Old 02-21-2014, 08:35 AM   #3571
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Originally Posted by swift996 View Post
I have a little bit of what I'd call a "rough" spot between 2-3k rpms at light/moderate throttle when the car hasn't reached proper temperature. It sort of feels like it hesitates/pulsates a little. Nothing crazy but you can feel it. Seems to go away once the car is up to operating temps.
Originally Posted by CK_Bladesmith View Post
Mine is exactly the same
That isn't normal as mine does not do this
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 02-21-2014, 09:26 AM   #3572
phloozy
phloozy's Avatar
Drives: Scion FR-S
is this on 93? Whenever I fill up with 93 after running e85 this happens for about 5 mins then sorts itself out.
phloozy is offline   Reply With Quote
Old 02-21-2014, 10:06 AM   #3573
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by ntaphse View Post
Here's mine instead.
This looks great man, thanks for the photo.
Are you dyno tuned? wonder if the switch to this box will make any difference. Did it change the sound at all?
How far back does the airaid box come? Seems to be close to the oil filter, wonder if there will be issues with the oil cooler I have. Could just be the pic though.
xxscaxx is offline   Reply With Quote
Old 02-21-2014, 10:32 AM   #3574
swift996
swift996's Avatar
Both 93 and e85, although e85 seems to be a bit smoother all around.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-21-2014, 10:51 AM   #3575
jamesm
do you have aftermarket port injectors?
Old 02-21-2014, 10:56 AM   #3576
xjohnx
Grip>Slip
xjohnx's Avatar
He's running DW700's.
swift996 (02-21-2014)
Old 02-21-2014, 10:56 AM   #3577
swift996
swift996's Avatar
Yes DW700s.
The Following User Says Thank You to swift996 For This Useful Post:
xjohnx (02-21-2014)
Old 02-21-2014, 11:04 AM   #3578
evan
Drives: fr-s
I have the exact same thing but it is very mild and can be controlled by smooth throttle action. It can be made better with additional tuning time. It hasn't been a showstopper for me since my transmission is not 100% smooth until the car reaches operating temperature anyway. Once up to operating temp, everything is great.
At the moment I have stock injectors and pump. Also, it is being worked on now to get DW700's in there, DW pump, 3 bar map and tuning for the whole shebang on pump (92). Once that is done, I will have an e85 map built. I'll let you know how the cold spot between 2 and 3k feels after that. Even if it doesn't change much, I don't care since it is not detrimental to the car and I have noticed this car is clunky all around anyway until it is fully warm/hot.
evan is offline   Reply With Quote
Old 02-21-2014, 11:47 AM   #3579
ntaphse
Drives: beater
I have not tuned on the dyno yet, just via datalogs. I'm waiting for Bill and I to be in the same place at the same time to put it on the dyno. Honestly I don't care about peak hp numbers as much as consistent power and good, safe driveability.
I have run my kit with the Airaid box from the start, so I can't comment on the difference in sound, but I did test it without the lid and it was so loud I put it back on. To me the whine was annoyingly loud. Some may like it.
The Airaid flows more air than stock no doubt. Bill is working on the tune to see what gains can be had with this combo. He already made 200whp with E85 and this intake, so it's looking good.
I might be running the Chase Bays oil cooler soon, hoping it will fit with the Airaid air box.
ntaphse is offline   Reply With Quote
The Following 2 Users Say Thank You to ntaphse For This Useful Post:
jflogerzi (02-21-2014), xxscaxx (02-21-2014)
Old 02-21-2014, 11:49 AM   #3580
ntaphse
Drives: beater
Clearance between Airaid air box and oil filter.
Old 02-21-2014, 11:50 AM   #3581
evan
Drives: fr-s
Let us know how it goes. I'm looking for one too.
Old 02-21-2014, 11:52 AM   #3582
jamesm
Yes DW700s.
log the cold start and see what the fuel trims are. if you have a drivability issue that only exists for the first few seconds/minutes after starting it's likely fueling error on the port side (it runs 100% port injection shortly after starting).
i had a similar issue with my first protune and this was the cause.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
evan (02-21-2014), ntaphse (02-21-2014)
Old 02-21-2014, 11:54 AM   #3583
ntaphse
Drives: beater
I'm in the same boat, since it got cold it will scratch going into second gear until the trans oil warms up, and the throttle is touchy and will surge if you aren't careful. It does sputter a bit until warm. This is only for like the first two blocks leaving my house in the morning and hasn't bothered me enough to even re-tune. I'm sure Bill will smooth it out like he said anyways. Looking forward to the next update, Bill is a real perfectionist and I'm amazed at how well these cars are running considering how modded they are.
DeliciousTuning (02-21-2014), evan (02-21-2014)
Old 02-21-2014, 12:36 PM   #3584
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Yes, the common problem people have spoken about, from a dead stop or very low RPM throttle acceleration between 1k-3.5K does have some surging. I have been revising the tune in this area over the past few weeks and getting close to finalizing it.
Currently I do have the Airaid Box on the vehicle (that is it besides the supercharger) and it definitely has the effect of making everything more responsive including the surging. So dialing in the tune for the AirAid has it's benefits. But I will install the OEM box back on for final verification.
Also working on the cold start as I do get about a 1-2 second sputter on start ups, well use to. With some slight adjustments it seems to be improving this considerably. So getting close to an update release. With the main focus on low RPM drivability and no change in power.
Also as another update the AirAid box can literally be bolted right on, with no tuning needed on these tunes. It is definitely a great system, and not sure why it got so much bad press early on, as I have yet to experience any problems on three different boxes I have tried on our development vehicle. (We wanted to make sure there wasn't some fluke good one)
Lastly, we are working on MPG on partial throttle to see if we can improve the overall MPG. And I have made some decent improvements in this arena also. Be on the lookout.
Cheers,
William Knose
The Following 6 Users Say Thank You to DeliciousTuning For This Useful Post:
calispec (02-21-2014), Calum (02-21-2014), CK_Bladesmith (02-21-2014), evan (02-21-2014), Lawnik (02-21-2014), ntaphse (02-21-2014)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
