Old 02-23-2014, 03:13 AM   #1
L8Apex
Drives: H8R FR-S
Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40
Haven’t seen this setup yet so here it is:
Rays Gram Lights 57Xtreme
17x9 +40
custom Mag Blue powder coat
245/40-17 Federal SS-595 square
stock suspension, stock alignment
Pardon the rally ride height:
Comparison pics…
Before/After
Before/After
Before/After
Here’s the new and old tire side by side. Look at that extra meat:
The new wheel/tire combo is a bit heavier than stock: 45.75 lbs, vs oem ~42 lbs.
The wheels poke slightly at stock ride height and alignment, but not bad.
Front:
Rear:
No rubbing, even at full lock. No issues at the fender or liner, front or rear. There’s about 5mm clearance between inside front tire and spring perch, not enough space to get any camber using crash bolts while on the stock springs. I’ll probably do camber plates instead so I can run RCE Yellows. I don’t want spacers or any more offset if I can avoid it.
This is just step one. Suspension mods to follow.
Much thanks to Randy at Evasive Motorsports for setting this up for me. He was a huge help getting hold of the size I wanted and lined up the custom powder coating which turned out perfect. Can’t say enough positive about Evasive!
"Understeer scares the driver; oversteer scares the passenger"
L8Apex is offline   Reply With Quote
The Following 5 Users Say Thank You to L8Apex For This Useful Post:
DAEMANO (02-23-2014), dunnr (03-16-2014), Evasive Motorsports (02-24-2014), IAmNotTheDriftKing (02-23-2014), TofuJoe (10-11-2015)
Old 02-23-2014, 06:03 AM   #2
TheProdigy
TheProdigy's Avatar
Drives: 2013 WRB Subaru BRZ Limited
Daaaamn, nice man! really looking that powder coat! Adds some color to it!
TheProdigy is offline   Reply With Quote
The Following User Says Thank You to TheProdigy For This Useful Post:
Old 02-23-2014, 06:06 AM   #3
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
These are the exact size I wanted for these wheels, they look beautiful! I wish I had the cash for these :'( Maybe once I am out of college.
IAmNotTheDriftKing is offline   Reply With Quote
The Following User Says Thank You to IAmNotTheDriftKing For This Useful Post:
Old 02-23-2014, 06:45 AM   #4
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
Nicely done! I really like the hot Lava/blue scheme. Had you have gone Lava /teal, I might have barfed right about now! I can't wait to see the lowered pics.
Wolfking is offline   Reply With Quote
The Following User Says Thank You to Wolfking For This Useful Post:
Old 02-23-2014, 10:56 AM   #5
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
Very nice, I was pondering that setup for a while, good choice.
In God We Trust - Hold No Faith That Violates Reason
SpeedyJay is offline   Reply With Quote
Old 02-23-2014, 02:21 PM   #6
eklipz98
Drives: 2004 Honda S2000 (RIP to my BRZ)
Loving this set up!!!
eklipz98 is offline   Reply With Quote
Old 02-23-2014, 03:14 PM   #7
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
Did you get a shop to do that powder coating or you can order custom color from rays?
Myv is offline   Reply With Quote
The Following User Says Thank You to Myv For This Useful Post:
Old 02-23-2014, 11:19 PM   #8
L8Apex
Drives: H8R FR-S
Evasive Motorsports works with a shop local to them for custom wheel coatings, and offered to have a set of silver wheels coated for a reasonable charge before shipping them out. They sent sample pics before I placed the order so I could judge the color.
Otherwise they don't come in mag blue, but you can find "Winning Blue" and "Velvet Marine" blue straight from Rays. Both are more of a matte finish and not as dark. Problem is they're only stocked in 18". The 17's would be special order from Rays for those colors.
The Following User Says Thank You to L8Apex For This Useful Post:
Old 02-24-2014, 12:15 AM   #9
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
Looking good needs some suspension soon! @L8Apex
-Randy
Evasive Motorsports is offline   Reply With Quote
Old 02-24-2014, 01:03 AM   #10
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
With some low should complete the look.
Old 02-24-2014, 01:25 PM   #11
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels
Old 02-24-2014, 04:32 PM   #12
shattered_memory
Drives: Satin White BRZ Limited
Those are really nice wheels! I'm thinking of running a sized wheel similar to yours for the track. Do you notice more body roll compared to the stock setup? I'm just wondering since your offset is a 8mm difference from stock. Thanks
shattered_memory is offline   Reply With Quote
Old 02-25-2014, 12:38 AM   #13
L8Apex
Drives: H8R FR-S
Thanks! No additional body roll noticed, except what comes from more aggressive cornering on more grip. The car feels much more planted mostly due to the tires.
Old 03-16-2014, 11:10 AM   #14
dunnr
Boston WhiteOut
Drives: 2013 FR-S white-out, 2015 MB C300W4
17x9 +40
Comparison pics…
Before/After
Before/After
Before/After
Front:
Rear:
Those Gram Lights look awesome.
dunnr is offline   Reply With Quote
Wheel Directory: Gram Lights 57DR 17x9.0 +38 mr. slim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 179 12-07-2021 07:07 PM
Wheel Directory: Gram Lights 57Xtremes 18x8.5 +45/18x9.5 +40 WorkoArt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 02-18-2017 06:46 PM
Wheel Directory: Gram Lights 57Getter 19x8.5 +35 adprokid Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 08-20-2015 11:44 AM
Wheel Directory: Gram Lights 57Xtreme 19x9.5 +43 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 12-04-2014 10:56 PM
Wheel Directory: Gram Lights 57Xtreme 19x8.5 +43 / 19x9.5 +45 86 FRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 05-19-2014 12:28 AM
