#29 |
Drives: 2013 Whiteout Scion FR-S
the new corvette is pretty close... starts at $51k, curb weight is a bit higher at 3300 but its got the power to start and has room for more, looks great, and has RWD
#30 | |
Drives: Turbo BRZ & Supercharged E90 M3
Besides it's over 500lbs weight difference and that's a base model vette. If you start with an FRS it would be less. Anyways, it's the fun factor of a having a custom build which isn't easy.
#31 | |
Drives: 2014 Scion FRS MT
| The Following User Says Thank You to Moe23 For This Useful Post: | canu_50 (03-04-2014) |
#32 | |||
TURBOLICIOUS
Drives: a machine :]
![]() Quote:
#33 | ||
Trust me, I'm the Doctor
Also, OP, I take it you've also sourced the transmission as well? Quote:
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#34 | |
Boosted
Drives: Not a supra....yet
Full interior, Ac , all electronics working and also abs/ traction Sent from my IBrick
| The Following 3 Users Say Thank You to SmsAlSuwaidi For This Useful Post: |
#35 |
Not bad. Still unbalances more than stock (stock distribution is closer to 53/47, iirc), but that's not too bad.
I guess if you get too much front dive, you can put in stiffer springs, or if you begin to lose the rear traction at higher power and speeds, you can always add aero to plant its ass back down onto the road .
| The Following User Says Thank You to SirBrass For This Useful Post: | SmsAlSuwaidi (02-25-2014) |
#36 |
Drives: Attitude
#37 | ||
TURBOLICIOUS
| The Following User Says Thank You to Drift&Drag For This Useful Post: | SmsAlSuwaidi (03-03-2014) |
#38 | |
#40 | |
| The Following User Says Thank You to h4nh For This Useful Post: | Drift&Drag (03-03-2014) |
#41 |
Drives: 2013 Raven Black FR-S
In for updates guys I love the idea. I have a 2j mk3 supra I've debated on swapping to the frs.
-Raven Black 13 FR-S : The daily driver
-88 supra turbo : 2jz 66mm single on E85 in the process ![]() |
#42 | |
Drives: '13 Ultramarine FR-S M/T
I imagine that swapping an aluminum V8 would net better weight distribution than any inline 6 in the FR-S/BR-Z. weight distribution would probably come in real close to stock with the aluminium V8 while adding a straight 6 of any kind will throw weight way out towards the front. My guess is the split would come to 54.5F/45.5R ish. Oh and also for a jack of all trades like you said you want a V8 would probably be better anyway. they typically have better torque curves for multipurpose setups. 500-600hp 2jz might have a bit more turbo lag than you would want for something like autox unless you go with a sequential setup which i dont know if you could fit that in the twins engine bay. would be sweet though haha Dont get me wrong though. I dig the idea of a 2jz swap . they make a ton of power and i dig straight 6's thanks to my love for S30 Z's. Good luck with the swap.
| The Following User Says Thank You to Sypher For This Useful Post: | SirBrass (03-03-2014) |
| What's happening at TF-Works... | Touge Factory | Great Lakes | 93 | 04-24-2015 01:44 PM |
| What's happening in August? | jimmillion | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 06-01-2013 11:22 PM |
| What's Happening this Weekend? (Nov 1st-4th) | TyperRspec789 | Mid-Atlantic | 27 | 11-02-2012 11:11 PM |
| well, its finally happening... | carbonBLUE | Scion FR-S / Toyota 86 GT86 General Forum | 46 | 10-16-2012 07:39 AM |
| any UT happening? | Celica00 | Southwest | 6 | 09-11-2012 10:03 AM |
