Old 02-20-2014, 05:57 PM   #29
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Oh you were knocking alright. No way you weren't. Thing is, most knock you can't hear, but knock detection does. When it gets to where you CAN hear knock in modern engines, you're probably about to get hosed.
And this car was meant to be run into high revs. Cruising is for sub 3k. Mid & upper band is above 3k.
I'm on my phone so if I make mistakes, blame Sportsguy83
^GT5 Replay Photo Mode^
Old 02-20-2014, 06:24 PM   #30
akahenry
akahenry's Avatar
Drives: '18 STi
Originally Posted by sshole View Post
Wants to throw money at car mods.
Can't buy the right gas.
LMFAO.
Dude just buy the FT86 CATTED UEL Header or the $1000 OFT + OFH combo. I'm planning to get the FT86 Catted UEL Header and a OFT later down the line. Don't buy a cat back first like I did. My current Cat back is quite loud imo but is still very daily drivable.
akahenry is offline   Reply With Quote
Old 02-20-2014, 06:32 PM   #31
FR-Slide
Drives: 13 Whiteout 6MT
On a serious note, a tune will help you with midrange power as well as top end. Lots of people are reporting that a simple tune can nearly eliminate that torque dip from 3500-4500 rpm. Tune + header will completely get rid of it.
I don't know about you, but most of my time in the BRZ is spent at 3000-4000 rpm and it hurts when I try to pass people on the highway.
If I REALLY need to pass, I just grab 4th, but I know what you mean. As I said before, I knew what I was getting with the car, and don't expect it to be a torque monster or v8-slayer.
Anyway, I think a tune is in the works eventually, but was trying to keep warranty in tact "just in case". Really just wanted a bit more bark to the car, so the few times that I DO get to drive it, I could enjoy the sound.
But I guess it's better to listen to Ron Swanson. Never half-ass two things; whole-ass one thing.
This is how my bank account stays empty
FR-Slide is offline   Reply With Quote
Old 02-20-2014, 06:34 PM   #32
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
IMO, if you can't run the minimum required fuel in the car than you shouldn't even consider modding.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 02-20-2014, 06:37 PM   #33
FR-Slide
Hey I figured out multi-quote.
Yeah, again it was never a "OMG I can't afford the extra $$ for 93", but more of a "meh, doesn't seem like I'm losing anything, seems like a waste" test. Easy fix, will remedy at next fill-up.
And I agree about the ideal powerband. Since most of my mileage is highway, I sit in the ~3k range. It is fun to uncork 6k+ once in a while.
Originally Posted by akahenry View Post
LMFAO.
I was reading about the OFH, and there was some concern about lack of flex joints on it, being UEL and all. I didn't get to finish the thread, but is this a real issue? I know most every header for flat-4s has flex built in, so is this how they can offer it so cheap?
But, I agree that after more thought, the RIGHT way to do this car is front to back. I just don't know that I want to do that YET. Which was why I was considering the cheap/easy route with the Berk kit. If that makes sense, anyway.
Old 02-20-2014, 06:56 PM   #34
gabeg86
gabeg86's Avatar
Drives: 2013 Raven FR-S
A lot of aftermarket headers don't have flex joints. The hks, which is one of the top performers and top quality pieces, doesn't have flex joints. There's a huge debate on whether they're required or not, but hasn't been a problem thus far
Revworks also has a good rep and they don't have flex joints on their uel
Sent from my HTC One using Tapatalk
Perrin (LWCP) - Blox (shift knob) - HID Powerhouse (LED's and HID's) - Eibach (sportlines) - Muteki (lugs) - SPL (LCA's) - Rays Engineering (57dr's) - Dunlop Direzza ZII (tires) - Greddy (Evo3) - Full Race (turbo kit) - Ecutek (tuned)
gabeg86 is offline   Reply With Quote
Old 02-20-2014, 06:57 PM   #35
SirBrass
SirBrass's Avatar
You want to keep your warranty intact? Yet you don't think it's worth it to put the proper fuel in it?
