Window issues
Wondering what my Canadian friends are doing to try to rectify the annoying window malfunctions each morning?
Hopefully by now everyone realizes that when your two window buttons are flashing and the windows aren't cooperating one needs to roll down the window halfway, then roll it back up and continue to hold up for ten seconds. This will accomplish a reset. I've tried silicone lubricant on the seals and window area to no avail. They seem to stick no matter what with this colder temperature. Any ideas or solutions you've come across? Thanks in advance. On another note loving the FRS in winter! |
does this only happen because of the cold weather? havent had any window problems, but then its pretty mild in van.
I think we will have to deal with that crap until the temperature settles below zero permanently. You could always park your car with the windows 4-5mm, just to clean the double seal and see if that makes a difference.
No sticking issues yet - although not quite sub zero yet
Ah, being Canadian :bonk: |
this has happened with every car I have owned |
Im surprised the silicone spray didnt work. You have to leave a significant residue on the rubber. Spray a liberal amount on a microfibre cloth and smear it along...
Glad I'm garaging my baby. Alberta has the weirdest weather. As I recall there was a blizzard in June in either Calgary or Edmonton 1 or 2 years ago? |
petroleum jelly (Vaseline) works on my Accord windows in the winter. The trick was to get enough in the seals that you didn't have to reapply it every couple of days.
- plus unlike a silicone spray, there's no odour. |
Rob |
Silicone is pretty inert wrt rubbers/plastics AFAIK. Perhaps there is a gel textured silicone product in the market. Here I found this product...http://www.autopia-carcare.com/w-8930128.html And this...[ame="http://www.amazon.com/einszett-914806-Gummi-Pflege-Rubber/dp/B004B8GTQG/ref=sr_1_1?s=automotive&ie=UTF8&qid=1351351024&sr= 1-1&keywords=wurth+rubber+care+gel+stick"]Amazon.com: einszett 914806 'Gummi Pflege Stift' Rubber Care Stick - 3.4 fl. oz: Automotive[/ame] The xB tends to get frozen windows too. |
Windows have not stuck yet! Still not cold enough in Toronto!
Gummipflege is great for restoring dried or cracked rubber, or preventing that in the first place. It won't help a whole lot with the window problem, though. For that you really want to use de-icer. Get it at Canadian Tire or even the corner drugstore or convenience store. |
Funny, a guy from northern Cali recommending Canadian Tire.
| All times are GMT -4. The time now is 09:07 PM. |
User Alert System provided by
