Old 02-24-2014, 03:46 PM   #1
Gt86_nick
Drives: Scion FRS asphalt
Borla uel advice
So I bought borla uel headers and installed them myself. A few days later I started hearing an exhaust leak and think I may not have torqued that one tricky bolt enough. Anyone that has done an install themselves knows which bolt it is lol the one on the driver side right next to the bend. If I had a picture I'd post it. For the record I used a flex joint socket to get to the bolt the first time. So my question would be how did you go about tackling the nut? Any tricks to it?
Gt86_nick is offline   Reply With Quote
Old 02-24-2014, 03:58 PM   #2
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Did you reuse the gaskets or replace them? I'd suggest the grimmspeed gaskets once you figure out how to tighten that one nut.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 02-24-2014, 07:56 PM   #3
almedarj
Drives: 2013 FR-S White out
I've had no issue yet but I got new gaskets when I did the install
Perrin drop in filter Genome Tuning Aluminum resonator delete Borla UEL header motiv concepts over pipe megan racing resonated front pipe invidia q300 cat back and more to come
almedarj is offline   Reply With Quote
Old 02-25-2014, 01:37 AM   #4
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
I re-used gaskets but I was also very careful not to over torque bolts which can also give you a leak. I know it can get tight down there but maybe try to get a torque wrench? I know I got mine on most of the nuts/bolts.
EvilBeaverFace is offline   Reply With Quote
Old 02-25-2014, 10:04 AM   #5
ShadowSeraph
Tech Master / Car Geek
ShadowSeraph's Avatar
Drives: 2013 AT Hot Lava FR-S
I reused my gaskets and made sure to use a smaller torque wrench with a long and skinny extension. I stuck the extension in between the header pipes then put the socket on the extension.. worked well for me. I also made sure to tighten the bolts evenly and opposite, kind of like putting on a tire, but that was me being extra careful on my first header install.
Perrin: Crank pulley, 3" Cat back, Nameless: 3" FP/OP
GFB: water and alternator pulleys
Borla: UEL Header
Hyper Black ROTA T2R 18x9.5, DSS CF Shaft for AT
-= OFT - Stage 2 UEL E85 - fine tuned by me. =-
ShadowSeraph is offline   Reply With Quote
Old 02-25-2014, 12:22 PM   #6
jonbonazza
I feel like resusing a header gasket is a terrible idea. Maybe I am crazy.
jonbonazza is offline   Reply With Quote
Old 02-26-2014, 12:16 AM   #7
Fast_Freddy
Drives: Passat
It really depends on the gasket material. MLS gaskets like ours can often be successfully re-used.
Fast_Freddy is offline   Reply With Quote
Old 02-26-2014, 01:04 AM   #8
EvilBeaverFace
you're crazy! Really though you just have to be careful.
Old 02-26-2014, 01:09 AM   #9
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
I've reused the stock gaskets numerous times on some friends cars with no issues. I usually snug that center (hard to get bolt) down first before the 2 outers.
Jesse@JDLAutodesign is offline   Reply With Quote
Borla UEL Header : Need some opinion/advice. Ray_32 Engine, Exhaust, Transmission 3 10-28-2013 11:53 AM
I need some advice The Robot Cow Scion FR-S / Toyota 86 GT86 General Forum 16 04-06-2013 03:43 PM
Advice EDCOVEY FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 12-10-2012 08:16 AM
Need advice FRSMAK86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-06-2012 05:39 PM
FR-S or BRZ? Need some advice Davie Dynamite Scion FR-S / Toyota 86 GT86 General Forum 60 07-13-2012 10:47 PM
