Old 02-22-2014, 04:53 PM   #21631
Lischynski
Weendog
Lischynski's Avatar
Drives: 2014 Scion FR-S
Did rear differential fluid swap today. Stock fluid smells AWFUL! had some metal-y paste on the drain plug magnet, but no noticeable chunks, so I'll call it a victory. Also installed my Grimmspeed hood struts. Pain in the ass to do by myself, but I managed, and it looks much better now. The install is actually really easy, just would have been helpful to have a spare pair of hands. Hopefully this will keep my hood from warping any more than it already has.
(It makes me sad that your car's color isn't stock. It looks great.)
Old 02-22-2014, 05:08 PM   #21632
kavanagh
Fat on Corn Syrup
Alright making progress on the scratches.
I got the Megan Diff Brace installed.
@amaciose picked up and installed his newest upgrade. I think he likes it lol.
I also started this project for @4azcats stock header no heat shields with the cat punched out. This along with the minor exhaust changes should be interesting. It should also be interesting to get him to do said mods.
Sent from Spaceball 1
With the O2 sensors there in the cat, will the car throw a CEL if you don't run a tune or spacers or anything else? Basically, can you punch the header cat and do absolutely nothing else, and get no CEL?
Old 02-22-2014, 05:11 PM   #21633
ChandlerSwyng
ChandlerSwyng's Avatar
Drives: 2013 Red Subaru Brz
Who's attending the pavs tonight?
Old 02-22-2014, 05:11 PM   #21634
kavanagh
Fat on Corn Syrup
Track time, engaged. Make it so.
Thanks @Juggles for the info!!
Old 02-22-2014, 05:29 PM   #21635
Cross
It's the Mad Cow
Cross's Avatar
With a spacer using spark plug antifowelers we might get away with it but that has to be tested. However @4azcats has an OFT so it will not matter for him.
@jeffsides seems @captain_jack is out but I know a few of us are still heading up.
Old 02-22-2014, 05:42 PM   #21636
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Originally Posted by AZFA20 View Post
I was at JDL on Wednesday correct. We were more or less curious if there would be any issues with the equal length on my setup and yes there was very minimal interference with my setup. Very easily rectified and I may still go that route at some point but it's hard to let go of the sound of my JDL UEL.
Yours seems to be an easy fix as far as fitment on the EL header. If you have the UEL already I would just stay with that. I am not a fan of the so called "Subie/Boxer Rumble" thus why mine is EL but to each his own. I actually wanted to stay and see your car on Wednesday but work was calling my name unfortunately
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 02-22-2014, 05:50 PM   #21637
captain_jack
captain_jack's Avatar
Yeah I had planned on coming up but I just don't feel good at all. So I'm out unfortunately.I was looking forward to it.
may the schwartz be with you....
Old 02-22-2014, 05:51 PM   #21638
nelsmar
I haven't tested with a punched trough at but on a number of headers I haven't disabled the CEL. And I did forget to disable the rear af sensor compensation before and no DTC was thrown. I honestly can't even remember which DTC is commonly thrown for it though.
I've been wanting to test this as well to see how much of the tirque dip could be eliminated by simply removing the cat.
My flickr - Canibeat
Local magazine scout
Old 02-22-2014, 05:52 PM   #21639
nelsmar
Nooooooooo!!!!
Old 02-22-2014, 06:18 PM   #21640
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
The rear O2 on these are too sensitive to use an antifoul plug. It will still throw a CEL. The reason is that the rear O2 will in fact adjust fuel trims just as the front will for various reasons such as attempting to heat the cat to get a reaction from it should the rear O2 see too lean a condition from pulling it out of the exhaust stream. Older systems you could get away with this but newer ones are nearly impossible to trick. They know better. The only way to be able to avoid the CEL is to disable the rear O2 trimming and the CEL associated. If you do not dissable that sensor there are side affects that you will not want occurring relating to STFTs.
As a tuner, if you try tuning the vehicle and there is no cat you will be basically chasing your fuel trim adjustments unless you eliminate the rear O2 functionality. Basically you will be a dog chasing your tail.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
The Following User Says Thank You to AZFA20 For This Useful Post:
J. O'Grimm (02-22-2014)
Old 02-22-2014, 06:41 PM   #21641
kavanagh
Fat on Corn Syrup
I'm thinking of punching the front pipe cat or the header one.
Old 02-22-2014, 06:45 PM   #21642
nelsmar
Yeah I had a problem once which is how I found out DTC isn't always thrown gene someone didn't tell me they didn't have a front cat and the fuel trims were changing in ways I wasn't expecting. I now always ask if someone has a front cat before flashing lol
Old 02-22-2014, 06:55 PM   #21643
AZFA20
AZFA20's Avatar
Yep makes a surprisingly big difference. The trims can do some interesting things as the ECU try's to wake a cat up that doesn't exist haha.
Old 02-22-2014, 06:59 PM   #21644
nelsmar
Yup lol.
