Old 02-07-2014, 10:55 AM   #57
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
Originally Posted by andrew20195 View Post
FYI, Subaru updated their version of this TSB with new part numbers as of 1/28/14.
Unfortunately, this appears to be a "safety" feature built in to the window indexing. There is a note about it in your owner's manual. However, with this fix, it looks like they reduced the distance the window drops, so it should seal better when it's frozen.
Do you have a link to it? Or can you attach it to a post in this thread?
My dealership is much more susceptible to doing the work if I hand them the TSB since otherwise they can never find them on their own
If you're a Subaru tech or have log in info to the Subaru Information System here is the link: http://techinfo.subaru.com/proxy/752...-07-79-13R.pdf
Parent Site where the TSB is listed: http://techinfo.subaru.com/static/whatsNew.html
doesn't really do any of us any good lol
EvilBeaverFace is offline   Reply With Quote
Old 02-07-2014, 02:10 PM   #58
andrew20195
Drives: 2013 Subaru BRZ
In their defense, Subaru's search engine sucks. The bulletin is on the "What's New" page on STIS, they should be able to find it easily enough for at least the next month. And the correct bulletin number was posted above. If you bring that to them they should be able to look it up by number.
andrew20195 is offline   Reply With Quote
Old 02-07-2014, 02:28 PM   #59
EvilBeaverFace
the whats new page was my 2nd link
my 1st link was to the correct bulletin, I just can't log in because I don't work there. Thanks though for your input. I don't think that's why they tend to turn me away though, lol.
Old 02-07-2014, 02:29 PM   #60
HeubergerMotors
HeubergerMotors's Avatar
Drives: 2006 WRX TR
Location: 1080 Motor City Drive , Colorado Springs 80905
Thanks for share.
HeubergerMotors is offline   Reply With Quote
Old 02-08-2014, 12:37 AM   #61
EvilBeaverFace
Originally Posted by HeubergerMotors View Post
Thanks for share.
If that was pointed at me, I didn't actually share anything... until now.
I got a local guy who has access to send it to me, so here is the TSB for Subaru:
@Sigh-on-Rice
The Following 4 Users Say Thank You to EvilBeaverFace For This Useful Post:
FLYFISHR (02-08-2014), Kimsey47 (02-10-2014), Muskokan (02-28-2014), Sigh-on-Rice (02-10-2014)
Old 02-10-2014, 12:37 PM   #62
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
@Sigh-on-Rice
Thanks. I just added it to the TSB thread.
The Following User Says Thank You to Sigh-on-Rice For This Useful Post:
EvilBeaverFace (02-10-2014)
Old 02-10-2014, 07:12 PM   #63
navanodd
Drives: 2013 BRZ Sport-tech WRB
This fix has been great for me. Much less moisture freezing inside of the car (still some as my commute is too short to really allow the dehumidifier to work or any snow in the car to melt). Windows aren't going into failsafe mode and getting stuck open/closed.
navanodd is offline   Reply With Quote
Old 02-11-2014, 12:44 PM   #64
rxpx2012
Drives: FR-S Manual
I called today to have them order the parts for the window fix. Unfortunately they need to see it themselves since its warranty work they are claiming. So hopefully they freeze up for me soon.
rxpx2012 is offline   Reply With Quote
Old 02-19-2014, 01:34 PM   #65
jermyzy
Drives: 2013 WRB BRZ Sport-Tech 6MT
Anybody what's involved in testing for defect? I'm bringing in my BRZ to get the taillights replaced due to condensation. I've had the window freezing happen in the past, they said they'll take a look at it when I get the taillights replaced, but temperatures here in Vancouver have already warmed up, so it won't be freezing by then.
jermyzy is offline   Reply With Quote
Old 02-19-2014, 07:51 PM   #66
Gunman
Drives: 2019 Mazda Miata RF
I talked to my dealer last friday, and they have the parts on order to fix mine. No word yet on when they will get them.
Thanks for the TSB.
Old 02-25-2014, 11:08 AM   #67
andrew20195
If they're being sticklers about it since it's under warranty, don't reset the indexing when it acts up so you can show them that they aren't working. Personally, if a car comes in with that concern, there's no history of the repair, and the vehicle falls within the VIN range indicated by the bulletin, I perform the repair. Especially if it's caused by a temperature issue that is not present on the day the customer brings it in.
The Following User Says Thank You to andrew20195 For This Useful Post:
jermyzy (03-02-2014)
Old 02-26-2014, 06:14 PM   #68
n0thing
Drives: Subaru BRZ
doesn't make sense for them not to perform the tsb repair if the vehicle falls within the vin range. it's basically free work for the tech/advisor/customer, unless they are super busy or the advisor isn't aware of the tsb.
n0thing is offline   Reply With Quote
Old 03-03-2014, 09:46 AM   #69
Muskokan
Drives: white Sport-tech
Ugh anybody in canada get anything done about their windows?
My weather stripping got destroyed, big scratches down the length of the window, nasty sound when it's wet because it's dragging rubber down.
So I was pumped when I saw there was a tsb for this, take it in, they can't find it. Fair enough considering they couldn't find anything to do with the fuel pump also.
So I go back with the tsb #, " that's American, means nothing to us". Well damn.
So now I got a message saying yea they have finally indeed found the Canadian tsb, aaaaaand my car isn't in the vin# range.
What are my options? All weather stripping is gone on drivers side, most on passenger, they do the freeze mode when it gets cold, I've got all the problems on the tsb but for whatever damn reason I'm not in the vin range, what gives and what would you guys do?
Muskokan is offline   Reply With Quote
Old 03-03-2014, 09:49 AM   #70
Muskokan
Originally Posted by tinma View Post
dont have the link to the TSB but the TSB # is 07-79-13
I actually gave that # to my dealership and now my car is going in for it tomorrow to be replaced.
That's the number I gave my dealership and it masewell of been directions to Timmies, what dealer did you go to?
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 02:14 PM
Windows freezing in the winter. Garstang CANADA 26 11-15-2013 10:14 AM
Windows freezing in the winter. Garstang Scion FR-S / Toyota 86 GT86 General Forum 9 10-23-2013 07:07 PM
summer or all-season tires? freezing temps? rainmonkey Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 04-07-2013 01:11 PM
Windows freezing? L3P47 Scion FR-S / Toyota 86 GT86 General Forum 11 12-22-2012 12:49 PM
