Old 02-24-2014, 03:34 PM   #15
raven1231
[QUOTE=pearsor1;1553627]I like everything except for the acceleration and power output.
Sent from my SAMSUNG-SGH-I337 using Tapatalk[/QUOTE
Now where have I heard that before?
Old 02-24-2014, 03:54 PM   #16
EAZYBRZY
EAZYBRZY's Avatar
Drives: 2014 BRZ LTD
Drive it a little first then start customizing
Sent from my SAMSUNG-SGH-I537 using Tapatalk
EAZYBRZY is offline   Reply With Quote
Old 02-24-2014, 03:55 PM   #17
EAZYBRZY
EAZYBRZY's Avatar
Old 02-24-2014, 04:22 PM   #18
zimzum
Drives: h22 hatch
I would buy what helps the car retain its fun factor, while building the car you want slowly. Before boosting buy the wheels, tires, suspension you want. All those will need to be addressed with a boosted vehicle anyways, you might as well do it and have some fun learning the characteristics of the car before jumping in head first.
I have the money for my suspension set up but haven't taken the car to the track in its stock form. I'm def going to do that first. Just to know if what I'm adding is really a better choice over stock.
zimzum is offline   Reply With Quote
Old 02-24-2014, 04:22 PM   #19
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Wheels, tires, brakes and suspension take precedence over more power in my books, build the car up so that it can utilize very little bit you are giving it.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 02-24-2014, 04:24 PM   #20
JS + BRZ
Drives: 2010 MS3
Just take it to the track as a stock form. See what you want to upgrade.
I did it and I just want to get a set of lightweight wheels and sticky tires. Didn't really feel like I need additional power for now.
I noticed that I couldn't even properly use that 200hp, why add more? I need to upgrade a driver mod before adding any more power to the ground.
Old 02-24-2014, 04:52 PM   #21
pearsor1
pearsor1's Avatar
Drives:
pearsor1 is offline   Reply With Quote
Old 02-24-2014, 04:53 PM   #22
pearsor1
pearsor1's Avatar
Drives:
Old 02-24-2014, 05:03 PM   #23
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by pearsor1 View Post
Thanks. Noted. I get impatient and want everything at once.
Start slow and figure out what you want as you drive it stock.
Wheels and tires first. Then figure out what you like about the engine. It may be that what you want really is NA, or SC, not Turbo.
Also, consider fluid changes too after break-in, as well as better brake pads and putting in RBF600 (or is it 400?) brake fluid. You know, stuff that'll simply help it do better what it already does.
As you learn the car more and more you'll get a sense for exactly what you want to do for it. Dumping all your money right now is a great way to start the cycle of paying twice. Don't do it.
A wise carpenter says "Measure thrice, cut once." A smart tuner-car driver says "Think thrice, buy once."
^GT5 Replay Photo Mode^
Old 02-24-2014, 05:27 PM   #24
pearsor1
pearsor1's Avatar
Drives:
Thanks. Noted
Old 02-24-2014, 07:41 PM   #25
fatoni
i can see wanting to add power for street driving where its easy to use power but i imagine that the 200hp the car comes with is more than enough to keep you busy on the track. every time i think about doing something to my track car i say to myself "you cant even use all the power you have now. why do you want more?"
if you want to have a fast car, save up for a supercharger unless you have access to e85. if you want to go around a track fast, spend time on track days, instructors, and a datalogger.
The Following User Says Thank You to fatoni For This Useful Post:
pearsor1 (02-24-2014)
Gasoline Choices Lunatic Scion FR-S / Toyota 86 GT86 General Forum 22 02-04-2014 09:32 AM
Exhaust choices KonTheory Engine, Exhaust, Transmission 6 01-30-2014 03:28 AM
Turbo Kit Choices AVodka14 Forced Induction 63 07-25-2013 09:43 PM
Choices choices ICantAffordAnLFA EUROPE 5 08-11-2012 01:38 AM
Help with Lug choices. feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 05-24-2012 08:19 PM
