Old 02-25-2014, 11:03 PM   #99
HSayaovong
HSayaovong's Avatar
Drives: blk;2dr;rwd;fun
Originally Posted by DriftHappens View Post
Which is heavier, a ton of bricks, or a ton of feathers?
seriously? look at the boost chart for sc then compare it with turbo .. amount of time in full boost is like .5krpm for a supercharger while for a turbo max boost runs from 3.5k to redline.. and you seriously think a supercharger is equivalent to a turbo? wow..
i'm sure you believe that drifting is also faster around corners then grip
anywho, sry for hijacking the thread.. I"M DONE.. O_~.. hope to hear an awesome price tag on your vortech system soon ..
Life is like taking a dump, sometimes it's easy and other times its hard. But it always stinks
HSayaovong is offline   Reply With Quote
Old 02-25-2014, 11:06 PM   #100
Sniper2606
Sniper2606's Avatar
Jesus shit, take this somewhere else.
Read the Title.
OpenFlash Tablet and Vortech Supercharger
Sniper2606 is offline   Reply With Quote
The Following 2 Users Say Thank You to Sniper2606 For This Useful Post:
HSayaovong (02-25-2014), raven1231 (02-26-2014)
Old 02-25-2014, 11:09 PM   #101
jamesm
it's called area under the curve. imagine if we compared average hp over the course of a pull as opposed to grabbing one data point from the top and comparing things that way (seems kinda stupid when you put it that way, doesn't it?). the turbo would positively destroy any centrifugal s/c. it's due to the fact that the compressor on a turbocharger is not mechanically linked to the crankshaft, and can increase rpm independent of engine rpm, thus producing full boost much sooner than the centrigual s/c. i think that's what he's getting at, and i'm pretty sure 99% of the people here already understand that. so really he's just trolling you.
but boost is boost, it's all better than being as slow as an na 86. i wouldn't buy a centrifugal given the available options, but i can see why some do.
The Following User Says Thank You to jamesm For This Useful Post:
Old 02-25-2014, 11:28 PM   #102
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I too was anti-centrifugal SC for the last 20 years when we focused on nothing but 20+psi turbo engines. This application got me to change my mind and match compressor type to the kind of car and how it is driven. In the case of our twins, I'd say that a well tuned centrifugal SC makes more for a more fun, more controller driver's car than a equally powered turbo. I've been defending turbos for decades but have now realized that there truly are different strokes for different applications. It all depends on what you are going for. Turbos do things very well. But some things very poorly. The centrifugal SC doesn't do anything poorly and many things really well. In a small lightweight RWD car that steers with the throttle as effectively as the steering wheel, having predictable/progressive torque output that can be easily modulated by the throttle is key for drivers. For drag racers, maybe not so much.
Then again, this thread isn't a turbo vs SC thread.
Shiv@Openflash is offline   Reply With Quote
The Following 9 Users Say Thank You to Shiv@Openflash For This Useful Post:
DAEMANO (02-26-2014), JEFFSTYLE (02-28-2014), JS + BRZ (02-26-2014), Mad1723 (02-26-2014), normancw (02-26-2014), raven1231 (02-26-2014), Sniper2606 (02-26-2014), toysub (02-26-2014), Yobiwan (02-26-2014)
Old 02-25-2014, 11:30 PM   #103
Sniper2606
Sniper2606's Avatar
Originally Posted by shiv@vishnu View Post
I too was anti-centrifugal SC for the last 20 years when we focused on nothing but 20+psi turbo engines. This application got me to change my mind and match compressor type to how the car is driven. In the case of our twins, I'd say that a well tuned centrifugal SC makes more for a more fun, more controller driver's car than a equally powered turbo. I've been defending turbos for decades but have now realized that there truly are different strokes for different folks. It all depends on what you are going for. Turbos do things very well. But some things very poorly. The centrifugal SC doesn't do anything poorly and many things really well.
Can you please answer my PM.
Trying to buy the OFT
Thanks
Old 02-25-2014, 11:33 PM   #104
Shiv@Openflash
Drives: 2013 FRS
Thanks
I forwarded it to the sales department so expect an answer tomorrow morning when the office opens
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Old 02-26-2014, 08:46 AM   #105
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Originally Posted by germgerm View Post
Is this gonna come with a e85 tune as well? Or are we gonna need to run bigger injectors for that ?
@shiv@vishnu, do you have an answer for this or do you need to do more testing to find the answer?
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
Old 02-26-2014, 08:59 AM   #106
raven1231
Read the Title.
This. IF you want something else or dont like this setup then why are you even responding in this thread.
Old 02-26-2014, 02:08 PM   #107
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
Woot woot
I just bought @nelsmar supercharger
cjsporl1996 is offline   Reply With Quote
Old 02-26-2014, 03:42 PM   #108
Shiv@Openflash
Drives: 2013 FRS
So lets say you have the following
Vortech on 91 gas
Revworks UEL headers
Motiv Overpipe
Invidia test pipe
Invidia Q300
And crappy ECUtek
What will be the benefits of jumping boats to this Openflash tablet.
Unfortunately i havent Dyno my setup but i hate Ecutek and especially John Visconti he lacks people skills and good attitude and i had enough.
Thank you for your order! Make sure you flash your ECU with an Ecutek "stock" file. You will have to get that from your previous tuner. After that, you're good to go
Old 02-26-2014, 03:44 PM   #109
Sniper2606
Sniper2606's Avatar
Yeah unfortunately my previous jackass tuner was/is Visconti and he suspended my account because i told him what he deserved, now i dont have the stock map..... what to do now? where can i get the stock map for ecutek
Old 02-26-2014, 03:51 PM   #110
ShadowSeraph
Tech Master / Car Geek
ShadowSeraph's Avatar
Drives: 2013 AT Hot Lava FR-S
OFT + Vortech + upcomming FBM intake manifold + possible MAP throttle body... oh gawd... i need more $
Perrin: Crank pulley, 3" Cat back, Nameless: 3" FP/OP
GFB: water and alternator pulleys
Borla: UEL Header
Hyper Black ROTA T2R 18x9.5, DSS CF Shaft for AT
-= OFT - Stage 2 UEL E85 - fine tuned by me. =-
ShadowSeraph is offline   Reply With Quote
Old 02-26-2014, 03:59 PM   #111
Foobar
SLO NO MO
Foobar's Avatar
Try contacting @EcuTek or maybe some other ECUTek user can provide it from the set of base ROMs they now have access to.
Old 02-26-2014, 04:00 PM   #112
Shiv@Openflash
Drives: 2013 FRS
+1
Contact Ecutek UK and they should be able to help you.
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
FS: Openflash Tablet Sgt.Beardface Engine, Exhaust, Bolt-Ons 8 01-04-2014 11:12 AM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 12:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 09:05 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
