Old 02-21-2014, 01:21 PM   #1
Brick
Drives: White 2013 FRS
AFR's Danger zone!?
So I'm gonna be installing a AEM failsafe with my turbo this weekend and want the colored LEDs to be a instant indication of AFRs. Can someone point me in the right direction for the ranges of AFRs that are safe and where the danger zone is for normal gasoline. @jamesm @arghx7
Brick is offline   Reply With Quote
Old 02-21-2014, 02:09 PM   #2
arghx7
Drives: car
Internet tuner rule of thumb is, stay in the 11's (call it Lambda=.81 or less) for gasoline/E10. Now there are things like closed loop delays engine rpms and such that play into that. With E85 you can actually run more timing compared to premium E10 in terms of knock. More timing = lower exhaust temperatures, meaning less fuel is required. As I've pointed out in other threads, when you start advancing the timing you increase cylinder pressure even if the engine doesn't knock.
The problem is, if I tell you to run it leaner and advance the timing, and you do that, I'm an idiot with dangerous advice if something goes wrong. No matter what the root cause of the failure is. And you become an idiot for listening to me.
So I'll throw out a somewhat arbitrary and oversimplified piece of advice and say, stay lambda of =.81 or richer once boost is over 5psi.
Old 02-21-2014, 02:33 PM   #3
jamesm
agreed, what afr is 'safe' depends greatly on the timing being run. i'd see what you're targeting and set it a half-point leaner than that. there really is no general rule that you can be sure of. you definitely don't want to be over 12:1 in boost though.
Old 02-21-2014, 03:32 PM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
This is about how I set mine up:
Red = anything under 9.5:1
Yellow = 9.5:1 to 11.5:1
Green = 11.5:1 to 13:1
Yellow 13:1 to 14.5:1
Red = 14.5:1 to 22:1
If you are in boost and in the green then you are in the go area. If you dip down into the yellow then you are running a little rich. If you are in the red then something is seriously wrong with your tune. If you are the other way, then back out of it ASAP.
Old 02-21-2014, 03:45 PM   #5
jamesm
Red = anything under 10:1
Yellow = 10:1 to 12:1
Green = 12:1 to 14:1
Yellow 14:1 to 15:1
Red = 15:1 to 22:1
i'd have to say 13+:1 under boost isn't green if you ask me... is that what you normally run?
Old 02-21-2014, 03:48 PM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
No. I was going off memory, and @Visconti had me tuned to just south of 13:1, but Toni had me tuned to this:
I meant green was up to 13:1. I will adjust my ranges. They don't let you just set it based on AFR, you have to set it based on where the LEDs fall on the gauge face as well.
Old 02-21-2014, 03:49 PM   #7
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
12.1 on e85 is what I'm running
Old 02-21-2014, 03:53 PM   #8
jamesm
ok got ya . i thought something was off there lol. i usually target 11.2-11.4:1 under boost... seems to make the best power without running what i'd consider to be too lean. i'm sure you can probably get away with leaner/less timing if you wanted to.
Old 02-21-2014, 03:53 PM   #9
jamesm
that's on e85. it's typical to target ~1 afr point leaner on e85 than on pump gas.
Old 02-21-2014, 03:54 PM   #10
STV3
Señor Member
STV3's Avatar
In boost you want to be with in the 11 range. 12.0-12.1 is usually ok but thats starting to get lean. 11.7 would pretty much be dead on perfect
STV3 is offline   Reply With Quote
Old 02-21-2014, 04:04 PM   #11
jamesm
i've found that at around 11.6:1 you need to start pulling timing, particularly at higher rpm. i usually taper down to a richer afr above 7k to keep from having to. i don't tune anything to the ragged edge though... usually pretty conservative. i'd rather have 260whp for 100k miles than have 280whp for 30k .
Old 02-21-2014, 08:12 PM   #12
Brick
Thanks for all the advice, the simple answer seems to be ask my tuner what AFR is being targeted and go from there as it depends what fuel and timing conditions are?
Old 02-21-2014, 10:20 PM   #13
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
For modern NAs you'll want to see around 12.5. They make more HP on the richer side.
For FI you'll want to see about 11.5-12 at most. Some will claim DI can make peak power at 13:1 FI, but our dynos so far have all shown that you're best at 11.5:1.
Melt down is rare these days with sodium filled valves and better piston metallurgy. But knock threshold under boost is much worse at 12:1 AFR rather than 11-11.5:1. Better a little richer and more timing. DI and all.
Below 12 don't rely on the stock sensor. Shoot for a 12.5 AFR, then subtract 5-10% to get your final fueling. Or get a real wideband. Now with RaceROM 7 support you can tie that right into the ECU and don't really need a failsafe anymore. You can just make a custom Load vs RPM vs AFR map, and then use that for failsafe functionality.
Xero-Limit is offline   Reply With Quote
Old 02-22-2014, 12:20 AM   #14
jamesm
i think you mean shoot for 12.5:1 then add 5-10%.. right? i've never done it that way.. interesting idea. so you dial the whole maf (or ve map) in @ 12.5 and then just go through and add the correction globally? i might have to try that next time .
Subaru BRZ - Dual Zone Climate Temperature - Wrong? Nourdmrolnmt1 Issues | Warranty | Recalls / TSB 21 03-22-2015 01:11 PM
Typhoon buffets Tokyo, heads into tsunami zone Marrk Off-Topic Lounge [WARNING: NO POLITICS] 1 09-21-2011 02:23 PM
