Northwest AK, ID, OR, WA
Old 02-20-2014, 11:44 AM   #29
evan
Drives: fr-s
Just popped a P0420 (catalyst efficiency below threshold) last night. Get that code ironed out your tune folks! :0) Header guys.. I'm talking to you. I've got both cats, but exhaust flow must be too fast for the catalyst to heat up properly.
evan is offline   Reply With Quote
Old 02-22-2014, 12:29 AM   #30
NickFRS
Drives: 2013 Asphalt FRS
This code usually pops if you are catless. If you have a cat that is concerning ahaha.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 02-22-2014, 02:06 PM   #31
evan
Drives: fr-s
Cat in header downpipe is getting swapped anyway for different reasons, so we will see..
Sent from my Nexus Five, I'm Alive!
Old 02-22-2014, 08:36 PM   #32
evan
Drives: fr-s
Blame it on the meh, meh, meh, meh, meh, methanol..
https://web.anl.gov/PCS/acsfuel/prep...04-75_0059.pdf
Science is awesome kids
Old 02-23-2014, 03:12 AM   #33
NickFRS
I know how meth works. I also have seen meth on cars with stock cats with no issues. Just saying.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 02-23-2014, 11:00 AM   #34
evan
Drives: fr-s
I have no doubts that you do. Since I don't have stock cats, likely I'll need an o2 spacer on the secondary bank. The hi-flow cat may be disrupting normal emissions operation. I am not ready to disable P0420 since I want to stay compliant. I still don't think the cat on the header downpipe is heating up enough. It's not a big deal really. For those purchasing the PRE header, you'll probably end up disabling P0420.
Old 02-23-2014, 11:22 AM   #35
NickFRS
Just go catless!
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 02-23-2014, 11:33 AM   #36
evan
Drives: fr-s
Just go catless!
Too loud and stinky!
Old 03-05-2014, 05:09 PM   #37
PRE-Erich
Drives: 1981 Toyota Corolla TE72
Btw, Evan, on pump + meth your car made 276whp today. I'm not a huge fan of the injectors but it drives really good on the pump tune. Draining the gas and getting ready to tune on e85. The corn tune shound be even smoother because it will allow those port injectors to run at a more efficient pulse width.
PRE-Erich is offline   Reply With Quote
The Following User Says Thank You to PRE-Erich For This Useful Post:
evan (03-05-2014)
Old 03-05-2014, 05:24 PM   #38
evan
Drives: fr-s
Thank you. We didn't add power adders, so the power on pump is consistent with the last run on stock injectors and pump, which makes me happy. 10-4 on the injectors.. They were meant for the additional scalability to support corn juice and future power adders. I plan to run this thing 95% of the time on E85, so can't wait to see results for that!
Good job Erich!
Eat your vegetables..
Old 03-05-2014, 11:35 PM   #39
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Even,
car sounded great good luck on the corn power!
Erich adjusted my tune so no more crazy cold start ups
anyone with a BRZedit tune should go see Erich for an update
plan to get before and after videos posted soon
Jmonty is offline   Reply With Quote
The Following User Says Thank You to Jmonty For This Useful Post:
evan (03-06-2014)
Old 03-06-2014, 12:13 AM   #40
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
I want this exhaust manifold...
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 03-06-2014, 04:08 PM   #41
PRE-Erich
Originally Posted by Jmonty View Post
Even,
So was it better this morning on a true cold start? This is something I will happily do for any of our catless or high flow catted BRZ-edit customers. I have most of your maps still from the transition.
evan (03-06-2014)
Old 03-06-2014, 05:36 PM   #42
Jmonty
Yes it was better this morning , not bad at all
evan (03-06-2014)
Nameless Performance Equal Length Stepped Header Jason@Nameless Engine, Exhaust, Transmission 4525 11-21-2022 05:38 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
Tri-Y (4-2-1) stepped vs. UEL 4-1 solidONE Engine, Exhaust, Transmission 26 10-01-2013 01:27 AM
