Old 01-29-2014, 09:50 AM   #15
CaptainSlow
CaptainSlow's Avatar
OK thanks!
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 01-30-2014, 09:57 AM   #16
CaptainSlow
Tested it last night (I have a beta 1.4X tune on the car at the moment...need to update I guess)...can confirm launch control is active on those maps, and is set around the 5500 rpm range.
Old 01-30-2014, 03:37 PM   #17
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Does this go for TunerPro as well? I recall seeing the fields, but wasn't sure what to do with them.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 01-30-2014, 07:45 PM   #18
steve99
Drives: FT86
The parameters are defined for tunepro in the XDF files for C series ROM's (see first post be shiv for defined ROM's
If you open the XDF in notepad or similar text editor/viewer and search for them ie FFS or Launch their is some info on setting these parameters.
Old 01-30-2014, 09:58 PM   #19
CaptainSlow
Edit...nevermind. I was being an idiot. Original post is quoted below, but I didn't want to leave my OP here because there was actually no issue other than user error.
Old 01-30-2014, 10:21 PM   #20
steve99
Drives: FT86
Originally Posted by CaptainSlow View Post
OK, bit of an issue (or maybe it's not...you be the judge).
I had a beta version of the 93 Octane Stage 1 1.42 map installed on my car. I tested it yesterday and found that it did indeed have launch control...with the clutch in the revs would not pass 5600RPM...here is a capture of the parameters for that tune file:
I downloaded the new released 1.42 maps today and modified the 93 Octane Stage 1 and E85 EL Stage 2 maps to have a LC setting of 3600 (would equate to a 4000 RPM limiter) and FFS of 600 (so the RPMs would max at 7000 when using FFS). I saved these new files as "93 Octane v1.42 (FFS+LC).bin" and "E85 v1.42 (FFS+LC).bin" - NOTE - I did actually type ".bin" at the end of the file name when I was naming it - didn't seem to automatically attach that file type when I didn't the first time. Not sure if that matters or not.
Here are the two sets of parameters:
93 Octane v1.42 (unmodified)
93 Octane v1.42 (modified FFS and LC)
I loaded the modified map onto my car, but the launch control doesn't seem to be working. I pushed the clutch in and tried revving, but it just revved near redline, so I just let up. Tried that a couple of times, but got the same results. The car wasn't fully warmed up...not sure if that matters? Anyway, just wondering what, if anything, might be going on? It's not a huge deal, but I would like to know why it's not working now.
I didn't try the base released v1.42 map as an intermediate, but like I said, it was working with the beta v1.42 map. Anyway, figured I probably did something wrong, so just wondering if anyone sees anything obvious or has an answer for what might be going on.
Thanks!
Did you also point Tunerpro at the "new" XDF file corresponding to the new bin files ??
Bin files and XDF's must match
Old 01-30-2014, 10:26 PM   #21
CaptainSlow
Yeah...turns out im a moron. Im an idiot and accidentally flashed the stock file instead of the new tuned file. I thought I had selected it but I was wrong. Loaded it up again and it works like a charm...revs stay right at 4k
Sent from my GT-P5113 using Tapatalk
Old 02-03-2014, 03:34 PM   #22
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
not supported for B01C roms yet - FYI if you have a B01C rom and are looking for this in RomRaider.
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 02-06-2014, 10:57 AM   #23
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Launch control and FFS does not supported in the new 2014 B series ROMs just yet.
Shiv@Openflash is offline   Reply With Quote
Old 02-16-2014, 08:37 PM   #24
Proof
Proof's Avatar
Drives: 2007 STI Limited / 2014 BRZ Limited
Is there anyone who can walk me though getting Romraider to even friggin work?! I have been screwing around for two hours and cant get it to even open a file. I feel like a moron but cant cant seem to find what I am doing wrong. Are there any walk-thru?
Proof is offline   Reply With Quote
Old 02-16-2014, 09:05 PM   #25
Proof
Proof's Avatar
I assume this applies to the 800C and timeline on this?
Old 02-21-2014, 09:36 PM   #26
DEK186
DEK186's Avatar
Drives: 86 GT MT Velocity Orange
Will flashing the same rom with different LC & FFS parameters require the ECU to learn trims again and so on?? I am thinking of saving a few roms with different LC & FFS parameters and flashing between them to test them out on the track this afternoon. Would hate to have a shit run down the quarter because my ECU hasn't learnt what it needs to in 400m.
DEK186 is offline   Reply With Quote
Old 02-21-2014, 09:51 PM   #27
steve99
Drives: FT86
Yes , your erasing then flashing entire ROM, it will need learning time
Old 03-28-2014, 06:53 PM   #28
t1ao
Drives: 2008 Bmw 335i
I currently have B00C, would i be fine using A01C, so i could use launch control?
t1ao is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
racerom flat foot shifting ft86me Engine, Exhaust, Transmission 10 07-25-2013 03:02 PM
EcuTek RaceRom Flat Foot Shifting ! Visconti Engine, Exhaust, Transmission 79 11-14-2012 09:36 PM
