Old 02-20-2014, 10:54 AM   #1
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Flex Fuel cold start stumble
I just thought I'd post my log of an E85 cold start with flex fuel. The first start always stumbles and dies. Second start fires perfectly.
I'll be working with my tuner to fix this and hope to learn what the issue was. So take a peak.
post_break is offline   Reply With Quote
Old 02-20-2014, 11:03 AM   #2
jamesm
Probably needs more cranking ipw compensation for the ethanol content.
Old 02-20-2014, 11:10 AM   #3
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
could be a vacuum leak also
lol
Ironsquid is offline   Reply With Quote
Old 02-20-2014, 11:18 AM   #4
jamesm
lol
^ i see what you did there
Old 02-20-2014, 01:02 PM   #5
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Could also be the tuners fault. *drops the mic* @Sportsguy83
BTW, James we good for next weekend?
Old 02-20-2014, 01:09 PM   #6
jamesm
Yes sir
Old 02-20-2014, 01:14 PM   #7
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Yes sir
Awesome can't wait, Temps have been good but it varies. Hopefully nothing arises too.
Old 02-20-2014, 01:43 PM   #8
post_break
post_break's Avatar
Can that be adjusted based on ethanol percentage? So if you increase that for E85, would there be issues keeping it the same for E10?
Old 02-20-2014, 01:48 PM   #9
jamesm
It's part of the flex fuel setup. A custom map that scales cranking ipw to the output of the ECA scaler map. So yes it's adjusted based on ethanol content automatically once set up properly.
Old 02-20-2014, 02:02 PM   #10
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Same here, but not FF. Just using OFT E85 map. Staring at RomRaider this morning to get some sense of what needs to be changed.
http://www.ft86club.com/forums/showt...=46468&page=53
See posts #1150-1152.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 02-20-2014, 02:45 PM   #11
post_break
post_break's Avatar
Yeah mine does the same thing. Not that it's "cold" just hasn't been started in a while. 8 hours and it won't start on first try. 4 hours it will fire right up. Once when it was really cold, like 30ish it refused to start. I had to try 4-5 times and give it gas to finally come alive.
Old 02-20-2014, 02:47 PM   #12
jamesm
Bump up the cranking ipw or cranking enrichment just a bit at a time until it fires up first crank.
Old 04-02-2014, 01:40 PM   #13
post_break
post_break's Avatar
Just an update. Visconti has pulled through again and my cold start fires every time and now the exhaust cams (I have no idea what I'm talking about) are silent.
I was setting off car alarms before. Now my unlock beep is louder than my exhaust.
[ame="https://www.youtube.com/watch?v=EzEHsjHYeUA"]flex fuel cold start - YouTube[/ame]
E85/Flex fuel hard start? iketiak Engine, Exhaust, Transmission 18 01-14-2017 07:12 PM
Engine stumble around 2.5k rpm in cold weather Eyesacky Issues | Warranty | Recalls / TSB 2 11-02-2013 04:50 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
FR-S cold start stumble - video whtchocla7e Issues | Warranty | Recalls / TSB 11 04-17-2013 07:02 AM
