#323 |
Drives: Raven FR-S MT
Lovin' the Whitelines poking out back there. That "diffuser" delete along with the lack of muffler just shows off the colors.
2013 Scion FR-S - Build Thread
2015 Ford Mustang GT 1978 Triumph Spitfire 1500 ---------------------------------------------- ![]() |
#324 |
Drives: 2013 Raven Scion FR-S
| The Following User Says Thank You to phastafrican For This Useful Post: | Anthony (02-24-2014) |
#325 |
Car looks seriously good!
#326 |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
The more pictures you post of that rear, the more I like it. I wish you had some sexy real diffuser back there that worked with the new contours and eliminated the lift/added downforce.
| The Following User Says Thank You to Luckrider For This Useful Post: | Anthony (02-25-2014) |
#327 |
Wayward Member
Drives: Hot Lava 86
I'm surprised by how much I like the look of the rear of your car missing the diffuser. I like being able to see all of the aftermarket parts. Looks very purpose built, but not like it's actually missing anything.
#328 | |
Drives: DGMBRZ
Weight Name Price 13.4 SSR Type-C 17x7.5 +35 2,575 14.3 SSR Type-C 17x8 +38 2,575 14.9 TC105n 17x8.0 +42 5x100 1,600 15.0 Volk CE28n 17x9 +38 15lbs 2,500 15.4 ADVAN RS 17x8 +37mm 5x100, Sliver 2,400 15.5 O.Z. Alleggerita HLT SE 17x8 +48 15.45lbs 1,436 15.5 Kosei K1TS 17x8 15.5lbs +45mm 916 15.5 Volks TE37 Seibon 17x8 +44 2,200 15.7 O.Z. Alleggerita HLT 17x8 +48 15.7lbs 1,316 15.8 Kosei K4R 17x8 +36 15.8lbs 796 15.8 TC105n 17x9.0 +42 5x100 15lbs 1,699 15.8 ADVAN RS 17x8.5 +48mm 5x100, Dark Gun Metal 1,800 16.0 Enkei RPF1 17x8 +35 16lbs 972 16.0 Volks TE37V 17x8 +44 2,885 16.1 Enkei RPF1 17x8 SBC, +35, 16.1lbs 1,240 16.1 TC105n 18x8.0 +42 5x100 1,799 16.4 SSR GTV02 17x8 +45 5x100 1,360 16.5 Enkei RPF1 17x9 +35 16.5lbs 1,240 16.5 Advan Tcii 17x8.5 1,540 16.8 Enkei RSM9 17x8 +35 16.83 lbs. 1,600 17.0 TC105n 18x8.5 +42 5x100 1,800 17.1 Enkei Fujin 17x7.5 +40 17.1lbs 720 17.1 Rota Titans 17x8, 35mm 899 17.1 Volks TE37V 17x9 +36 2,885 17.2 Konig feathers 17x7.5+45 17.2lbs 576 17.2 Volks TE37V 17x9 +36 2,000 17.4 O.Z. Ultraleggera 17x8 +48 17.4lbs 1,140 17.5 Neuspeed Rse05 17x8, 44mm 1,076 17.5 Advan RSII 18X8.5 et35 2,400 17.6 Enkei RPF1 18x8 1,000 17.8 Mach V Awesome 17x8 +42 17.8lbs 1,316 17.8 Neuspeed RS10 18x8 17.8lbs 2,160 18.3 Enkei rs05rr 18x8.5 +42 5x100 2,160 18.7 Rota SVN 17x8 +48 849 19.0 Yoshihara 18x8 +40mm 5x100 700 |
#329 | |
Great job putting this together...
...although I have a set of 17x8 rpf1s and they are 15.6lbs. K4Rs are also 15.6 from a friend who has them. Personally, I was tempted to go with Kosei K4R or K1ts in 17x7 at 14lbs when I thought I would stay at 225s max;however, I'll be running 235 toyos or 245 hoosier r6s, so that forces me to 17x8. Quote:
#330 |
Drives: 2013 Raven
Wow. That diffuser delete looks fantastic with the Tomei exhaust.
What did you do with the reverse light? |
| The Following User Says Thank You to N_A For This Useful Post: | Anthony (02-25-2014) |
#331 | |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Hey, thanks a lot! I'm considering going with some Wilwood brakes that are compatible with 15" wheels. Even if I do that, your list will be a huge help in beginning researching the best wheels for that situation. I'm amazed there are 17's in the sub 14lb range. Good stuff! Thanks! And... nothing. I just don't have a reverse light.
#332 | |
Fat on Corn Syrup
Thank you thank you thank you thank you thank you This is exactly what I've been looking for! Sent from a secret volcano base using trained sharks |
#333 | |
Drives: 2021 Toyota Supra 2020 4Runner
Look up 949Racing 6UL Wheels. Specifically made to accept the 11.75" Willwood Big Brake Kit. Check em out...great wheels...had them on my S/C AW-11 |
| The Following 2 Users Say Thank You to Atropine For This Useful Post: | Anthony (02-25-2014), phastafrican (02-25-2014) |
#334 |
Weight Nazi
@diss7, did you ever settle on a set of brakes?
#335 |
Fat on Corn Syrup
is there a good way to drop an excel spreadsheet into the forum?
I took @Flow 's information (which is awesome!) and added a link to an image for each rim and tried to verify the other info. I figured if it was in excel, people could sort by what's most important to them, weight, size, price... |
#336 | |
Drives: DGMBRZ
| Tags |
| mother fu(king winning! |
