Old 02-20-2014, 07:04 AM   #197
Nardi330
Nardi330's Avatar
Drives: 86
Originally Posted by shiv@vishnu View Post
We do support G series ROMs from Aussie spec cars. Not a problem
Thanks Shiv. I have emailed my ECUTEK supplied stock rom to you.
Should the A01G roms from v1.55b works on my car? Or I should wait for you to review the sent rom first?
Thx
Nardi330 is offline   Reply With Quote
Old 02-20-2014, 10:31 AM   #198
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Thx
No problem. Since your original file is ZA1JA01G, just upload ZA1JA01G OTS maps. In fact, OpenFlash Manager won't let u load anything else. No need for you "stock" map
Shiv@Openflash is offline   Reply With Quote
Old 02-20-2014, 03:21 PM   #199
steve99
Drives: FT86
Thanks for your help.
Mine is a 2012 June built 86 manual.
I'm just a little unsure as my car had a ECUTEK flash. That wouldn't matter what type of rom my car has?
After reading my "stock" rom (supplied by my ECUTEK tuner), OFM reads the CAL being ZA1JA01G. Does this CAL change with the type of rom I previously had or it is fixed with my type of ECU. This is confusing me as I lost my stock rom from Toyota.
Thanks in advance.
As Shiv said you should be fine with loading up the A01G ROM's. ie the .bin format entire ROM
Where you will run into problems id if you try to use the .dev format database format option as the OFT will try to build a ROM and will look at checksums ect in your "standard" ROM . since its an Ecutek "stock" ROM it not actually exactly the same as stock ROM at it has a few bytes of ecutec license info embedded in it (performs as standard though).
I think Shiv was working on a stock ROM overwrite feature sometime in the future.
To use the .dev format option you would need to send shiv a copy of your stock "ecutek" ROM to add to the database.
Old 02-21-2014, 01:57 PM   #200
PMok
Codename: Stitch
PMok's Avatar
http://www.datazap.me/u/pmok/stage-1...g=0&data=1-2-9
here is my latest set of runs logged on v1.55b. On my 2nd tank of 91 after a previous fill up of 94. So about 500 miles of learning on this tune. IAM has stayed pretty close to 1, dipped a few moments to around 0.94 or so while driving but on these runs stayed at 1 all the way.
I think it looks pretty good but someone more knowledgeable than me please take a look and confirm.
Old 02-23-2014, 11:10 PM   #201
Nardi330
Nardi330's Avatar
Drives: 86
thanks for your reply.
Would you please kindly supply me with the true stock A01G file (as opposed to my ecuteck stock file)?
Robert promised me this when I ordered
Thanks in advance.
Thanks Steve for your help.
I have loaded A01G 1.55b rom over the weekend and it's awesome. like everyone else has said, this should be how it came from the factory.
Old 02-23-2014, 11:18 PM   #202
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
@shiv@vishnu
I've been having a couple weird run-ins with a rough idle suddenly. In particular, last night after a 20 minute drive (somewhat spirited, but not even close to redline) - I began to notice my idle would dip below 700 and I could feel the car "choking" (sorry if the term is wrong).
I've had this tune for a while now, and I find it weird to have this problem now. Just to be safe, and not knowing what to do. I simply reset my ECU (via battery disconnect), figured that might help esp. after my K&N Filter install. Any ideas what happened in the first place?
leicaboss is offline   Reply With Quote
Old 02-24-2014, 02:09 AM   #203
steve99
Drives: FT86
Thanks in advance.
The "stock" A01G map shiv has is actually the map from my car if you PM me with your email i will send it to you
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Nardi330 (02-24-2014), Shiv@Openflash (02-24-2014)
Old 02-24-2014, 10:11 PM   #204
troek
troek's Avatar
Drives: 2012 Toyota 86
Originally Posted by leicaboss View Post
@shiv@vishnu
my car has done this from time to time on the stock tune. i have the ZA1JA01 rom. its not very often at all though.
troek is offline   Reply With Quote
The Following User Says Thank You to troek For This Useful Post:
leicaboss (02-25-2014)
Old 02-25-2014, 01:35 AM   #205
Shiv@Openflash
Drives: 2013 FRS
Update:
1) New v1.56b maps are available for download!
Changes:
-Added full tuned map and XML support for A01E (C6 6MT) and A01A (DOM 6MT) ROMs.
2) XML support for A01E and A01A ROM now added to RomRaider XML file download.
The Following 5 Users Say Thank You to Shiv@Openflash For This Useful Post:
makinen (02-25-2014), normancw (02-25-2014), troek (02-25-2014), vynervt (02-25-2014), Yobiwan (02-25-2014)
Old 02-25-2014, 01:48 AM   #206
troek
troek's Avatar
Update:
Changes:
A type roms?! I love you!
Shiv@Openflash (02-25-2014)
Old 02-25-2014, 02:25 AM   #207
brn12345
brn12345's Avatar
Enjoy the maps! I am running 1.55b and absolutely love it. I run high enough octane that my IAM is always 1 and Fine Learning knock table is never populated. Launch control is great too and you can set it by RPM and also to which KM/H you want it to disengage
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
Old 02-25-2014, 05:32 AM   #208
troek
troek's Avatar
i was told A type roms dont support IAM montoring yet. havnt data logged with 1.56 to verify either. also im very interested in disabling the valve retardation/cat warm up thing during cold start.
Old 02-25-2014, 06:26 AM   #209
brn12345
brn12345's Avatar
The cold start warm up thing is very annoying I agree. Its actually not valve retardation but timing retard. OEM it is set at -15deg retard during the warm up phase. I have set mine to -8deg and the drone is much reduced. On my next flash I plan on reducing it to -4 degrees to reduce it further. This is very easily changed via romraider or other editors.
The Following User Says Thank You to brn12345 For This Useful Post:
troek (02-25-2014)
Old 02-25-2014, 07:36 AM   #210
Kodename47
Kodename47's Avatar
Drives: UK GT86
You can reduce the cold start RPM too
.: Stealth 86 :.
Kodename 47 DJ:
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
FS: Openflash Tablet Sgt.Beardface Engine, Exhaust, Bolt-Ons 8 01-04-2014 11:12 AM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 12:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 09:05 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
