taken it past 6000 from time to time. Never tracked, tuned, or modded in any way. |
#467 | |
Drives: Moped
#468 |
so after reading all of this... looks like I may have this same issue - Car is with dealership right now and they are basically looking at the injection system... Car basically got a warning light then traction control light went on... then started having idle issue... This is really sad but good thing is I am still under power train warranty...
Founder / Writer - MicroCarMag
Driver / Builder Project Chimera - https://www.facebook.com/MCMProjectChimera Check out my sponsors: D2BD Motorwerks / Bavaria / Nutek Wheels / Continental Tire |
#469 |
Drives: Honda
Is this DI issue only affecting earlier 2013 cars or is this unresolved and continues to affect 2014 cars as well?
#470 |
Drives: Supra, BRZ
^ x2
In for this info as well if someone has had this with their 2014.
1997 Toyota Supra TT 6MT - RR
2014 Subaru BRZ Limited 6MT - WRB |
#471 |
Drives: white premium brz M/T
I purchased the 700cc fuel injectors with my turbo kit and wondering if it replaces OEM DIs?
#473 |
Ah I see. So they are two different things?
#474 |
Drives: Toyota
Just a question, does this problem only affect manual transmission cars?
#475 | |
Drives: 13 BRZ SSM
| The Following User Says Thank You to turbocat For This Useful Post: | bjun (02-27-2014) |
#476 |
So is anyone using aftermarket DIs?
| Tags |
| direct injector, engine, failure, meet regal's paranoia, poll, regal's witch hunt, regalnoia, seal, sealions, silly sausage |
| Injector / seal failure or Miss-fire codes.. please post here | mad_sb | Engine, Exhaust, Transmission | 378 | 04-24-2020 06:33 PM |
| Direct Injector Leaking | Carwhisperer | Issues | Warranty | Recalls / TSB | 356 | 03-13-2020 12:35 PM |
| Fuel Injector Cleaner | Purdue FR-S | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-18-2013 06:54 AM |
| Wilwood Failure | SubieNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 46 | 04-09-2013 08:32 PM |
| Ringland Failure? | iLuveKetchup | BRZ First-Gen (2012+) — General Topics | 9 | 01-30-2012 12:25 PM |
