| Software Tuning Discuss all software tuning topics. |
Drives: White 2013 FRS
AFR's Danger zone!?
#2 |
Drives: car
Internet tuner rule of thumb is, stay in the 11's (call it Lambda=.81 or less) for gasoline/E10. Now there are things like closed loop delays engine rpms and such that play into that. With E85 you can actually run more timing compared to premium E10 in terms of knock. More timing = lower exhaust temperatures, meaning less fuel is required. As I've pointed out in other threads, when you start advancing the timing you increase cylinder pressure even if the engine doesn't knock.
The problem is, if I tell you to run it leaner and advance the timing, and you do that, I'm an idiot with dangerous advice if something goes wrong. No matter what the root cause of the failure is. And you become an idiot for listening to me. So I'll throw out a somewhat arbitrary and oversimplified piece of advice and say, stay lambda of =.81 or richer once boost is over 5psi. |
#3 |
agreed, what afr is 'safe' depends greatly on the timing being run. i'd see what you're targeting and set it a half-point leaner than that. there really is no general rule that you can be sure of. you definitely don't want to be over 12:1 in boost though.
#4 | |
NASA SpecE30 Racer
Red = anything under 9.5:1 Yellow = 9.5:1 to 11.5:1 Green = 11.5:1 to 13:1 Yellow 13:1 to 14.5:1 Red = 14.5:1 to 22:1 If you are in boost and in the green then you are in the go area. If you dip down into the yellow then you are running a little rich. If you are in the red then something is seriously wrong with your tune. If you are the other way, then back out of it ASAP.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z Last edited by King Tut; 02-21-2014 at 03:49 PM. |
| The Following User Says Thank You to King Tut For This Useful Post: | 86-tundra (02-22-2014) |
#5 | |
#6 | |
NASA SpecE30 Racer
![]() I meant green was up to 13:1. I will adjust my ranges. They don't let you just set it based on AFR, you have to set it based on where the LEDs fall on the gauge face as well.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#7 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
12.1 on e85 is what I'm running
#8 | |
. i thought something was off there lol. i usually target 11.2-11.4:1 under boost... seems to make the best power without running what i'd consider to be too lean. i'm sure you can probably get away with leaner/less timing if you wanted to.
#9 |
#10 |
Señor Member
In boost you want to be with in the 11 range. 12.0-12.1 is usually ok but thats starting to get lean. 11.7 would pretty much be dead on perfect
#11 | |
#12 |
Thanks for all the advice, the simple answer seems to be ask my tuner what AFR is being targeted and go from there as it depends what fuel and timing conditions are?
#13 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
For modern NAs you'll want to see around 12.5. They make more HP on the richer side.
For FI you'll want to see about 11.5-12 at most. Some will claim DI can make peak power at 13:1 FI, but our dynos so far have all shown that you're best at 11.5:1. Melt down is rare these days with sodium filled valves and better piston metallurgy. But knock threshold under boost is much worse at 12:1 AFR rather than 11-11.5:1. Better a little richer and more timing. DI and all. Below 12 don't rely on the stock sensor. Shoot for a 12.5 AFR, then subtract 5-10% to get your final fueling. Or get a real wideband. Now with RaceROM 7 support you can tie that right into the ECU and don't really need a failsafe anymore. You can just make a custom Load vs RPM vs AFR map, and then use that for failsafe functionality. |
#14 | |
| Subaru BRZ - Dual Zone Climate Temperature - Wrong? | Nourdmrolnmt1 | Issues | Warranty | Recalls / TSB | 21 | 03-22-2015 01:11 PM |
| Typhoon buffets Tokyo, heads into tsunami zone | Marrk | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-21-2011 02:23 PM |