If you want to make sure any warranty claim you might have on your engine isn't denied, you'll put in the fuel the owner's manual & the gas door says you need to: MINIMUM 91, preferred 93 & up.
Old 02-20-2014, 06:59 PM   #36
noob and expert
Drives: None :(
If it's a daily driver, you definitely don't want a muffler delete with any other mods. Sure, you might gain a hp or 2 and lose some weight in the rear but you upset weight balance and only have one tip which doesn't look so good. The FT86Factory header is great both in performance, quality,etc. you can run a full exhaust with it and not get drone. It all depends on your catback. An invidia n1 will drive you crazy (pun intended) with a full exhaust and a q300 will give you no drone and will only be noticeable when you want it. Do some research. The header is definitely one if the best bang for the buck upgrades on this car. A header alone, chatted or not, will give you sound when you want it, no drone, will get rid of the torque dip, give you more power throughout the whole powerband, etc. I strongly recommend just getting the FT86 chatted if you want power, sound, drivability, no cel, no tq dip, and UEL.
??? is offline   Reply With Quote
Old 02-20-2014, 08:45 PM   #37
FR-Slide
Again, I ran 93 from when I got the car til a few months ago when I swapped over to 87 on a whim to test the difference, and never went back. When I picked the car up, dealer said to use 87.
And again, none of that really matters, since I can just switch back to 93 next time I need to fill up.
There are a few dual-exit track pipes/deletes out there, which is what I was considering, but thanks for the feedback. Power gains/weight saving would be minimal I know, was really just after some sound and new/better looking tips to fill out the rear when this whole thread was started haha.
Old 02-20-2014, 09:04 PM   #38
noob and expert
Drives: None :(
Yeah the stock tips are terrible
Old 02-20-2014, 09:07 PM   #39
SirBrass
SirBrass's Avatar
The dealer was grossly misinformed, then.
Good you're going to go back to using the good stuff. I don't advocate a tune except on e85 or 91/93 gas. Tunes can be good for improving drivability too on a stock exhaust.
Tune + header will totally eliminate the torque dip, also.
Old 02-20-2014, 10:24 PM   #40
cycleboy
Drives: 2013 Scion FR-S - Argento
It's in the owner's manual to use 93, or 91 if that's not available. . .
Kind of scary that a dealer would go against that. Might give you some recourse if it blew up and they are the ones who told you to (if they admit to it).
cycleboy is offline   Reply With Quote
Old 02-21-2014, 01:27 AM   #41
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
K&N or other high flow filter ($40)
Buddy club spec II catback exhaust ($500)
Invidia catless resonated front pipe ($260)
It's going to be loud, but hopefully the resonated front pipe will help you out with drone/rasp. It'll be a very free flowing exhaust combo
tyler_win_photo is offline   Reply With Quote
Old 02-21-2014, 08:03 AM   #42
FR-Slide
To be honest, I haven't cracked open the manual except to find out how to fix the windows when they froze shut But yeah, that was my thinking about dealer responsibility if I ever had to make a warranty claim.
I've got a drop-in and tube, and removed the sound tube and resonators. Definitely a good and cheap fix.
You'd say go for catback and FP before header?
Is your FR-S your daily driver? Drive Scion FR-S / Toyota 86 GT86 General Forum 136 02-10-2014 09:10 AM
FRS as a Daily Driver? Pake1 Scion FR-S / Toyota 86 GT86 General Forum 104 08-15-2012 11:48 PM
Will the BRZ be your daily driver WRXGuy1 BRZ First-Gen (2012+) — General Topics 47 05-23-2012 12:15 PM
BRZ as daily driver? Pakjk89 BRZ First-Gen (2012+) — General Topics 80 03-22-2012 09:50 AM
The daily driver KiingDavid CANADA 25 02-06-2012 01:14 PM
