BRZ LED DRL Strip Question
Hi everyone,
I'm looking to do a FRS -> BRZ front end swap, but I don't want BRZ headlights. The problem with this is that the BRZ headlights have built-in turn signals, whereas the FRS headlights do not. I want to turn the LED DRL strip above the fog light bezel on the BRZ bumper into an LED Switchback turn signal. I was wondering if anyone had any suggestions how how I could do this. I haven't seen the LED DRL strip in person, so I'm not sure what kind of bulbs are in it or if they're replaceable. If they can be replaced with LED switchback bulbs, I would assume the wiring would be pretty straight forward. If they can't be replaced, then this might be a bit more complicated. Thoughts? |
The BRZ LED DRL can only be replaced as a unit, unless you want to solder.
Sorry for the off topic though. I think worst case scenario you could split the housing of the DRL and put new bulb/sockets in there maybe? |
Stock FRS headlights can be had for like $150 a pair. Sent from my SAMSUNG-SM-N900A using Tapatalk |
http://www.hidplanet.com/forums/show...ghts-internals but i'm doing it because i want to use the turn signal location for other lighting ideas. but i've since realized that i screwed up-- i'm used to working with through-hole designs where i can just flip the original to get a matching left/right pair, but with the components involved with this design, i need to design both boards independently to get all the connections to line up where they're supposed to be.. so the project is at about 50% in the design phase now.. but i really don't have much of an intention to sell these boards later on-- you're free to use the design if you'd like, i just don't think most will be willing to pay for what i expect my costs to be to design and build the entire setup... |
You're just intentionally being an...... @sshole |
This guy is so cool, I just want to give him my car
one of my stipulations is that i always use quality name-brand parts-- for instance, this project is going to use genuine lumiled rebel's for the led's, and then use led drivers with internal thermal cutoff. non-branded parts tend to have lower quality standards that can lead to early failure.. i could get away with not using name-brand stuff and save some money, but it only ends up hurting the quality of the end product later on.. i prefer to spend the extra now and make something that i'll never need to touch ever again.. |
| All times are GMT -4. The time now is 11:33 PM. |
User Alert System provided by
