Old 02-04-2014, 01:06 PM   #393
wheelhaus
wheelhaus's Avatar
Originally Posted by choi0706 View Post
does anyone have a boost graph with this kit?
Posted several pages back. Is this what you're looking for?
The boost rises linearly with RPM.
Old 02-13-2014, 07:20 PM   #394
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
Originally Posted by raul View Post
@CSG Mike @Jackson Racing
Or anyone for that matter. How much weight does the kit add to the car, roughly? Anyone taken the time to weigh it?
We haven't had the chance to weigh our FR-S yet, but I would guess the system installed adds +/- 30 lbs. I am guessing based on our other kits with similar components.
-Oscar Jr.
Jackson Racing is offline   Reply With Quote
The Following 2 Users Say Thank You to Jackson Racing For This Useful Post:
*LongFella (02-16-2014), sklimo (02-14-2014)
Old 02-22-2014, 01:32 PM   #395
enivid
enivid's Avatar
Drives: WRB JR BRZED
Getting close. Just waiting for the oil cooler to arrive and then will install the intercooler and wrap it up!
enivid is offline   Reply With Quote
The Following 6 Users Say Thank You to enivid For This Useful Post:
*LongFella (02-22-2014), Blizzard (02-24-2014), CSG David (02-23-2014), Mad1723 (02-22-2014), sklimo (02-26-2014), Sonolin (02-22-2014)
Old 02-22-2014, 01:53 PM   #396
Ocho Seis
Ocho Seis's Avatar
Drives: 2013 Frs
What intercooler did you go with ?
Ocho Seis is offline   Reply With Quote
Old 02-22-2014, 03:14 PM   #397
enivid
enivid's Avatar
The one that it comes with
Or if you meant oil cooler, I'm waiting on the JR oil cooler which I hope will arrive very soon.
Old 02-23-2014, 09:11 AM   #398
Ocho Seis
Ocho Seis's Avatar
Drives: 2013 Frs
my bad I ment oil cooler ...
The Following User Says Thank You to Ocho Seis For This Useful Post:
CSG Mike (02-25-2014)
Old 02-25-2014, 10:50 PM   #399
enivid
enivid's Avatar
Originally Posted by CSG Mike;
Just fine. The Rotrex is a proven supercharger, and is OEM on some exotic cars as David mentioned.
We've done our own testing with Rotrex superchargers (albeit on a different car) at 4000+ ft elevations, without issue. Datalogs show ambient getting as low as about 12.5 psi (vs 14.5 psi at sea level).
Do you have a guess on what the hp loss is at 4000+ ft elevations for this supercharger?
Old 02-26-2014, 03:40 AM   #400
CSG Mike
CSG Mike's Avatar
It's more or less a percentage... same applies for any FI setup.
Old 02-26-2014, 08:12 AM   #401
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Do FI setups take a higher % drop compared to NA cars at elevation? Say a turbo car makes 300whp and a NA cars makes 200whp at sea level. Going up to 4000 ft, would the turbo and NA car both drop approximately x%?
mit_peid is offline   Reply With Quote
Old 02-26-2014, 08:31 AM   #402
qtwre
Drives: White FR-S
Won't a turbo just spin faster to hit the same boost target, regardless of elevation? Oh, but then I guess intake temperatures would go up, losing power.
Touche.
qtwre is offline   Reply With Quote
Old 02-26-2014, 11:38 AM   #403
CSG Mike
CSG Mike's Avatar
^ That.
One thing people don't realize, is that the turbo Bimmers and Mercedes cars gain a TON of power from reflashes, because they actually have the capability of making more than their rated horsepower from the factory. Why? Because the manufacturer wants the car to make that power in a variety of conditions, not just under ideal conditions.
For example, an older 300hp/300tq BMW 335 will make 300hp/300tq at sealevel, as well as at 4000 feet above sea level. How does it do it? By utilizing more of the overhead that is left as a margin for consistency in output. However, a reflashed 335 will not have that consistency. After a flash, the car may make 360hp/345tq at sea level, but only 320hp/320tq at 4000 feet above sea level.
I've never said this before, but this 0-125 video was shot at high elevation, above 4000 ft.
[ame="http://www.youtube.com/watch?v=KHZTjIKNpNU"]Jackson Racing Supercharged BRZ (FR-S) 0-127mph run - YouTube[/ame]
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
sklimo (02-26-2014), Sonolin (02-26-2014), TexMex (02-26-2014), TouchMyHonda (03-06-2014)
Old 02-26-2014, 12:51 PM   #404
jamesm
if you lose power when you go up in elevation on a turbo system (i.e. the turbo can't keep up due to an inability to push the PR required to maintain target boost at that altitude), your turbo is way too small.
this isn't a realistic concern with any of the turbo kits available for this platform.
The Following User Says Thank You to jamesm For This Useful Post:
SirBrass (02-26-2014)
Old 02-26-2014, 02:49 PM   #405
tendogy
Whaaaaaaaaaaaaaaaaat?!?! You got so much crap for the lack of acceleration (relatively speaking) in that video and you didn't want to mention that it was at elevation? So you were only at ~22psi instead of ~24psi; that explains everything.
tendogy is offline   Reply With Quote
Old 02-26-2014, 03:45 PM   #406
CSG Mike
CSG Mike's Avatar
:shrug:
the 0-60 is still faster than stock by a good margin, even with the granny shifting.
A supercharger's RPM doesn't change by elevation; a turbo can work harder to get to the desired boost (albeit, potentially also going out of the efficiency range). I'd say the absolute MAP was lower than 22 :p
jackson racing, jrsc, rotrex, supercharger, track
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 03:28 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
