Old 02-20-2014, 02:46 AM   #127
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Originally Posted by Wise View Post
Not sure what QLD's legality is but in VIC i've heard it's fine as long as the top doesn't poke out past the wheel arch.
max increase in track is 25mm here as well so regardless +35 illegal is by 1mm
86•BRZ is offline   Reply With Quote
Old 02-20-2014, 06:42 PM   #128
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Hmm I used to live on the gold coast and drive a single turbo supra with a long list of mods that weren't legal.
I lived there for 3 years and the only time I got pulled over I was driving my flatmate's 1993 Hyundai Excel. The cops in QLD seemed really laid back then.
Though I lived on the Gold Coast not in Brissie.
Wise is offline   Reply With Quote
Old 02-20-2014, 06:59 PM   #129
s2d4
s2d4's Avatar
The cops have more important things to do then to measure for 1mm.
Old 02-20-2014, 07:07 PM   #130
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
I drive a Calais turbo with external screamer piped wastegate for 10 years and was fine too.
Times have changed.
Old 02-20-2014, 07:08 PM   #131
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Probably. But not always. A mate was booked for a frayed bonnet liner once. As well as no shift pattern on a gear knob in a car that never came with one.
Old 02-20-2014, 07:22 PM   #132
s2d4
s2d4's Avatar
The point was, there is no reason to adhere to the 1mm when the total allowable according to you would be 1545mm front (0.065%) and 1665mm rear(0.0605%) especially when it becomes 0.5mm at each side, and forego functionality.
Old 02-20-2014, 07:39 PM   #133
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
I didn't. I went the +45 as it was closer to factory offset and the 35s poke too much for my liking. I understand that many people find this look very desirable.
Old 02-20-2014, 07:48 PM   #134
s2d4
s2d4's Avatar
I was referring to functionality but yes, I wouldn't forego functionality and lose ability to run the sprint brakes just because of trying to run useless 0 degree camber.
As for factory offset, this is mute when you are rubbing on the stock perch when you are only running 235 wide tyres or hit the toe arm on full lock.
Old 02-20-2014, 07:53 PM   #135
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
I run ~1.5 all round. Clearly stated many times it is my opinion about offset so why keep assuming things in an attempt to continue? everyone had different opinions/reasons. Though even with an inch lowering the 45s looks silly at the front as they poke out with no camber. Couldn't do 0 even if you wanted to.
Old 02-20-2014, 07:58 PM   #136
s2d4
s2d4's Avatar
Yes, your opinion is based on looks which obviously is subjective.
Old 02-20-2014, 08:20 PM   #137
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Part of it. But as said better steering geometry and legalities also. Sure, for a race car go the 35s and dare I assume! more than 3 dredgers camber for 255s
Old 02-20-2014, 08:24 PM   #138
That86mikeyb
Drives: scion fr-s
hey
what kind of wing is that????
Originally Posted by LevinPhan View Post
That86mikeyb is offline   Reply With Quote
Old 02-20-2014, 08:35 PM   #139
s2d4
s2d4's Avatar
Yes, your choice is the best.
Old 02-21-2014, 12:08 AM   #140
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Best for me. I've only tried to show why I chose 45 rather than the 35s.
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 03:50 PM
Wheel Directory: Enkei Kojin 17x9.0 +45 Clipdat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 08-02-2016 04:18 PM
