Old 02-20-2014, 01:26 PM   #211
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
So the STI portion cannot be pry out readily? Is it glued on?
I don't plan on this until I finish my STI OEM+ build tho, not even close to 50% yet like some of you guys here lol!
krayzie is offline   Reply With Quote
Old 02-20-2014, 01:33 PM   #212
AznBRZer
Drives: 16 CBS WRX Limited
It's probably taped onto the garnish at a couple points and secured with a screw at that one end because there's nothing to tape it to at the part where the STi fin extends past the stock fin.
I wonder what happened to that other dude with the CBS Limited OEM+ build. He should be getting in on this...haha
AznBRZer is offline   Reply With Quote
Old 02-20-2014, 01:58 PM   #213
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
@Nitesh31 where you at bruh?!
Old 02-21-2014, 01:09 AM   #214
Nitesh31
Nitesh31's Avatar
Drives: Black BRZ Black STI
I know I'm late on this lol. Need to make sure of a couple other things before I finalize the order from Japan
Nitesh31 is offline   Reply With Quote
Old 02-21-2014, 08:51 AM   #215
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
Ordered my gurney flap finally haha. Took long enough! Still debating if I want The STi pink springs or not. Then yen is at the perfect price right now.
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below.
Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty.
Old 02-21-2014, 10:12 AM   #216
JS + BRZ
Drives: 2010 MS3
Where you order that?
Sent from my SCH-I605
Old 02-21-2014, 10:14 AM   #217
krayzie
Drive From Home
krayzie's Avatar
We need to start a Team STI Peformance for us OEM+ whores.
Old 02-21-2014, 11:49 AM   #218
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Woot woot!
In my opinion, the STI springs are just bling. Stock suspension is fine, so the only reason to swap is to get low (I recommend Eibach Sportline) or get stiffer (coil-overs). Get sway bars swapped if you want to help your car feel a bit more planted. Also strut bars (like Grimmspeed's) really help.
Still at Japanparts.com
I noticed the STI brake lines are missing. What's up with that?
Old 02-21-2014, 02:15 PM   #219
krayzie
Drive From Home
krayzie's Avatar
The STI pink springs lower the car by 15mm, that would match the CoG of the LFA actually right? lol!
You will noticed that most if not all of the STI limited edition cars are lowered by 15mm as well.
Aren't the STI pink springs progressive? My car rotates differently after install (like the initial turn-in wasn't so clear anymore compare to stock so I got the flexible tower bar to fix that). Now I have the flexible draw stiffeners and the car feels like it gets sucked to the ground a bit when cornering fast. Just missing the trailing and lateral link sets now (pillowball inserts to enable faster/smoother vertical motion).
Yup I noticed they discontinued the brake lines I want to know why too (smells like a recall).
http://www.sti.jp/parts/catalogue/brz_zc6/6.html
Old 02-21-2014, 04:30 PM   #220
Chauntalei
Drives: Non-BRZ
I really want the carbon fiber TRD shark fins, but holy shit, I'm not spending $465 + shipping for them. I with the painted ones came in SSM. =/
2013 SSM BRZ Limited 6MT - 5/28/2012-10/28/2014
Chauntalei is offline   Reply With Quote
Old 02-21-2014, 04:58 PM   #221
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
http://www.ft86club.com/forums/showthread.php?t=57872
Probably same situation. Whomever they were using as a supplier most likely has a materials defect or more serious situation.
-alex
Old 02-21-2014, 05:00 PM   #222
mav1178
mav1178's Avatar
You know why it's $400+? It's true carbon fiber, not the CF-overlay fiberglass copies you find on the market.
Plus, TRD had Subaru create a special backing plate just to produce this piece. The backing plate is only found on the TRD fins, both CF/non-CF versions. That's a low-volume/high-cost situation that reflects the price.
-alex
Old 02-21-2014, 05:06 PM   #223
Chauntalei
Drives: Non-BRZ
-alex
The price can be completely justified, but I'm still not paying it for something like replacement side vents.
Old 02-21-2014, 06:57 PM   #224
Khazzy
Khazzy's Avatar
Woot woot!
Yeah the Eibach were what I was leaning towards just to close up the wheel gap a tad. I already have the Cusco bars tower bar for front and rear.
it sucks to be broke, sti omg!
WTB: Parts for my FR-S hyperpunx Interior Parts (Incl. Lighting) 1 03-05-2013 05:28 PM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 10:30 AM
