go_a_way1
Old 02-19-2014, 10:18 PM   #3739
HSayaovong
HSayaovong's Avatar
Drives: blk;2dr;rwd;fun
Pardon my intelligence but what is a TQ250 and M45 blower? Is that the ESC + "insert cool stuff here"? Sound like a type of battery?
Originally Posted by Robftss View Post
Boost curves:
Blue line - M45 PD blower only.
Green line - TQ250 & M45 blower together.
*2.4L GM engine*
Life is like taking a dump, sometimes it's easy and other times its hard. But it always stinks
HSayaovong is offline   Reply With Quote
Old 02-19-2014, 10:32 PM   #3740
fenton
The TQ250 is the phantom electric supercharger. It is centri blower connected to a electric motor for drive power.
The M45 is a positive displacement blower that was already fitted to the car in question.
What you see is the before and after of having just a PD blower and having a PD blower plus the Electric supercharger in a twin configuration.
The large and small denominations on the graph are the TQ180 and the TQ250, the 180 does not apply to our car as it is too small.
fenton is offline   Reply With Quote
Old 02-19-2014, 10:39 PM   #3741
HSayaovong
HSayaovong's Avatar
Thank you for the free education, everyone here is so nice. Thank God it's not like other forums I've joined in the pass, i would've been kicked around a few times for not knowing the lingo.
Old 02-19-2014, 11:10 PM   #3742
Thatruth2001
Drives: Raven FR-S
I hate all you dual dump pack people. Just when I thought I was out I keep getting pulled back in..... Has anyone developed a step by step installation of the dual packs and relocation of the battery?
Thatruth2001 is offline   Reply With Quote
Old 02-19-2014, 11:16 PM   #3743
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Love that line...
Installed Mods:
Old 02-20-2014, 01:14 AM   #3744
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
thatruth2001: I hate all you dual dump pack people
I haven't even got the kit yet but yeah, the dual pack is a must for me.
If I ever catch up on my projects, I'll try to make a DIY relocation, preferably to the back seat. Though I still want to know how to get the positive cable into the cabin, I don't want to drill an unnecessary hole through the firewall. All I have to do is fix my tail light/fish tank (about 1 inch of water in there now) + 20 other things. I suppose I am gonna break down and get the OFT/OFH combo while waiting for all the tunes and the tq300 to become available. (anybody here heat-wrap the OFH?)
Quick question, is the aux charger necessary with the dual pack setup or just a perk?
Target70 is offline   Reply With Quote
Old 02-20-2014, 01:49 AM   #3745
jpit
Drives: Subaru BRZ
The positive cable fits fine through the firewall where the sound tube was disconnected. Then you can run it right up through the center console. You don't need the aux. charger.
jpit is offline   Reply With Quote
The Following User Says Thank You to jpit For This Useful Post:
DAEMANO (02-20-2014)
Old 02-20-2014, 03:12 AM   #3746
Target70
Target70's Avatar
Thanks, I haven't removed any of the sound tube stuff, so I don't really know the size of the hole, but judging from the plug I used to block it off, I wouldn't think a 4ga (That's what you used If i remember correctly) would fit by itself, much less with all the phantom wires running beside it.
I have 16ft of both red and black 2ga laying around from a relocation on my 240sx I never got around to. Do you think that it would fit? *edit.. just the positive, I will probably ground to chassis, and run a ground strap from the outside/backside of that bolt to the engine, or the shock tower where everyone moves the ground to.
Old 02-20-2014, 09:25 AM   #3747
fenton
Im pretty sure that Rob recommends the Aux charger with the TQ300. Reason being is the increased draw the the 300 will deplete the battery pack quicker.
Very interested to see @shiv@vishnu 's results as he said he had a good performance bump even with the TQ250.
Old 02-20-2014, 09:28 AM   #3748
VR46
are you Jeff Vader?
VR46's Avatar
Drives: Black BRZ Limited
+1 - I've got an extra dump pack sitting here purely by accident.
VR46 is offline   Reply With Quote
The Following 2 Users Say Thank You to VR46 For This Useful Post:
DAEMANO (02-20-2014), Sojhinn (02-20-2014)
Old 02-20-2014, 09:47 AM   #3749
Sojhinn
Sojhinn's Avatar
I think what matters on the dual packs is the top end power. We've got a helluva a lot on tap down low. I'm curious how it will translate on the top end.
Installed Mods:
Old 02-20-2014, 09:59 AM   #3750
migueralliart
migueralliart's Avatar
Drives: 2013 Firestorm FRS
battery options
Just wanted to add my 2 cents here since I"m going this route soon.
Another option to a second dump pack is to get a higher discharge rate battery (high performance). I searched around for suitable replacements to the already inexpensive option Rob provided which is great but just wanted to see what else was out there.
YUASA makes a line of high performance ATV batteries called the YUMICRON CX.
[ame="http://www.amazon.com/dp/B000GZRBXS/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=3P2MG 08QLCLT2&coliid=I3J99HRX022I8H"]Amazon.com: Yuasa YUAM2218C Y50N18L-A-CX Battery: Automotive[/ame]
I have not seen a discharge graph of these at 200 amps but I'm pretty sure these will hold voltage better than the atbat packs.
Just an option to people that don't want to have 2 packs and relocate all that stuff to the trunk making it harder for servicing at the dealership etc.
Remember keeping the voltage sag to a minimum is gonna give you a more stable boost and more HP.
migueralliart is offline   Reply With Quote
Old 02-20-2014, 11:35 AM   #3751
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Originally Posted by migueralliart View Post
You are free to use whatever you want. But here are a few thoughts:
The battery you selected is larger then the batteries Rob suggests. The battery you selected are not sealed like the batteries Rob suggests. The battery you selected have not been field tested like the batteries Rob suggests. The battery you selected are twice the price then the batteries Rob suggests.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
The Following User Says Thank You to Gary in NJ For This Useful Post:
Old 02-20-2014, 11:43 AM   #3752
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
After seeing that plot with the m45, I really wana see someone run a compound set up with an innovate. That would give all the TQs
bee_are_zee is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
