Old 02-25-2014, 11:07 PM   #29
JR007
JR007's Avatar
Drives: Ultramarine FR-S
^^ thanks for the info.
JR007 is offline   Reply With Quote
Old 02-25-2014, 11:48 PM   #30
mfbmike
Drives: 2013 FRS, 2008 R32
That video right there, those practices - is why I support Grimmspeed.
You guys fucking rock.
mfbmike is offline   Reply With Quote
Old 02-26-2014, 10:31 AM   #31
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
No problem folks, I was getting worried you weren't going to see this post.
Also, thank you, that's appreciated! I must say that I would tend to agree with you
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to GrimmSpeed For This Useful Post:
JR007 (02-26-2014), SkAsphalt (02-26-2014)
Old 02-26-2014, 10:56 AM   #32
OrbitalEllipses
Drives: Attitude
If you haven't done it already - step on the brakes HARD. The bottom portion of pedal travel should feel markedly different.
Old 02-26-2014, 11:01 AM   #33
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Exactly this. The last 25% or so is much different
Old 02-26-2014, 03:41 PM   #34
Thongpocket
Master Troll
Thongpocket's Avatar
Drives: 2013 BRZ Limited
I just did my first autoX and I could definitely tell it was working. Lol
Sent from my XT1080 using Tapatalk
Thongpocket is offline   Reply With Quote
Old 02-26-2014, 04:35 PM   #35
JR007
JR007's Avatar
Chase
Engineering
Chase, I did want to ask you a question. So, I have an AT and have been told and seen proof from others that I'll need to relocated a bracket and harness. Do you have any suggestions besides removing the bracket and tie-wrapping the harness to another one for the part to fit properly? Is there anything in the works for an updated part for an AT FR-S? If so, I'd be happy to test it for you guys.
Thoughts?
Thank you!
Old 02-26-2014, 09:54 PM   #36
Seattle944t
Drives: Sc10n
Thoughts?
Thank you!
I have an AT and installed the Perrin MC brace. There isn't a bracket that needs relocating, but the AT control wiring harness has some retention straps that run through there with a mount. Just zip tie the harness wiring (it's a wire routing loom) to the MC brace and you are fine.
And for me it was a night and day difference - the "dead zone" on the pedal before braking is applied is reduced to about 1mm of pedal travel vs. about 3mm w/o the brace. This is on any brake force, even light pressure. Probably the best "feel" mod I have done on any car. The brace on my STi didn't have nearly the same effect, and the brakes on the STi with stainless lines feel positively spongy compared to my FR-S.
Seattle944t is offline   Reply With Quote
The Following User Says Thank You to Seattle944t For This Useful Post:
JR007 (02-27-2014)
Old 02-27-2014, 09:34 AM   #37
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
What class are you running? If you ran with the SCCA, the MCB is either illegal to use or should bump you into some mod class. jw
Propaganda is offline   Reply With Quote
Old 02-27-2014, 11:05 AM   #38
GrimmSpeed
GrimmSpeed's Avatar
Thoughts?
Thank you!
We don't really have a different solution for AT owners in the works. We recommend zip tieing the harness to the MCB (or something else chassis mounted), or if you can find a place to relocate the retention strap. It should also be possible to ziptie the retention strap itself to the MCB, or drill a hole in it, and add a bolt to the retention strap. It's alright to get creative here, but at the same time it might be alright to leave it out all together.
Chase
Engineering
The Following User Says Thank You to GrimmSpeed For This Useful Post:
JR007 (02-27-2014)
WTB Master Cyl Brace SpectreRT Want-To-Buy Requests 0 11-22-2013 04:00 PM
Master brake cylinder brace Ryan86 AFRICA 42 02-10-2013 02:47 AM
BRZ/FR-S master cylinder brace - $60 Turn in Concepts Brakes, Suspension, Chassis 35 01-26-2013 12:17 PM
Perrin master cylinder brace SubaSteve Brakes, Suspension, Chassis 9 01-11-2013 10:46 PM
What can I use to make sure strut bar doesn't scratch paint? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 10-16-2012 12:16 PM
