Old 02-18-2014, 05:06 PM   #1
yuicebox
Drives: Asphalt FRS
BRZ LED DRL Strip Question
Hi everyone,
I'm looking to do a FRS -> BRZ front end swap, but I don't want BRZ headlights.
The problem with this is that the BRZ headlights have built-in turn signals, whereas the FRS headlights do not.
I want to turn the LED DRL strip above the fog light bezel on the BRZ bumper into an LED Switchback turn signal. I was wondering if anyone had any suggestions how how I could do this.
I haven't seen the LED DRL strip in person, so I'm not sure what kind of bulbs are in it or if they're replaceable. If they can be replaced with LED switchback bulbs, I would assume the wiring would be pretty straight forward. If they can't be replaced, then this might be a bit more complicated.
Thoughts?
yuicebox is offline   Reply With Quote
Old 02-18-2014, 05:10 PM   #2
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
The BRZ LED DRL can only be replaced as a unit, unless you want to solder.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 02-18-2014, 05:25 PM   #3
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Soldering won't work.
Old 02-18-2014, 05:30 PM   #4
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Originally Posted by yuicebox View Post
Hi everyone,
Thoughts?
They were like the main selling point for BRZ over an FRS for me.
Sorry for the off topic though. I think worst case scenario you could split the housing of the DRL and put new bulb/sockets in there maybe?
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 02-18-2014, 05:34 PM   #5
yuicebox
Drives: Asphalt FRS
Don't get me wrong, I LIKE the BRZ head lights but they're just expensive and hard to source cheaply.
Stock FRS headlights can be had for like $150 a pair.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Old 02-18-2014, 11:24 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
i've been slowly working on doing exactly that. all the current details are here
http://www.hidplanet.com/forums/show...ghts-internals
but i'm doing it because i want to use the turn signal location for other lighting ideas.
but i've since realized that i screwed up-- i'm used to working with through-hole designs where i can just flip the original to get a matching left/right pair, but with the components involved with this design, i need to design both boards independently to get all the connections to line up where they're supposed to be.. so the project is at about 50% in the design phase now..
but i really don't have much of an intention to sell these boards later on-- you're free to use the design if you'd like, i just don't think most will be willing to pay for what i expect my costs to be to design and build the entire setup...
Old 02-19-2014, 01:46 AM   #7
yuicebox
Drives: Asphalt FRS
That's awesome! I'm not very smart when it comes to all this electrical stuff, what makes it so expensive?
Old 02-19-2014, 02:26 AM   #8
DaJo
FT86Club Vancouver
DaJo's Avatar
I'm assuming labour and craftsmanship plays a big role when designing.
2000 MR-S 5MT
2010-2012
Old 02-19-2014, 07:33 AM   #9
sshole
Then what makes you think you can turn the LED DRL into an LED switchback so easily?
sshole is offline   Reply With Quote
Old 02-19-2014, 11:28 AM   #10
yuicebox
Drives: Asphalt FRS
Erm, I never said it was going to be easy. I said it was something I wanted to do. I was trying to find out more information about whether or not it was a matter of changing bulbs and splicing wires or if it was more complicated.
You're just intentionally being an...... @sshole
The Following User Says Thank You to yuicebox For This Useful Post:
sshole (02-19-2014)
Old 02-19-2014, 12:14 PM   #11
sshole
Yay you understand my username. Turns out you're not as "not very smart" as you make yourself out to be.
Old 02-19-2014, 12:19 PM   #12
yuicebox
Drives: Asphalt FRS
This guy is so cool, I just want to give him my car
Old 02-19-2014, 09:14 PM   #13
soundman98
soundman98's Avatar
somewhat. a lot of it has to do with the quality of parts. in general, when i've quoted led work in the past, i quote double whatever the raw parts cost is.. that typically works out to be about $5/hr for designing, building and testing the circuit boards--which is also why it's not really profitable for most platforms i've been involved in...
one of my stipulations is that i always use quality name-brand parts-- for instance, this project is going to use genuine lumiled rebel's for the led's, and then use led drivers with internal thermal cutoff. non-branded parts tend to have lower quality standards that can lead to early failure..
i could get away with not using name-brand stuff and save some money, but it only ends up hurting the quality of the end product later on.. i prefer to spend the extra now and make something that i'll never need to touch ever again..
DaJo (02-19-2014)
beer, brz, front end, frs, swap
BRZ ‘s “boomerang” LED strip mystery DrakeM BRZ First-Gen (2012+) — General Topics 114 05-05-2015 12:00 PM
People with the LED DRL strip.. husker741 Cosmetic Modification (Interior/Exterior/Lighting) 13 10-23-2013 06:19 PM
no front LED strip? Lydin Scion FR-S / Toyota 86 GT86 General Forum 3 06-03-2012 02:05 AM
About the LED strip on the GT86 Sasquachulator Scion FR-S / Toyota 86 GT86 General Forum 14 05-15-2012 12:14 AM
