coolant leak or burned rubber smell
Hi there,
2013 FR-S 15,000kms had already done the oil plate twice and also done passenger side valve cover sealant once. In the same time frame since December 2013 experiencing odd smells, but what prevails is sweet taste in mouth right after sometimes 5mins up to 1 hour of driving. Have faint and thin oily film on windshield and side windows. Been to couple of different dealers a few times to no fault found and kicked out every time. Last night at -7C upped heater and car started to fog up with the halo around bright lights, even heater on full blast, it was getting worse and of course with sweet after taste in mouth. Any one experienced anything similar.. Any info or how to get Toyota to acknowledge its FUBAR and fix it once for all, would be fantastically appreciated ! |
#2 |
Drives: 2013 FR-S whiteout
Are you by any chance eating candy?
Losing coolant? Bad heater core? Any dampness on floor? |
#3 |
Sounds like heater core has a leak........
#4 |
Drives: Fast
Yep what he said.
Coolant leak at heater core. |
#5 | |
- Coolant in minimum lever mark - Toyota won't touch the car unless "obvious" causes appear. (No visible leaks, no coolant smell, had already 3 techs in my car, NONE noticed anything !!!) |
#6 |
#7 |
Drives: 2014 BRZ SWP LTD
Your all wrong. It's probably just the heater core.
#8 |
You might try some "stop leak"; but if you do, make sure it's compatable with the "blue stuff" coolant.
humfrz |
| OEM parts? Burned rubber door/window sill | l0aded | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 04-08-2017 07:32 PM |
| Rubber smell sometimes on cold start | jonbonazza | Issues | Warranty | Recalls / TSB | 9 | 12-04-2013 05:32 PM |
| Burnt Rubber smell | Fizzle | Issues | Warranty | Recalls / TSB | 22 | 01-06-2013 09:10 PM |
| Anyone else smell rubber? | pinoyplaya | BRZ First-Gen (2012+) — General Topics | 15 | 09-24-2012 03:40 AM |
| Has the seatbelt 'burned' you yet? | Rob_g | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 07-17-2012 02:01 PM |
