Old 02-23-2014, 08:39 PM   #253
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
i want to see these in gold , i was torn between these and the 57drs , i went with 57drs but sometimes wish i had gone for these
eddieEndo is offline   Reply With Quote
Old 02-23-2014, 08:51 PM   #254
CenCali86
CenCali86's Avatar
Drives: FRS 10 Series
Originally Posted by jdnguyen View Post
I did winning blue. Graphite would look good too!
I was leaning towards a gunmetal/ graphite. The silver ignition is such an awesome color but damn does it make matching other colors to it difficult.
CenCali86 is offline   Reply With Quote
Old 02-23-2014, 10:39 PM   #255
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
maybe this might help with the visualization.
shiumai is offline   Reply With Quote
Old 02-23-2014, 10:45 PM   #256
CenCali86
CenCali86's Avatar
Thanks man! I'm really like that top image.
Old 03-10-2014, 06:37 PM   #257
mush
mush's Avatar
i recently got these rims 18in staggered
noob question
i never had aftermarket rims before, do i still use 35psi? cause the tires only says "50psi max"
Old 03-10-2014, 07:52 PM   #258
nosi9frs
nosi9frs's Avatar
Drives: Raven FR-S
Gram Light 57Xtreme: 18x8.5 +33 / 18x9.5 +40
noob question
No, max inflation on a tire sidewall is max until possible failure. There are tables available that can tell you suggested psi, It will probably be a similar with those tires, but I couldn't tell you off the top of my head
nosi9frs is offline   Reply With Quote
The Following User Says Thank You to nosi9frs For This Useful Post:
mush (03-10-2014)
Old 03-10-2014, 07:54 PM   #259
jadewbj
jadewbj's Avatar
I run 38.
jadewbj is offline   Reply With Quote
The Following User Says Thank You to jadewbj For This Useful Post:
mush (03-10-2014)
Old 03-10-2014, 08:38 PM   #260
mush
mush's Avatar
it was at 40 psi when they installed it, took some air out now im at 36 psi
Old 03-12-2014, 06:10 AM   #261
Choong86
Drives: Toyota GTS 86
Velvet Blue 18x9.5 +38
Choong86 is offline   Reply With Quote
The Following User Says Thank You to Choong86 For This Useful Post:
dunnr (04-15-2014)
Old 03-12-2014, 08:00 PM   #262
dunnr
Boston WhiteOut
Drives: 2013 FR-S white-out, 2015 MB C300W4
Here are some pics!
Attachment 66556Attachment 66557Attachment 66558Attachment 66559Attachment 66560
look awesome. you need mud guards on that bad boy.
and don't park too close to the curb
dunnr is offline   Reply With Quote
Old 04-02-2014, 07:59 PM   #263
FullTuneZN6
Novice Drifter
FullTuneZN6's Avatar
Drives: 2013 Asphalt FR-S
if that's what you want, you'd have to stick to narrower rims and tires - this setup won't work for you. grip is increased a LOT, which was what i wanted. i have not noticed more understeer - but that doesn't mean there isn't any. i'd need to go back and drive a stock setup to compare and then drive mine.
with this set up and the "a lot " more grip what power #'s are you running? is it still stock? im just curious bc the extra grip may come in handy and balance out a little with more power added
...sweet pics btw
FullTuneZN6 is offline   Reply With Quote
Old 04-03-2014, 12:05 AM   #264
shiumai
shiumai's Avatar
...sweet pics btw
stock engine. more grip is a priority to me over more power for now. yes, of course i'd like to have a little more power in the street, freeway etc, but when driving in the canyons, i've never had the need for more power in a curve. more grip yes, but not more power.
driving a big track would be different and i can definitely see the want for more power in the straights. it all depends on what you want to do with the car.
Old 04-03-2014, 03:00 PM   #265
FullTuneZN6
Novice Drifter
no i understand...i just wanted to know because as you increase the power you need more grip, and with this set up i think it would be a good balance of grip to power to allow for a little tail wagging now an then ...thanks
Old 04-03-2014, 03:16 PM   #266
dunnr
Boston WhiteOut
wagging tail
Shake ur $$$ maker.
The Following User Says Thank You to dunnr For This Useful Post:
FullTuneZN6 (04-03-2014)
Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40 L8Apex Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 71 08-05-2023 09:20 PM
Wheel Directory: Gram Lights 57Xtremes 18x8.5 +45/18x9.5 +40 WorkoArt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 02-18-2017 06:46 PM
Candy Red Gram Light 57Xtreme 18X9.5 +40 ugadogs_11 Wheels and Tires 8 10-03-2013 09:04 AM
FS: Gram Lights 57Xtreme 18x8.5, 18x9.5 funcheung Canada Classifieds 7 09-16-2013 05:01 PM
