Old 02-26-2014, 02:39 PM   #1
Saf
coolant leak or burned rubber smell
Hi there,
2013 FR-S 15,000kms had already done the oil plate twice and also done passenger side valve cover sealant once.
In the same time frame since December 2013 experiencing odd smells, but what prevails is sweet taste in mouth right after sometimes 5mins up to 1 hour of driving. Have faint and thin oily film on windshield and side windows.
Been to couple of different dealers a few times to no fault found and kicked out every time.
Last night at -7C upped heater and car started to fog up with the halo around bright lights, even heater on full blast, it was getting worse and of course with sweet after taste in mouth. Any one experienced anything similar..
Any info or how to get Toyota to acknowledge its FUBAR and fix it once for all, would be fantastically appreciated !
Saf is offline   Reply With Quote
Old 02-26-2014, 02:45 PM   #2
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Are you by any chance eating candy?
Losing coolant?
Bad heater core?
Any dampness on floor?
Old 02-26-2014, 03:12 PM   #3
White64Goat
Sounds like heater core has a leak........
Old 02-26-2014, 03:40 PM   #4
Razz
Razz's Avatar
Drives: Fast
Yep what he said.
Coolant leak at heater core.
Razz is offline   Reply With Quote
Old 02-26-2014, 10:40 PM   #5
Saf
Losing coolant?
Bad heater core?
- Coolant in minimum lever mark
- Toyota won't touch the car unless "obvious" causes appear.
(No visible leaks, no coolant smell, had already 3 techs in my car, NONE noticed anything !!!)
Old 02-26-2014, 10:41 PM   #6
Saf
Originally Posted by Razz View Post
Yep what he said.
that is what I am arguing, but if they don't see it, they will not touch it
Old 02-26-2014, 11:17 PM   #7
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Your all wrong. It's probably just the heater core.
Old 02-27-2014, 02:33 AM   #8
You might try some "stop leak"; but if you do, make sure it's compatable with the "blue stuff" coolant.
OEM parts? Burned rubber door/window sill l0aded Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 04-08-2017 08:32 PM
Rubber smell sometimes on cold start jonbonazza Issues | Warranty | Recalls / TSB 9 12-04-2013 06:32 PM
Burnt Rubber smell Fizzle Issues | Warranty | Recalls / TSB 22 01-06-2013 10:10 PM
Anyone else smell rubber? pinoyplaya BRZ First-Gen (2012+) — General Topics 15 09-24-2012 04:40 AM
Has the seatbelt 'burned' you yet? Rob_g Scion FR-S / Toyota 86 GT86 General Forum 22 07-17-2012 03:01 PM
