CANADA Canada
Old 03-09-2013, 10:23 PM   #71
MattM232
MattM232's Avatar
Drives: 2013 Scion FR-S Firestorm AT
I've had several issues with my windows as well. The drivers side window often does not go back up after the door is closed (after the automatic drop), and I continuously lose control of the passenger window from the drivers' side controls.
The issues stop after I do the reset with the switches, but keep coming back after about a week.
MattM232 is offline   Reply With Quote
Old 10-25-2013, 06:27 AM   #72
Muskokan
Drives: white Sport-tech
I to would like to join the shitty window club.
not the coldest day yet, but had frozen condensation on my window and it mucked it up...
how many engineers does it take to design a window?
Muskokan is offline   Reply With Quote
Old 10-25-2013, 02:26 PM   #73
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Just last night I got a buddy that's new to the BRZ game text me about his window, so I said, "Can I call you?" Then I proceeded to explain the process to him. I let him know he's going to get good at doing it quickly.
The only time it wouldn't happen to me is if I washed the car and brought it directly to my job's warehouse to completely dry out.
Old 10-30-2013, 03:15 PM   #74
Rossman
Rossman's Avatar
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
Originally Posted by techsmitty View Post
My car has developed a window issue. The passenger side window will not return to the fully up position when the door is closed. The window will roll down correctly on door open and the passenger side door switch works. What doesn't work is the driver side switch for the passenger window. The replacement for the "master switch" is on order through Subaru Canada but it has no ETA yet. Anybody else waiting on parts?
Uh, dude, you don't need any parts to fix this, you just put the window all the way down, and keep pressing down for 3-5 seconds after the window is completely down, then put it back up and keep holding up for 3-5 seconds, if that's whats going on.
Rossman is offline   Reply With Quote
The Following User Says Thank You to Rossman For This Useful Post:
chanomatik (10-31-2013)
Old 02-24-2014, 06:35 PM   #75
adan
Drives: Asphalt Scion FR-S 2013
God dammit. I actually went to the dealership to have the window issue fixed only to find out now that I could have just reset it myself. FML. The mechanic told me it's not under warranty so I have to pay for an hour's work which comes out to $100. How the hell did it take him 1 hour to reset the window? GTFO here. This is bull. I looked up this issue in this forum about a month ago but I couldn't find this thread. I should have looked harder. Dammit. Expensive lesson for me.
adan is offline   Reply With Quote
Old 02-24-2014, 08:02 PM   #76
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Mechanic charged you $100, pocketed the money himself, filed paper to Subaru to cover under warranty, reset the window in 5 seconds, went out to buy cigarettes, had a one hour smoke break, hand over the car to you. Mechanic win.
chenshuo is offline   Reply With Quote
Old 02-25-2014, 10:17 AM   #77
Kfresh23
Kfresh23's Avatar
Drives: 2013 WRB Subaru BRZ
That sucks! Note to everyone (including myself) ALWAYS CHECK THE OWNERS MANUAL It explains how to deal with SOME issues, including the window reset.
Kfresh23 is offline   Reply With Quote
Old 02-25-2014, 01:01 PM   #78
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
I know this doesn't solve the problem but what I have done as an ounce of prevention, is if there is a chance of it freezing when I wash the car is to have a roll of clear hockey tape that I use to cover the felt strip to stop it from getting soaking wet. After I have rinsed it down I just pull the tape off the window glass and throw it a way. What I missed with the wash is easily cleaned up with a damp miro towel.
Old enough to know better but young enough to do it again
FLYFISHR is online now   Reply With Quote
Old 02-25-2014, 01:29 PM   #79
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Bumper to bumper warranty should have covered it. You can call Subaru Canada to file a compliant and get your $100 bucks back like I did when the Willowdale Subaru failed to give me proper user manuals for the car, and I spent $102 bucks on eBay to get them (Subaru Canada actually gave me only $94 bucks back I'm not sure why they have to short change me $7 bucks but whatever).
krayzie is offline   Reply With Quote
Old 03-07-2014, 10:56 AM   #80
adan
Yeah, so I got pretty lucky in the end cuz I found the TSB and brought it to the mechanic's attention the next day (my car had to stay overnight since it was the end of the day). What annoys me though is that when I mentioned it to him, it sounded like he already knew about it yet initially wanted to screw me over and charge me the $100. What garbage. Whatever, no more window issues at least.
Old 03-07-2014, 09:57 PM   #81
Coach Hines
Drives: 2013 Scion FR-S Ultramarine MT
I know if a simple fix but I'm throwing up a disclaimer that you guys won't like my fix.....
Store the car for the winter and you won't have this problem
Coach Hines is offline   Reply With Quote
Old 03-21-2014, 12:33 PM   #82
jermyzy
Drives: 2013 WRB BRZ Sport-Tech 6MT
Brought my BRZ in to get a leaking taillight gasket fixed. Showed them the American TSB for freezing windows, and they've ordered in the parts for it, hopefully it will finally fix this annoying issue! There is a separate TSB number for Canada, but they were able to look it up for me.
jermyzy is offline   Reply With Quote
Old 03-21-2014, 02:40 PM   #83
brad fischer
Drives: 2013 BRZ Premium Blue Manual
What is the Canadian TSB # ?
brad fischer is offline   Reply With Quote
Old 03-21-2014, 03:53 PM   #84
jermyzy
Per my other post which you also posted on, try 07.08.13
This was what was written on my invoice
When cold windows do not work if below zero - see SB 07-79-13R
1000 Order in part as per SB.07.08.13
Window tint issues... Normal? Moshpit37 Cosmetic Modification (Interior/Exterior/Lighting) 35 09-11-2013 07:51 AM
What do you look at out your window? nzer Off-Topic Lounge [WARNING: NO POLITICS] 8 10-07-2012 02:59 AM
Auto up and down window Issues? CzRceCar Issues | Warranty | Recalls / TSB 3 08-07-2012 08:44 PM
Pop out window brett_g Cosmetic Modification (Interior/Exterior/Lighting) 10 07-22-2012 11:42 AM
Window Tint Before and After Suiris FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-24-2012 11:37 PM
